4.0 is not 2.0!
thats for sure!!!
Thanks for info, I check my installed .net and it is 4.0.
I don't know that the various versions are different and not compatible, this is another MS issue.
So I will install 2.0.
4.0 is not 2.0!
thats for sure!!!
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Using profile mode on Win7 x64 it looks like I need this plugin in both the %install_path%/plugins folder and the %profile%/plugins folder. If I remove the mediaart plugin from either location, the plugin manager no longer picks it up.
Am I doing something wrong? Should I have some files in the profile folder and some others in the install folder?
the plugin goes in the plugins path, rr/plugins.... period
the folder in the profile, is just where it writes the art file...
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
OK -- just got a little confused by the install path. Removed everything and reinstalled to the rr/plugins directory and it works fine now. Thanks.
tested and workspretty good now i can see all the album arts but i got just one question:
Is possible to use the plugin for embed the coverart of non played items? i mean, selecting an item under the music list and then it will show in the box the coverart
i'm using I,510,152,194,194,"COVERART" under music select (non working)
and "ALBUMART" under playing item (working)
NO, its just for the playing item... it only extracts the image when the item plays
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
