Page 12 of 23 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 226
Thread: RRFuelPrices 2.x - Lowest local fuel prices - Updated 05/11/15
  1. #111
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Apart from permissions the only other reason I can think of for not being able to copy the file is that it is already there and in use.
    In which case selecting ignore should work.
  2. #112
    Aug 2007
    let me see if I understood, I just install windows and drivers, road runner, flash player 10, frame net 3.5, then your plugins ...
    may be that when you install everything, before your plugins, these dlls is installed, wininet.dll and urlmon.dll .... so your plugins not installed because it is already installed on the machine?
    I thought your plugin needed to make some modification to these dlls to work or something? let me if I understood, then you need these dlls, if they are already installed on the machine? that you mean? , so , if i put ignoted with both dlls , your plugins working fine ? ..
    maybe any driver or another application need that dlls too ?
    so what do you think so then stop, or try to installed only windows without drivers, road runner, and your plugins and see if installed everything perfect?
  3. #113
    Aug 2007
    enforcer my friend , i make the last test about that dll files , and i format again the pc , install again the windows xp sp3 , alone , without driver , nothings , only windows xp sp3 , and check if windows installa those dll , on windonws/system32 , and yes , winint.dll and urlmon.dll , are installed , so ,maybe is the same what you say me plugin dont install because is ready installed in the pc correct , so i ignored and working fine yours two plugins , gas prices and traffic cameras ..
    so now i have a little problem , the google map of gas stations show perfect now , but when i push the button for close that application , and minimize RR , the google map of gas station dont close , so when i try to open other application what use the google map , show both maps , how i can close you google map gas stations when i finish to see ? i try with "CLOSE" and "ESC" but dont finish the application
    note: i think what find that command in you skincommand documents
    is "rrfp_mapcancel"
    tell me if is correct
  4. #114
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Enforcer,...... I'm getting this error now, also will traffic cams too???
    Then I went to your site to see what may be causing this,....and this is message I get?
    I hope everything is ok on your end.
  5. #115
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Hmm, Host an issue with spoof emails being sent out with one of my emails as a header.
    One of my accounts which isn't set up to send out mails anywhere, hence I know it's a spoof as opposed to a virus on my PC or email client.
    So they suspended the account.
    Everything is now being moved to a new server (yet again).
    Not sure why you had the error messages though. I didn't when I ran both RRTrafficCams and RRFuelprices when I saw this.
  6. #116
    Aug 2007
    hi enforcer my computer today I freeze when you try to open the prices, the plugin has a problem?
    thanks mikee
  7. #117
    May 2007
    Quote Originally Posted by Enforcer View Post
    That sucxx,..... glad to hear that everything will be back to normal though.
    Strange, this error didn't pop-up again, I wonder why/what the error means?
    Well,... as long it's working again, I guess it doesn't really matter.
    Quote Originally Posted by mikeeps2 View Post
    Same here for a moment, But now that stopped too. Seems to work OK now.
    Maybe it's my AV program doing something in the background etc.
    Thanks bud.
  8. #118
    Aug 2007
    Today i uninstall both plugins gas prices and traffic cam because the computer froze when I started RR
    something is happening
  9. #119
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Nope, it's probably RRTrafficcams trying to check for updated DB's and getting hung for some reason when it can't find the correct file on my site.
    It should then check dropbox, but for some reason is not moving on to do that.
    Will need to look at the code to stop this in future.
  10. #120
  1. Le prix des carburants (Fuel Prices for France) - Released 13/11/09
    By Enforcer in forum Software & Software Development
    Last Post: 12-02-2009, 08:58 AM
  2. Replies: 1
    Last Post: 11-18-2009, 08:45 PM
  3. Fuel prices for the UK - AKA Petrol Status Released 09-12-08
    Last Post: 05-17-2009, 07:54 PM
  4. Fuel prices for the US - AKA Gas : Coming soon
    Last Post: 12-09-2008, 11:26 PM
  5. UK Fuel Prices - Standalone version
    By Enforcer in forum Other Cool Stuff
    Last Post: 11-11-2008, 03:05 PM
