Page 15 of 22 FirstFirst ... 5678910111213141516171819202122 LastLast
Results 141 to 150 of 213
Thread: IBusCommunicatoRR [Update Dec 2011]
  1. #141
    Jan 2006
    Dublin, Ireland
    This is driving me absolutely nuts. I cannot get this working. I keep getting the "IbusCommunicatoRR ComPort Error". I have a Reseler USB iBus Interface running on Com3 and I have a Bluetooth USB Interface running on Com4 (which connects to my External BT-359 GPS). So I have Comport=3 in IbusCommunicatoRR.ini (located in C:\Program Files\RideRunner\Plugins\IBusCommunicatoRR) and then I have Com4 selected within RRCONFIG in the GPS section.
    So what have I missed please? Enclosed is my Debug File
    Code:
    01/12:
    23:10:06.078: Start -- Version: 01/11/2012
    23:10:06.078: OS Type: Windows XP
    23:10:06.078: FileManager: FileMode = Profile
    23:10:06.078: FileManager: mypath = C:\Program Files\RideRunner\
    23:10:06.078: FileManager: ProfilePath = C:\Documents and Settings\Administrator\My Documents\RideRunner\
    23:10:06.266: Start Sequence: Starting Player...
    23:10:06.266: PLAYER: Initialization creating object
    23:10:06.281: PLAYER: Started
    23:10:06.281: PLAYER: WMP Version: WMP (Ver ?.??)
    23:10:06.281: PLAYER: Initialization complete
    23:10:06.281: Start Sequence: Starting Radio Device...
    23:10:06.297: Start Sequence: Starting Serial Devices...
    23:10:16.563: Start Sequence: Starting Mixer...
    23:10:16.563: Master Vol: Master Volume/4
    23:10:16.563: Master Vol reports number of channels =2
    23:10:16.563: GetLineControl Failed: 401
    23:10:16.563: No Treble Support
    23:10:16.563: No Bass Support
    23:10:16.563: No Master ON/OFF
    23:10:16.563: Source: Mixer line #1: Wave=&H1008
    23:10:16.563: Source: Mixer line #2: SW Synth=&H1004
    23:10:16.563: Source: Mixer line #3: CD Player=&H1005
    23:10:16.563: Source: Mixer line #4: Microphone=&H1003
    23:10:16.578: Start Sequence: Starting Speech...
    23:10:16.891: DirectDraw Count: 1 - []
    23:10:16.906: Plugin Manager: loading Global Plugins...
    23:10:17.188: Plugin Manager: Plugin Found: DFXVoice(.NET)
    23:10:17.188: Plugin Manager: Plugin loaded (Global): DFXVoice
    23:10:17.703: Plugin Manager: Plugin Found: GpsLockout
    23:10:17.703: Plugin Manager: Plugin loaded (Global): GpsLockout
    23:10:17.703: Plugin Manager: Plugin Found: IBusCommunicatoRR
    23:10:17.719: Plugin Manager: Plugin loaded (Global): IBusCommunicatoRR
    23:10:17.734: ErrorScr: IbusCommunicatoRR ComPort Error Pls enter a valid ComPort in Configuration File and restart
  2. #142
    Sep 2012
    Germany - Munich
    Do you have the plugin registered?
  3. #143
    Jan 2006
    Dublin, Ireland
    Yes, both of them. Used register.bat for the ibusCommunicatoRR and regsvr32 for the other one
  4. #144
    Sep 2012
    Germany - Munich
    Did you get the message, that the plugin was successful registered?
    Did you copy the mscomm32.ocx to system32 folder?
    Try to start RR without the Bluetooth Plugin.
  5. #145
    Newbie Asterix1965's Avatar
    Jan 2007
    With this plugin can be handled the original radio in RR?
    For example, change frequency and see the name of the station in RR
  6. #146
    Sep 2012
    Germany - Munich
    Quote Originally Posted by Asterix1965 View Post
    Check the ReadMe File. I don't have a MID. But i can remember, there is a VAR to get the Text from MID.
    Sending Commands to simulate your Butttons 1-6 is possible.
  7. #147
    Mar 2009
    Hello! So is it working on window 7 ? win7 SP1? There is some diference wich .net framework ? 3.5 or 4.0 or 4.5 ???? And how about win 8 ?
    Thanx!!!
  8. #148
    Sep 2012
    Germany - Munich
    go back, one or two pages. there is the answer.
  9. #149
    Mar 2009
    Is it possible to make this plunig to work separately from RR ? I mean somehow load dll and use ibus to control not RR but something like media player or winamp ?
  10. #150
    Sep 2012
    Germany - Munich
    ask google for ibuscomm
  1. Build on Mandriva 2010
    By yoshihiro in forum RevFE
    Last Post: 02-23-2010, 06:50 AM
  2. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 03:36 AM
  3. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
