Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 54
Thread: RRTrafficcams 2.0 - Traffic flow cameras - Updated 17/11/11
  1. #11
  2. #12
  3. #13
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    wooo hooo
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  4. #14
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Enforcer, I couldn't send attachments on your site for some reason, so I'll send it from here. If you can add these too, I really do appreciate this. Here is the url addresses, I think. You don't have to hurry on this but, I like to use added cams when warmer weather is back. Thanks
    Attached Files Attached Files
  5. #15
    Nov 2009
    cant dl the plug in for appmart of your site
  6. #16
  7. #17
    Nov 2004
    St Louis
    Same here
    Quote Originally Posted by navputer View Post
    For some reason now, I don't have any data coming into RRTC. I have been using DFX5 with no problems but now, when I click on my button (RRTC), it goes to the TrafficCam skin but there is no database information, blank cameras windows, the search feature does not work or hitting GPS. This is weird because it has been working fine.
    I have re-ran the register.bat file as well. I've re-checked my button in DFX5 to make sure it has RRTC.
    RR Jan Rel
    WinXP
    DFX5
    I've got the same problem. Although, I also had a problem during install. Urlmon.dll and wininet.dll were in use so I had to ignore them to complete the install.
    RR Feb rel
    WinXP
    DFX5
    DEBUG.TXT:
    Code:
    2/10/2011|2:23:31 AM|rrTrafficCam|Checking for update to TraffiCamDDL
    2/10/2011|2:23:31 AM|rrTrafficCam|Update Folder =C:\Documents and Settings\USER\Application Data\Elevena Productions\Updates\
    2/10/2011|2:23:31 AM|rrTrafficCam|Program Files =C:\Program Files\Elevena Productions\Traffic Cams\
    2/10/2011|2:23:31 AM|rrTrafficCam|check for C:\Documents and Settings\USER\Application Data\Elevena Productions\Updates\update.ini
    2/10/2011|2:23:31 AM|rrTrafficCam|update ini found
    2/10/2011|2:23:31 AM|rrTrafficCam|Update Filename =
    2/10/2011|2:23:31 AM|rrTrafficCam|leaving
    2/10/2011|2:23:31 AM|rrTrafficCam|Program Files =C:\Program Files\Elevena Productions\ElevenAreg\
    C:\Documents and Settings\USER\Application Data\Elevena Productions\TrafficCams\ERROR.LOG
    Code:
    2/10/2011|1:29:43 AM|TrafficCam|
    2/10/2011|1:29:43 AM|TrafficCam|----------------------------------------------------
    2/10/2011|1:29:43 AM|TrafficCam|Routine : Get Country Codes
    2/10/2011|1:29:43 AM|TrafficCam|Error Number : 53   Error : File not found
    2/10/2011|2:02:22 AM|TrafficCam|
    2/10/2011|2:02:22 AM|TrafficCam|----------------------------------------------------
    2/10/2011|2:02:22 AM|TrafficCam|Routine : Get Country Codes
    2/10/2011|2:02:22 AM|TrafficCam|Error Number : 53   Error : File not found
    2/10/2011|2:12:17 AM|TrafficCam|
    2/10/2011|2:12:17 AM|TrafficCam|----------------------------------------------------
    2/10/2011|2:12:17 AM|TrafficCam|Routine : Get Country Codes
    2/10/2011|2:12:17 AM|TrafficCam|Error Number : 53   Error : File not found
    2/10/2011|2:23:41 AM|TrafficCam|
    2/10/2011|2:23:41 AM|TrafficCam|----------------------------------------------------
    2/10/2011|2:23:41 AM|TrafficCam|Routine : Get Country Codes
    2/10/2011|2:23:41 AM|TrafficCam|Error Number : 53   Error : File not found
  8. #18
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You're missing the trafficams.cdb file.
    This should be in the AppDataPath.
    Depending whether you are running in profile mode or not it should be in
    Non Profile mode
    PF-->RideRunner-->Plugins-->RRTrafficCam
    Profile Mode
    My Documents-->RideRunner-->Plugins-->RRtrafficcam
    I'll attach it, but if that hasn't been copied during the install process god knows what else hasn't
  9. #19
    Nov 2004
    St Louis
    Quote Originally Posted by Enforcer View Post
    Non Profile mode
    Profile Mode
    Still no joy, went back to 1.4.x. Do you have a manual install available?
    I may have asked this before, but, does the standalone and RR plugin version share setting gracefully?
  10. #20
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by GizmoQ View Post
    Because it installs more than one DLL into folders other than RR's no.
    They work totally independent of each other (at the moment)
    Can you zip up the debug files and an error logs in both locations to the email address in the manual.
    Don't post them here
    Cheers
  1. BETA Test....
    By guino in forum Road Runner
    Last Post: 07-26-2005, 09:25 AM
  2. beta 2.0
    By ApoloV in forum AutoTouch
    Last Post: 07-13-2005, 10:39 PM
  3. Car Media app (brand new!) available for beta test! DVD Support!
    By GTC in forum Software & Software Development
    Last Post: 01-27-2004, 06:36 PM
  4. Beta Test 1.6.9 Available
    By CarComp in forum ME Archive
    Last Post: 12-10-2002, 10:59 AM
  5. NNS MP3 Software beta test
    By Ashlawn Kemling in forum Software & Software Development
    Last Post: 08-21-2002, 12:57 PM
