Page 19 of 22 FirstFirst ... 910111213141516171819202122 LastLast
Results 181 to 190 of 213
Thread: IBusCommunicatoRR [Update Dec 2011]
  1. #181
    Jan 2008
    Heilbronn (Germany)
    System=True was helpful. I have not used this option, because in my case, seemed to me to be not useful.
    But i still don't understand, why turning on of PDC changing behavior of plugin
  2. #182
    Sep 2012
    Germany - Munich
    i think pdc sets System=true. becauseof your system was empty, it don't overwrite with false.
  3. #183
    Oct 2010
    Ivry-Sur-Seine (France)
    Hi JanneH0
    I've tested this plugin on my bimmer (e46). The PI well read the navigation informations, the rpm but I don't have informations for the speed, the consumption... I've tested with your skin and mine but same result.
    Do you think there are differents Ibus codes to return informations. Could you get the ibus codes used in your plugin for all yours plugin variables as RRConsumption...
    If in the ini file I put my ibus code and use setVar as RRcommand to set yours variables plugin, do you think that it's a solution?
    Also have you had time to find the source code for this plugin?
  4. #184
    Nov 2010
    Quote Originally Posted by shaken94 View Post
    Hi JanneH0
    Hi Shaken94,
    Not sure about the codes, could be difference between cars.
    Speed & RPM is in the same message so if you get RPM then Ibus message code are correct. Are you using mph or kmh?
    Also the consupmtion data are not availible in all cars.
    You can't set it in .ini and use setVar, the message need to be processed before it goes to RR.
    Here are all internal Ibus messages:
    Code:
    ' Navigation City
    IBusMessageTemplates(151).MsgTpl = "7F23C8A40001XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
    ' Navigation Street
    IBusMessageTemplates(152).MsgTpl = "7F23C8A40002XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
    ' Navigation Latitude & Longitude
    IBusMessageTemplates(153).MsgTpl = "7F14C8A2XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
    ' Navigation Latitude & Longitude request
    IBusMessageTemplates(154).MsgTpl = "C8047FA10012"
    ' PDC Start
    IBusMessageTemplates(160).MsgTpl = "6003D05AE9"
    ' PDC Request
    IBusMessageTemplates(161).MsgTpl = "3F03601B47"
    ' PDC Distance value
    IBusMessageTemplates(162).MsgTpl = "600E3FA0XXXXXXXXXXXXXXXXXXXXXXXX"
    ' Odometer
    IBusMessageTemplates(169).MsgTpl = "800ABF17XXXXXXXXXXXXXXXX"
    ' IKE Speed & RPM
    IBusMessageTemplates(170).MsgTpl = "8005BF18XXXXXX"
    ' IKE Engine & outside temp
    IBusMessageTemplates(171).MsgTpl = "8006BF19XXXXXXXX"
    ' OBC Outside temp
    IBusMessageTemplates(172).MsgTpl = "800CE72403XXXXXXXXXXXXXXXXXX"
    ' OBC Outside temp request
    IBusMessageTemplates(173).MsgTpl = "3F03601B47"
    ' OBC fuel consumption 1
    IBusMessageTemplates(174).MsgTpl = "800FE72404XXXXXXXXXXXXXXXXXXXXXXXX"
    ' OBC fuel consumption 1 request
    IBusMessageTemplates(175).MsgTpl = "3B0580410401FA"
    ' OBC fuel range
    IBusMessageTemplates(176).MsgTpl = "800CE72406XXXXXXXXXXXXXXXXXX"
    ' OBC fuel range request
    IBusMessageTemplates(177).MsgTpl = "3F03601B47"
    ' OBC fuel consumption 2
    IBusMessageTemplates(178).MsgTpl = "800FE72405XXXXXXXXXXXXXXXXXXXXXXXX"
    ' OBC fuel consumption 2 request
    IBusMessageTemplates(179).MsgTpl = "3B0580410501FB"
    ' OBC average speed
    IBusMessageTemplates(180).MsgTpl = "800EE7240AXXXXXXXXXXXXXXXXXXXXXX"
    ' OBC average speed request
    IBusMessageTemplates(181).MsgTpl = "3B0580410A01F4"
    ' OBC Distance
    IBusMessageTemplates(182).MsgTpl = "800DE72407XXXXXXXXXXXXXXXXXXXX"
    ' OBC Arrival
    IBusMessageTemplates(183).MsgTpl = "800CE72408XXXXXXXXXXXXXXXXXX"
    ' CD Changer Status
    IBusMessageTemplates(195).MsgTpl = "180A6839XXXX00XX00XXXXXX"
    ' CD Changer announce
    IBusMessageTemplates(196).MsgTpl = "1804FF0201E0"
    ' Ignition Key Off
    IBusMessageTemplates(200).MsgTpl = "8004BF11002A"
    ' Ignition Key Acc
    IBusMessageTemplates(201).MsgTpl = "8004BF11012B"
    ' Ignition Key On
    IBusMessageTemplates(202).MsgTpl = "8004BF110329"
    ' Ignition Key Start
    IBusMessageTemplates(203).MsgTpl = "8004BF11072D"
    ' Wide Screen Area 0
    IBusMessageTemplates(210).MsgTpl = "68123B236210XXXXXXXXXXXXXXXXXXXXXXXXXXXX"
    ' Wide Screen Area 1
    IBusMessageTemplates(211).MsgTpl = "680B3BA5620141XXXXXXXXXXXX"
    /JanneH0
  5. #185
    Sep 2012
    Germany - Munich
    do you have a IKE High in your Car?
  6. #186
    Sep 2012
    Germany - Munich
    Here are three Flash Gauges to use with IbusCommunicatoRR
  7. #187
    Oct 2010
    Quote Originally Posted by JanneH0 View Post
    /JanneH0
    kmh
    That's what it seems to me that there are different codes in cars.
    Thank you for the codes, I'll try to find my codes Bimma.
  8. #188
    Oct 2010
    Quote Originally Posted by harryberlin View Post
    Here are three Flash Dials to use with IbusCommunicatoRR
    What do you use to create these gauges?
    Do you have a sample script for these gauges?
    I also created gauges using swish max 4 but I struggled to do well. In any case they do not have any of your design level.
  9. #189
    Oct 2010
    I don't know! How to know if my IKE is high or low?
  10. #190
    Nov 2010
    Not sure E46 have "high", here is the difference for E39 http://forums.bimmerforums.com/forum...0#post24739230
  1. Build on Mandriva 2010
    By yoshihiro in forum RevFE
    Last Post: 02-23-2010, 06:50 AM
  2. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 03:36 AM
  3. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
