Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: DVB viewer RR plugin
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    let me 1st say that this plugin was written by Mitch, I would like to thank him very much for that.
    Me and Dartman_71 helped in testing.
    1. install latest RR
    2. install dvb viewer
    3. run the plugin installer (there is a test skin in the plugin folder - just copy the files to your skin folder)
    SkinCommand; "DVB", translates to "LOAD;dvb.skin;DVB"
    label; ACTIVESOURCE = "DVB", uservar; ACTIVESOURCEID = 9
    Code:
    *   DVBViewer plugin for Ride Runner
    *   V1.0.0
    * Requires DVBViewer
    * Requires RideRunner 08/2010 or Newer
    * Skin name = "dvb.skin"
    Summary:
        When entering "dvb.skin" the plugin will launch(if not already running)
        dvbviewer.exe and wait for it to load, and send the un-mute command.
        If already loaded, it will send un-mute command.
        The RR "EXIT" command (while on "dvb.skin", will send the mute command.
    RR.ini Setting:
    "dvbviewerexepath="  path to dvbviewer.exe
        Examples:
            dvbviewerexepath=C:\Program Files (x86)\DVBViewer\dvbviewer.exe
            dvbviewerexepath=C:\Program Files\DVBViewer\dvbviewer.exe
    COMMANDS:
    "DVBCOMMAND;xxxx"        - Sends command xxxx to dvbviewer.exe (see below for xxxx)
                               Example: "DVBCOMMAND;8" is channel minus
    "DVBMUTE;x"              - Mutes or Un-Mutes DVBViewer Audio.
                               Example: "DVBMUTE;1" or "DVBMUTE;true" mutes
                                        "DVBMUTE;0" or "DVBMUTE;false" un-mutes
    DVBViewer Commands: (from actiions.ini)
    Pause=0
    OnTop=1
    HideMenu=2
    ShowStatusbar=3
    Toolbar=4
    Fullscreen=5
    Exit=6
    Channellist=7
    ChanMinus=8
    ChanPlus=9
    ChanSave=10
    Fav1=11
    Fav2=12
    Fav3=13
    Fav4=14
    Fav5=15
    Fav6=16
    Fav7=17
    Fav8=18
    Fav9=19
    Fav+=20
    Fav-=21
    Aspect=22
    Zoom=23
    Options=24
    Mute=25
    VolUp=26
    VolDown=27
    Display=28
    Zoom50=29
    Zoom100=30
    Zoom200=31
    Desktop=32
    RecordSettings=33
    Record=34
    Teletext=35
    EPG=37
    Fav0=38
    Channel0=40
    Channel1=41
    Channel2=42
    Channel3=43
    Channel4=44
    Channel5=45
    Channel6=46
    Channel7=47
    Channel8=48
    Channel9=49
    TimeShift=50
    TimeShiftWindow=51
    TimeshiftStop=52
    RebuildGraph=53
    TitlebarHide=54
    BrightnessUp=55
    BrightnessDown=56
    SaturationUp=57
    SaturationDown=58
    ContrastUp=59
    ContrastDown=60
    HueUp=61
    HueDown=62
    LastChannel=63
    Playlist=64
    PlaylistStart=65
    PlaylistNext=66
    PlaylistPrevious=67
    PlaylistLoop=68
    PlaylistStop=69
    PlaylistRandom=70
    Hide All=71
    Audio Channel=72
    OSD-OK=73
    OSD-Red=74
    OSD-Green=75
    OSD-Yellow=76
    OSD-Blue=77
    OSD-Up=78
    OSD-Down=79
    OSD-First=80
    OSD-Last=81
    OSD-Previous=82
    OSD-Next=83
    OSD-Close=84
    Best Width=89
    Play=92
    Open File=94
    Stereo/Left/Right=95
    OSD-Teletext=101
    Jump Minus 10=102
    Jump Plus 10=103
    Zoom Up=104
    Zoom Down=105
    StretchH Up=106
    StretchH Down=107
    StretchV Up=108
    StretchV Down=109
    Stretch Reset=110
    OSD-Menu=111
    Previous=112
    Next=113
    Stop=114
    Screenshot=115
    Equalizer=116
    ChannelEdit=117
    Last File=118
    ChannelScan=119
    Video Output A/B=132
    Audio Output A/B=133
    Show Videowindow=821
    OSD-Left=2000
    OSD-Clock=2010
    OSD-Right=2100
    OSD-Show HTPC=2110
    OSD-Background Toggle=8194
    OSD-Show Timer=8195
    OSD-Show Recordings=8196
    OSD-Show Now=8197
    OSD-Show EPG=8198
    OSD-Show Channels=8199
    OSD-Show Favourites=8200
    OSD-Show Timeline=8201
    OSD-Show Picture=8202
    OSD-Show Music=8203
    OSD-Show Video=8204
    OSD-Show News=8205
    OSD-Show Weather=8206
    OSD-Show Miniepg=8207
    OSD-Show Computer=8210
    Toggle Mosaicpreview=8211
    OSD-Show Alarms=8212
    Show help=8213
    Hide Videowindow=8214
    Exit=12294
    Toggle background=12297
    Eject CD=12299
    Forward=12304
    Rewind=12305
