Page 18 of 22 FirstFirst ... 8910111213141516171819202122 LastLast
Results 171 to 180 of 213
Thread: IBusCommunicatoRR [Update Dec 2011]
  1. #171
    Mar 2009
    I'm using 32Bbit windows!!! NOT 64bit! Look 3 section : http://postimage.org/image/uxtcvpj75/
  2. #172
    Sep 2012
    Germany - Munich
    oh sorry.
    is there a wow64 folder also?
  3. #173
    Mar 2009
    No SysWOW64 folder is only in windows 64bit. In 32 bit system and system32 folders.
  4. #174
    Jan 2006
    Dublin, Ireland
    Quote Originally Posted by JanneH0 View Post
    My guess is 2), plugin can't find the .ini
    Looking at the debug file above you running in profile mode with "ProfilePath = C:\Documents and Settings\Administrator\My Documents\RideRunner\" you should have your plugin catalog there not in "C:\Program Files\RideRunner\.."
    Move all files to pluginpath and register it there then it should work.
    /Janne
    Spot on - that worked
    Many thanks
    C
  5. #175
    Nov 2010
    Quote Originally Posted by prohack View Post
    I tried but... I uploaded some screenshots : http://postimage.org/gallery/4i2my142/05b8faff/
    Looks OK, no clue what the problem is.
    Can you post a debug file? that would help.
  6. #176
    Jan 2008
    Heilbronn (Germany)
    no reaction to configured IBUS-Messages
    I use since more than 1 year this plugin. Configured are very few IBUS messages, only Steering Wheel buttons (Next Track, Prev Track and Dial Number Button - as pause)
    Since the beginning on, I have the following problem
    When RR starts, shows IBusCommunicatorRR the BC values, but there is no response to configured Steering Wheel buttons. Once PDC is activated, buttons start to work until i restart RR
    Where could be the problem?
    I'm using Windows 7 32-Bit.
  7. #177
    Sep 2012
    Germany - Munich
    check the other settings, like rts, parse and so on.
  8. #178
    Nov 2010
    Quote Originally Posted by drukhadze View Post
    Hi drukhadze,
    Let's start with debug files.
    Enable debug both in Riderunner and the plugin and post it here. Pls enable both "Debug" and "ExtendedDebug" in the plugin .ini file.
    thx
    /Jan
  9. #179
    Jan 2008
    Heilbronn (Germany)
    Hi drukhadze,
    thx
    /Jan
    Sorry for late response
    Today i could generate logs
    I turned RR's debug, plus IBusCommunicatorRR's debug, ExtendedDebug and IBusLog
    After starting RR I pressed some Steering Wheel buttons - no reaction
    Then I turned PDC on and off
    Again Steering Wheel buttons - now with desired response
    thx
    Dimitri
    P.S.: At the very beginning I've tried with SaveRTSEnable and StartupRTSEnable option, but not helped. I think this options are not relevant for my configuration
    Attached Files Attached Files
  10. #180
    Sep 2012
    Germany - Munich
    I think you should try with System=True.
  1. Build on Mandriva 2010
    By yoshihiro in forum RevFE
    Last Post: 02-23-2010, 06:50 AM
  2. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 03:36 AM
  3. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
