Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 56
Thread: BASSRR [The All In One Player]
  1. #31
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    afraid not ,, YT uses the Bass player ,, its all hardcaoded this way , i know El WAS thinking about seperating the sections of Bassrr , but for the moment i think that will be on hold for a while,, if it ever comes atall..
    sorry
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #32
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    I'm trying this new PI and I really like the idea to have music/video/youtube/shoutcast everything controlled by the same player!! Using different players (winamp, mpc...)
    I always had problems with sound quality (mainly equalizer), visualization etc. so I think it's better to have one single player with all features in it.
    Anyway, just tried to install BASSRR on a fresh install of OS (win xp sp3) and RR (latest). I have no other plugins running at the moment so it's a clean system. Tried to build the database for music and it hangs at 51%.
    My music folder contains about 15k songs, every album in it's own folder with it's folder.jpg cover. In case of more albums from the same artist there's the artist as root folder then the single folders for albums inside.
    Is there a way to see what's happening and why it stops at 51% when building db?
    P.S. I forgot to mention that I'm running the included sample skin to test PI! Is there some other suggested/better skin using BASSRR PI as player?
  3. #33
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    as for a better skin no ,, not at this moment in time ,,, but i'm working on it (Genesis)
    building a DB dose take a little time to do ,, its not done in seconds,,, it also freezes rr while building the db ,,,
    goto your PI folder Bassrr and delete the BassDB file ,,, and try again ,, give it some time to work though
  4. #34
    Jun 2007
    Sardinia Island
    Thank you carputer1.
    I tried what you suggested and observed the BASSDB.db file after rebuild command was called. It rapidly grows to reach 1.299KB and, it's a matter of seconds, then stops here.
    Tried to wait for over an hour yesterday but nothing happens after the stop at 51%; cpu is also free and no hdd activity.
  5. #35
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    can you upload your rr debug file and db file please
    also how did you reg the pi ,, hopefully by the reg.bat file ....
    is your media on a ext drive or home drive
    i'm yet to see this issue in other users tests ,,, but lets have look see if we can see whats going on
  6. #36
    Jun 2007
    Sardinia Island
    Here it is
    I registered plugin by reg.bat file and everything was ok (I removed "/s" to see messages from registration process).
    My media is on home drive.
    Attached you'll find the copy of db file when process of rebuilding database stopped to work then, after I exited RR, the db file. It seems that the plugin deletes all the work done (1.299KB) and leaves an empty file (2KB only).
    Is the genesis skin available to test?
    Attached Files Attached Files
  7. #37
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    looking at the debug the db is not being built open the exectbl.ini go down to onskinstart line remove ||1stRun
    just to double check everything
    open rrconfig or rr.ini make sure the player is set to Bassrr
    makes sure music path is correct
    make sure your music audio Types are correct
    open skin tool
    in top line put Bass_rebuild_DB
    in the label section
    Bass_db_adding set to auto update
    switch to or open another window for live debug in skintool
    fire the bass_rebuild_db cmd from skin tool and watch to see whats happens
  8. #38
    Jun 2007
    Sardinia Island
    Ok, removed "||1stRun" and checked everything on rr.ini.
    On skintool I see bass_db_adding value increasing but it stopped at 7801. At same time the live debug log shows:
    Code:
    bass_rebuild_db
    Command Not Executed: bass_rebuild_db
    *BASS_ONDBBUILD
    ---------- Post added at 01:02 PM ---------- Previous post was at 12:54 PM ----------
    If I try to "Send Command" again, bass_db_adding value start to grow and reaches 15602 value then stops again and live debug log repeat the previous messages!
    15602 is exactly 7801 doubled and, as I can see in included docs, this is the file counting...
    Maybe it's not a matter of file but is there any chance to see which file is stopping the process?
  9. #39
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    look far bass_config.ini delete that
    delete db
    dl this dll install to bass pi folder use reg.bat
  10. #40
    Jun 2007
    Sardinia Island
    Ok.
    Deleted bass_config.ini from RR root folder.
    Deleted BASSDB.db from RideRunner\Plugins\BASSRR folder
    Replaced old BASSRR.dll with the new one and registered correctly.
    Started the process with skintool and it stopped again at 7801 with usual message on live log.
  1. Bassrr
    By EL CAMINO in forum RR Plugins in Progress
    Last Post: 11-04-2010, 01:55 PM
