Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 54
Thread: RRTrafficcams 2.0 - Traffic flow cameras - Updated 17/11/11
  1. #41
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Glad you got it working.
    Profile mode is probably better, especially when using Win7.
    However you should still be able to get the plugins running in non-profile mode it would just mean you having full admin rights to the Program Files folder and subfolders.
  2. #42
    May 2011
    Don't know what the deal was there. I do have full admin rights to all of my folders and Win 7 gave no indication otherwise. All I know is that since I used the RR Profile Mode install, all is well. Well, almost. Now Mobilephone.net is giving me fits! Not your issue though, so moving on. Thanks again!
    Update: Well, that was relatively painless. Got Mobilephone.net working. Had to copy the .ini to it's profile folder.
  3. #43
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Thank you E,,
    just noticed the updates i requested,, work great ,,,
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  4. #44
  5. #45
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    campage , var
    search and camera page number var's
  6. #46
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Oh them, forgotten all about doing that.
    Probably added them when you asked and then they were there next time I compiled a newer version.
  7. #47
    Feb 2009
    First off thank you for RRTC and RRFP!
    I'm having a issue with GPS in both programs. When I hit GPS in RRTC it takes me to Hartford, CT (I'm in Vegas). When I hit GPS in RRFP it loads the nearest locations but says I'm 7601.8 miles away from all of them. It gives me the same distance when I input mine or ANY zip code. It does have the correct GPS info listed in the .ini files. Any idea why this is happening or can you gimme a place to starting looking?
    Thanks!
  8. #48
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    RRTC - Not all the cameras in the US have GPS coords, therefore it is possible that the nearest cameras to you that do are in Hartford CT.
    However I think the Hartford ones come up if I have the US DB loaded, which means they are the ones nearest to the 2012 Olympic Stadium. (the default GPS coords in the ini file)
    Now that would indicate that the GPS coords are not getting updated, make sure you have set the COM port for GPS in RRConfig, bear in mind if you have a navigation program running you will need to to a comsplitter running to split the comports so bot RideRunner and your navigation program can have access to the feed.
    RRFP - 7601miles sounds like has calculated the distance between Las Vegas and lat 0, lon 0 in Kilometers. So again either it has not got a GPS coord properly or possibly a conversion of GPS to zipcode or vice versa has not worked.
    Anyway both with or both, set Debug=true in the settings, run RRTC and RRFP and then exit RR. Go to each plugins folder on run their specifi 11adebugcollectors, they should create debug folders, zip these up individually and email to the email address in the PDF manual.
  9. #49
    Feb 2009
    Well RRTC started pulling the correct GPS info. RRFP was still not working. When I booted up yesterday to debug the hard drive failed. So, I'm doing a fresh install now. I'll let you know how it goes.
    Thanks again.
  10. #50
  1. BETA Test....
    By guino in forum Road Runner
    Last Post: 07-26-2005, 09:25 AM
  2. beta 2.0
    By ApoloV in forum AutoTouch
    Last Post: 07-13-2005, 10:39 PM
  3. Car Media app (brand new!) available for beta test! DVD Support!
    By GTC in forum Software & Software Development
    Last Post: 01-27-2004, 06:36 PM
  4. Beta Test 1.6.9 Available
    By CarComp in forum ME Archive
    Last Post: 12-10-2002, 10:59 AM
  5. NNS MP3 Software beta test
    By Ashlawn Kemling in forum Software & Software Development
    Last Post: 08-21-2002, 12:57 PM
