Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 76
Thread: RRRSSReader... because this place is a ghost town!
  1. #51
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i'll take a look at it today.
    Live mp3Car Facebook Chat
  2. #52
    FLAC -zip-'s Avatar
    Ontario/Canada
    Thanks!
    Sound Stage
    Eclipse|MTX|Infinity
  3. #53
    Woodbridge, VA
    Blog Entries
    55
    Im trying to duplicate your problem but i cant. Send me your rrrssreader_debug.txt and your rrrssreader.ini file so i can use the same feeds.
  4. #54
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    So i'm struggling to get this plugin to launch... to me it doesnt seem that the RSSREADER command is doing anything. i havent added it to my exectbl or anything, how can i make this work..
    thanks!
  5. #55
    Jan 2011
    notes to add.....
    If you are a windows 7 user you must do the following:
    -You must have UAC disabled in order to run regasm in cmd (which this does in the .bat)
    -You must right-click Run as Admin
  6. #56
    Mar 2006
    Houston, TX
    yeaa ive done both of those things and its the same problem.. didnt think that would fix it. i'm pretty sure the problem is that my RR doesnt know what to do with the command "RSSREADER"
  7. #57
    Jan 2011
    I registered the dll and the plug-in inside of rrConfig. I then copied the contents of the folder I was told to in to the directory of the skin (in the root folder). Example: C:\Program Files\RideRunner\Skins\Someskin). If you have the contents in the root of the skin it should know what to call with the RSSREADER command.
  8. #58
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by tundra2000 View Post
    show me rrrssreader_debug.txt from the plugins main folder. If there isnt one that means you dont have it registered correctly. You should see the plugin in your RR debug.txt as loaded.
  9. #59
    Mar 2006
    Houston, TX
    Quote Originally Posted by Sonicxtacy02 View Post
    thanks. had the folder just sitting in the RR directory, not the RR\Plugins directory. the uninstall, move to the correct location, and reinstall fixed it. thank you!
  10. #60
    Jan 2011
    no problem. now i dont feel like a leech around here, because you are my first contribution.
  1. safest place to place laptop?
    By cubanmoses in forum General Hardware Discussion
    Last Post: 07-16-2003, 03:10 PM
  2. where and how to place laptop???
    Last Post: 06-08-2003, 01:39 AM
  3. cheapest place to get an laptop hdd adapter?
    By whoojong in forum General Hardware Discussion
    Last Post: 01-27-2003, 01:19 PM
  4. The best place for LCD's
    By gish34334 in forum LCD/Display
    Last Post: 04-29-2001, 11:24 PM
  5. is there a place that i can get an lcd 6'' for around 150$ or less?
    By BobyYoo in forum General Hardware Discussion
    Last Post: 11-28-2000, 12:03 AM
