Page 6 of 22 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 213
Thread: IBusCommunicatoRR [Update Dec 2011]
  1. #51
    Nov 2010
    Quote Originally Posted by Nickyboy View Post
    Hi Enforcer,
    Thanks for your reply. If I take a look in the tab device management under hardware I will see that my GPS antenna is on Comport 3 and my Reseler's usb Ibus interface is on Comport 4. In the IbusCommunicatoRR.ini I have set the Comport to 4. Your last suggestion I am not sure....I not awear that I changed the Port in RRConfig to Comport 4.....do you mean the comport setting under the tab Sensors.... if not which Port do you mean and where can I find this info in RRConfig
    Thanks for your help so far.
    My best regards
    Nick
    Hi Nick,
    Moving forward. I can see that RR finds the plugin and the plugin finds the .ini file
    The error message tells you have a conflict on your comport.
    Pls do this:
    1) make sure it look like this in the IbusCommunicatoRR ini file
    [SPECIAL]; COM port number, Valid range 1 to 16 (Required)
    ComPort=4[/SPECIAL]
    2) check in RRConfig go to GPS-> GPS Port, what number do you have?
    3) You talk about IbusRR earlier, guess you don't use it any longer?
    4) Can you check ibusRR ini file what comport number you used there?
    5) Do you use any other program that using comport?
  2. #52
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Hi Enforcer,
    My best regards
    Nick
    I'm referring to the GPS com port in RRConfig. This should NOT be set to 4 if your iBus is on 4.
  3. #53
    Mar 2011
    Haarlem
    Quote Originally Posted by JanneH0 View Post
    Hi Nick,
    Pls do this:
    ComPort=4[/SPECIAL]
    Hi Janne, I have the plugin running a program in RRConfig was running under the same comport:s stupid mistake!!
    But now I am experiencing some problem with info I'm getting from the Ibus. When the PDC is engaged the skin won't display info recievd from the ibus
    And i think the plugin starts to interfer with the oem PDC itself because the signal is acting strange....
    Also when I use the steeringwheel buttons forward an previous don't work only volume up and down...
    Thanks for al the help I really apreciate it
    Nick
  4. #54
    Mar 2011
    Haarlem
    hi Janne,
    Thanks for al the help so far I really apreciate it !! I found the problem it was in one of the sensors in RRConfig. But now there is another problem, I am experiencing some interference with my OEM PDC. i think the IbusCommunicatoRR is interfering with the OEM PDC, because when I engage the PDC the PDC.skin comes up but doesn't give me the Ibus distance information..... and the OEM PDC signal is acting strange...
    Another problem is that when I press forward or previous nothing happens but when I press volume up or volume down the IbuscommunicatoRR works.
    Hope you can help me
    My because regards
    Nick
  5. #55
    Nov 2010
    What skin do you use? Is it the RRPDC you posted earlier?
    If so then pls read skin command documentation and double check your skin file as most likely where the problem are. I can see you missing several " in the slider style definitions.
    In what way? Can you tell what is strange and what car/model/year you have?
    Have you edited the .ini file to your need?
    I'm not using the steering wheel controls so these are comment out in my .ini (that's the one included in the zip).
  6. #56
    Mar 2011
    Haarlem
    Hi Janne,
    Thanks for the reply. I'm using the RRPDC skin but I have change the settings to this PDC.ini
    RoadRunner Skin
    RRScreen PARKING_SENSOR
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,646,465,36,15,255,120,0,14,"Ericsson GA628","=$IBusCommunicatoRR_PDCRLS$cm","SCROLL-CENTER",
    L02,682,470,30,15,255,120,0,14,"Ericsson GA628","=$IBusCommunicatoRR_PDCRLC$cm","SCROLL-CENTER",
    L03,715,470,30,15,255,120,0,14,"Ericsson GA628","=$IBusCommunicatoRR_PDCRRC$cm","SCROLL-CENTER",
    L04,745,465,36,15,255,120,0,14,"Ericsson GA628","=$IBusCommunicatoRR_PDCRRS$cm","SCROLL-CENTER",
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,650,107,125,272,"PDC_STOP"
    I02,694,514,25,15,"PDC_BUZZER:B"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,630,507,97,86,"PDC_BUZZER",""
    B02,727,507,76,86,"EXIT",""
    /, Y, Back Slider file path
    Y01,"Slider_RLS\RLS*.png"
    Y02,"Slider_RLC\RLC*.png"
    Y03,"Slider_RRC\RRC*.png"
    Y04,"Slider_RRS\RRS*.png"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,644,379,38,78,650,365,36,123,V,01,"",0,"IBusCo mmunicatoRR_PDC_Slider_RLS",""
    S02,682,386,30,78,687,365,21,123,V,02,"",0,"IBusCo mmunicatoRR_PDC_Slider_RLC",""
    S03,713,386,30,78,719,365,21,123,V,03,"",0,"IBusCo mmunicatoRR_PDC_Slider_RRC",""
    S04,743,379,38,78,741,365,36,123,V,04,"",0,"IBusCo mmunicatoRR_PDC_Slider_RRS",""
    /, A, x, y, w, h, color R;RGB, G, B
    A01,19,23,598,558,000,000,000
    /, C, x, y, w, h
    C01,19,23,598,558
    END
    Because I also had seen the errors in the .ini file
    I am riding a BMW E46 325Ci with the year 2001/02 it is the model before the facelift. The PDC system is a OEM PDC system. The sound signal is acting strange in a way that is going faster slower and than faster slower even when there is nothing behind the car.....
    Thanks for the steering wheel advice I am going to have a look.
    Hope you understand now what I mean
    Best regards
  7. #57
    Nov 2010
    Strange, you do mean the "gong" sounds even there is no obstacale?
    Do you have sensors both front and back or back only?
  8. #58
    Mar 2011
    Haarlem
    Yeah i mean the beeping sound is beeping fast even if there are no obstacales....
    I only have only back sensors...
    Thanks for your help.
  9. #59
    Mar 2011
    Haarlem
    Hi Janne,
    My best regards
  10. #60
    Nov 2010
    Hi Janne,
    My best regards
    Sorry, have no clue of what could be wrong. Maybe it's just not compatible with your model/year.
  1. Build on Mandriva 2010
    By yoshihiro in forum RevFE
    Last Post: 02-23-2010, 06:50 AM
  2. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 03:36 AM
  3. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