    Add Bookmark=12306
    Hibernate=12323
    Standby=12324
    Slumbermode=12325
    Close DVBViewer=12326
    Speed up=12382
    Speed down=12383
    Show Playlist=12384
    Show Version=16384
    Disable Audio=16385
    Disable AudioVideo=16386
    Disable Video=16387
    Enable AudioVideo=16388
    Zoomlevel Standard=16389
    Zoomlevel 0=16390
    Zoomlevel 1=16391
    Zoomlevel 2=16392
    Zoomlevel 3=16393
    Zoomlevel Toggle=16394
    Toggle Preview=16395
    Restore DefaultColors=16396
    DVD Menu=8246
    Shutdown Card=12327
    Shutdown Monitor=12328
    Stop Graph=16383
    WindowMinimize=16382
    WindowRestore=16397
    OSD-Show Subtitlemenu=8247
    OSD-Show Audiomenu=8248
    Play DVD=8250
    Recorded Shows and Timer statistics=2011
    Keep Timeshift File=2012
    Portal select=8254
    Zoom75=2013
    Clear Channel usage counter=8255
    Stop Renderer=8256
    Play AudioCD=8257
    OSD-CAM Window=8259
    Refresh RecDB=8260
    Cleanup RecDB=8261
    Compress RecDB=8262
    Refresh Cleanup Compress RecDB=8263
    Power Off=12325
    Reboot=12329
    Show Current Info=8264
    Show Radio list=8265
    Service Standby=8272
    Service Hibernate=8274
    Service Shutdown PC=8273
    Service Wake on LAN=8275
    Service get EPG=8276
    DVB Source Properties=134
    OSD-Show SysInfo=8277
    OSD Toggle View=8278
    OSD Toggle Sort=8279
    OSD Toggle Sortdirection=8280
    Attached Files Attached Files
    Aug 2004
    Germany
    YesyesYES ! Was desperately waiting for this ! Will try when I'm home .
    Apr 2006
    Greece
    if you have a powerfull pc you can run dvbviewer at startup or you can even have rr start it -and hide it-so it will be ready when you enter the dvb.skin
    you can do that by adding this to your startup commands
    Code:
    run;C:\Program Files\DVBViewer\dvbviewer.exe||wait;4||dvbcommand;16382
    wait;4 makes sure dvbviewer is loaded
    dvbcommand;16382 will hide it
    and select "run in full screen" in dvbviewer options, makes it easier to embed right
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I would love to see a screen capture of it in your skin, and how it embeds ect.
    My Fiero Build Thread
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Just one thing, can you to rename the dvbviewer.skin file by dvb.skin please ?
    Very cool plugin .
    A full skin example would be a good idea !
    Thanks for this plugin
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Thank's to Mitch for hard work and to Nomader and me for playing along.
    Reborn updated if you like to play with DVB.
    To JohnWPB: Screen capture in Reborn thread
    To pierrotm777: skin name have to be dvb.skin to work properly, I don't know why sample is DVBViewer.skin
    Feb 2006
    Hi
    I've got an error message
    Line -1:
    Error: Variable used without being declared
    Could you kindly let me know if anything wrong with my settings.
    Thanks in advance!
    Apr 2006
    Greece
    Quote Originally Posted by vinchan View Post
    Hi
    Line -1:
    Thanks in advance!
    make sure u use latest RR
    MySQL Error
    Oct 2004
    FIXED sample skin...
    that error, looks autoit3 related, nothing to do with plugin
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2009
    Finland
    Hi
    Line -1:
    Thanks in advance!
    You didn't get much details but my best bet is that you use Reborn skin. If you get error when pressing some buttons or you try to open or close button menu. Try this, open dvb.skin and dvb_menu.skin with notepad and you see WAIT;0.2 commands, increase wait value to 0.4 or more if needed. With slower pc's may have prob if wait value is too small, not enough time for close script before script start again. I try to keep delays small, sorry if that cause gray hairs.
  1. How to make Winamp TV Plugin work with RR
    By ramez75 in forum Road Runner
    Last Post: 09-03-2010, 01:17 AM
  2. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 03:36 AM
  3. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  4. New RR Image Viewer
    By gabepage in forum Software & Software Development
    Last Post: 05-17-2007, 08:50 PM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
