Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 90
Thread: RRTrafficcams 2.0 - Traffic flow cameras - Updated 17/11/11
  1. #51
    Feb 2009
    BOTH are working great now! For some reason RRTC has to be ran a few times for the GPS to get sorted out. I did 2 fresh Win7 installs and both times it would take me to Hartford, CT, but after a few runs it pulls my location. Also both times I had to manually register the dlls with RRTC but RRFP took me to your website.
    Anyways there both good now. THANKS!
  2. #52
    Low Bitrate jparks27's Avatar
    Feb 2006
    Maryland
    Quote Originally Posted by navputer View Post
    For some reason now, I don't have any data coming into RRTC. I have been using DFX5 with no problems but now, when I click on my button (RRTC), it goes to the TrafficCam skin but there is no database information, blank cameras windows, the search feature does not work or hitting GPS. This is weird because it has been working fine.
    I have re-ran the register.bat file as well. I've re-checked my button in DFX5 to make sure it has RRTC.
    RR Jan Rel
    WinXP
    DFX5
    Same issue.. Tried following install guide but nothing matched up.
  3. #53
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Try it in Carwings first.
    [/mitchjs mode]
    However I notice the plugin hasn't registered on my server, so read the bit about registration in the manual.
    Also read the thread for other possible solutions.
    Failing that, read the bit aboutturning debug on and sending me the debug files.
    Cheers
    E.
  4. #54
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Have now updated the plugin to be compatible with the new Dynamic Menus in RR.
    New downloads will have it now.
    I will do an update installer for existing installers in next few days.
  5. #55
    Jan 2006
    Dublin, Ireland
    Hi Enforcer
    I've downloaded v2.0 from your website and I have it running in a Carwings Skin. I can see some US cameras so it is working OK. However, the installation has installed a US database only and all other countries in the list all say "Not Installed"
    How do I get the Ireland database ? I've changed the country code in the ini file to IE but it just sits on the screen saying Database Version IE000
    Also, trafficcam_web2.skin file is missing from the installation. I got the error when I clicked on the country map
  6. #56
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You need to change the DB country in the plugin itself, it should then download the latest one for that country.
    Changing it in the ini may not cause the DB to be downloaded.
    I'll have a look at the trafficcam_web2.skin
  7. #57
    Jan 2006
    Dublin, Ireland
    Thanks for that Enforcer. However, the Plugin Manager displays exactly the same options as depicted in the screen shots contained in your RRTRafficCam User Manual.pdf - so I cannot see anywhere to specify or select the country in it
  8. #58
  9. #59
    Jan 2006
    Dublin, Ireland
    I finally got it. My stupidity.
    However, very few Irish cameras are working and in addition to this, the ones that do work are stuck on a fixed image from 29/08/2012. All the cameras can be found at http://www.dublincity.ie/dublintraffic/
    Can I assist in any way to fix the current database to point at these cameras ? I reckon only the first part of each cameras' url will change so the GPS positions and descriptions would be as they were. The new URL is
    http://www.dublincity.ie/dublintraff...16CameraXX.jpg - where XX = the camera number
  10. #60
    Jan 2006
    Dublin, Ireland
    Hi Enforcer
    I've sent you a PM with the Irish Database re-done - the the XML format you need All of the old cameras have been removed, the new ones added and the links for each one changed to the current cams. Can you let us know when you've re-compiled the database (or whatever it is you need to do with it) ?
  1. BETA Test....
    By guino in forum Road Runner
    Last Post: 07-26-2005, 10:25 AM
  2. beta 2.0
    By ApoloV in forum AutoTouch
    Last Post: 07-13-2005, 11:39 PM
  3. Car Media app (brand new!) available for beta test! DVD Support!
    By GTC in forum Software & Software Development
    Last Post: 01-27-2004, 07:36 PM
  4. Beta Test 1.6.9 Available
    By CarComp in forum ME Archive
    Last Post: 12-10-2002, 11:59 AM
  5. NNS MP3 Software beta test
    By Ashlawn Kemling in forum Software & Software Development
    Last Post: 08-21-2002, 01:57 PM
