where is rr.ini? i haven't this file..
Printable View
Under your folder C:\Program Files\RideRunner\
Thats only if your running RR in legacy mode, otherwise its in Docs\RideRunner\Config
ok.. it is in docs/riderunner/config...
but i have installed plugin and installed dvbviewer..
then i have made modify in rr.ini, but when i call dvb.skin from menu, dvbviewer don't start..why ?
yes......
really it is: dvbviewerexepath=C:\Program Files\DVBViewer Demo\dvbviewerdemo.exe
i dont think it was ever tested with the "DEMO" version
assuming its the same program
but something should launch id think when you got to dvb skin...
ok.. it is all right now.. i have installed dvbviewer full version and now it works..
thank you..
someone haa got a photo of skin completed ?
i don't understand whitch are important button/command for set up skin..
thank you
