Page 9 of 22 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 213
Thread: IBusCommunicatoRR [Update Dec 2011]
  1. #81
    Mar 2011
    Haarlem
    Hi Janne,
    Do you also use the 6.3a driver. Because I think you said that you use the seem HW setup I am using. My HW setup is an D510MO with 2 GB ram.
    Hope to hear from you if you are running a seem HW setup
    Grtz Nick
  2. #82
    Nov 2010
    Quote Originally Posted by Nickyboy View Post
    Hi Janne,
    Grtz Nick
    Hi Nick,
    No I'm using an old Resler RS232 interface bought 6 years ago. No USB -> no drivers needed.
  3. #83
    Mar 2011
    Haarlem
    Hi Janne, but other than the Resler RS232 interface you have the seem HW setup?
    Grtz Nick
  4. #84
    Nov 2010
    Grtz Nick
    Hi Nick,
    Here is what I'm using:
    MB - Gigabyte GA-G510UD with 2G Ram
    HD - Intel Gen1 80g SSD
    Power Supply - M1-ATX
  5. #85
    Mar 2011
    Do you know if it is possible to use this dll with python? I can load it, but I cannot call any of the functions... I'm trying to get it to work with another front end...
  6. #86
  7. #87
    Mar 2011
    Question
    Quote Originally Posted by Enforcer View Post
    No, the DLL will look for a reference to riderunner
    Could you be a little more specific? The DLL methods look for a instance of riderunner?
    Thanks!
  8. #88
    Nov 2010
    Quote Originally Posted by LiquidWater View Post
    Hi LiquidWater,
    It's an RRextension plugin and need Riderunner to work.
    You can read about it here How do I use the Extension Plugin Interface ? or search this forum for more info
  9. #89
    Mar 2007
    I am having problems getting this plugin to work properly with my e46. To start - all I'm trying to do is get my steering buttons to work with RR. The two volume buttons are working, but the other 4 are not.
    I have ran ibus analyzer and it sees all buttons being pressed (and I've compared msgtemplates and they are the same). So, it seems my hardware is setup correctly, but ibuscommunicatorr isn't recognizing buttons being pressed.
    As a troubleshooter, I set all RRcommands to "VOL+" but that also didn't work.
    Anyone have any ideas?
  10. #90
    Mar 2007
    Upon further tweaking - i got the phone button to work. I still cannot get the other three working however. It appears the msgtemplates change between two values. For instance, > press changes between 5004C83B01A6 and 5004683B0106. What does this mean?
  1. Build on Mandriva 2010
    By yoshihiro in forum RevFE
    Last Post: 02-23-2010, 06:50 AM
  2. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 03:36 AM
  3. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
