Page 13 of 23 FirstFirst ... 345678910111213141516171819202122 ... LastLast
Results 121 to 130 of 226
Thread: RRFuelPrices 2.x - Lowest local fuel prices - Updated 05/11/15
  1. #121
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Enforcer,
    I'm still getting that error popup for fuel and traffic.
    I should of said that I was using Windows 8.1,....sorry about that.
    Then I go back into fuel screen and everything is empty now?
    Also when I go back into traffic, all info is empty too.
    I also tested this in Windows 7 with no errors what so ever, so I'm OK on that machine.
    I'm going to post my log/error files for both traffic and fuel, if this helps.
    I wonder if this is a W8.1 problem.
    This is just weird.
    Thanks.
  2. #122
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Those are only partial debug files.
    run the 11adebugcollector.exe in each of the plugins folder.
    and email to the address in the manual
  3. #123
    Jan 2006
    Dublin, Ireland
    Hi Enforcer
    You have done a great job with both the Traffic Cams and the Fuel Prices plugins. I have just some small problem with the Fuel Prices plugin now. When I run the "Refresh", it takes just over 3mins
    Finding stations in range - about 10s
    Getting Prices - about 2m30s, and that's on a 100mb Internet link !!
    Transferring qualifying stations data - about 20s
    The plugin is set to retrieve the prices for stations within 5 miles of my location. The problem appears to be that it gets the details for EVERY Petrol Station in the WHOLE of Ireland rather than just the area I want. See the debug below where it got details of 1966 stations. The very first ones retrieved are indeed my local stations whereas the last ones in Limerick are over 100 Miles away. The onscreen resulting list does indeed display the correct stations for my local position.
    Code:
    18/03/2014|08:58:21|FuelPrices 1.0.512|setting update finished to False
    18/03/2014|08:58:21|FuelPrices 1.0.512|Set OK
    18/03/2014|08:58:21|FuelPrices 1.0.512|DoThis = updateprices
    18/03/2014|08:58:21|FuelPrices 1.0.512|In IE, what's the range? 5
    18/03/2014|08:58:21|FuelPrices 1.0.512|In GetIEDistances with 1965 no of stations
    18/03/2014|08:58:21|FuelPrices 1.0.512|Sorting by distance
    18/03/2014|08:58:24|FuelPrices 1.0.512|getting prices within = 5
    18/03/2014|08:58:24|FuelPrices 1.0.512|Station Address = Ballinteer Ave Ballinteer
    18/03/2014|08:58:24|FuelPrices 1.0.512|Station Number = 1
    18/03/2014|08:58:24|FuelPrices 1.0.512|1.529 = 1.529
    18/03/2014|08:58:24|FuelPrices 1.0.512|petrol = 1.529
    18/03/2014|08:58:24|FuelPrices 1.0.512|1.469 = 1.469
    18/03/2014|08:58:24|FuelPrices 1.0.512|diesel = 1.469
    18/03/2014|08:58:24|FuelPrices 1.0.512|Station Address = Exit 13 of Ballinteer Avenue Ballinteer
    18/03/2014|08:58:24|FuelPrices 1.0.512|Station Number = 2
    18/03/2014|08:58:24|FuelPrices 1.0.512|1.528 = 1.528
    18/03/2014|08:58:24|FuelPrices 1.0.512|petrol = 1.528
    18/03/2014|08:58:24|FuelPrices 1.0.512|1.468 = 1.468
    18/03/2014|08:58:24|FuelPrices 1.0.512|diesel = 1.468
    18/03/2014|09:00:57|FuelPrices 1.0.512|Station Address = N70 Main St New Chapel Cross
    18/03/2014|09:00:57|FuelPrices 1.0.512|Station Number = 1963
    18/03/2014|09:00:57|FuelPrices 1.0.512|0 = 0
    18/03/2014|09:00:57|FuelPrices 1.0.512|petrol = 99.99
    18/03/2014|09:00:57|FuelPrices 1.0.512|diesel = 99.99
    18/03/2014|09:00:57|FuelPrices 1.0.512|Station Address = Allihies Beara
    18/03/2014|09:00:57|FuelPrices 1.0.512|Station Number = 1964
    18/03/2014|09:00:57|FuelPrices 1.0.512|1.58 = 1.58
    18/03/2014|09:00:57|FuelPrices 1.0.512|petrol = 1.58
    18/03/2014|09:00:57|FuelPrices 1.0.512|1.5 = 1.5
    18/03/2014|09:00:57|FuelPrices 1.0.512|diesel = 1.5
    18/03/2014|09:00:57|FuelPrices 1.0.512|Station Address = Limerick Rd newport
    18/03/2014|09:00:57|FuelPrices 1.0.512|Station Number = 1965
    18/03/2014|09:00:57|FuelPrices 1.0.512|Station Number = 1966
    18/03/2014|09:00:57|FuelPrices 1.0.512|Fuel to use = 0
    18/03/2014|09:00:57|FuelPrices 1.0.512|Sorting by price 0 Stations in range 0
    From the ini file
    Code:
    [General]
    Country=IE
    zipcode=08900
    Fueltype=S98
    range=5
    language=English
    username=
    password=
    navigation=Freedrive
    AppDataPath=C:\Users\championc\Documents\RideRunner\Plugins\RRFuelPrices\
    DLLPath=C:\Users\championc\AppData\Roaming\Elevena Productions\FuelPrices\
    PostCode=Dubli
    precache=False
    Debug=True
    InternetOveride=False
    Update=1
    [igo8]
    kmlpath=C:\Program Files\iGo831_PC\
    [sygic]
    windowname=Sygic Fleet
    keysequence={F1}{ENTER}{RIGHT}{RIGHT}{RIGHT}{DOWN}{ENTER}{ENTER}
    mousex=750
    mousey=519
    delay=5
    [Internal]
    lat=53.2785999970805
    lon=-6.25552023754881
    GPScode=False
    Also, it is annoying that once the "Transferring qualifying stations data" part has completed, it stays on this display requiring you to press Exit rather than this screen disappearing automatically, to show the list of stations.
  4. #124
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by championc View Post
    Hi Enforcer
    Looking at the code, it should not do all the stations unless they are less than the range specified.
    So no idea why it is doing all of them.
    I have added a bit of extra debugging code and a new dll is available. Use the DLL Update command in the plugin settings screen to force an update.
    It shouldn't stay on that screen, it should close it when done.
    Are you using carwings or another skin?
    The command RRFUELPRICESDONE should be sent when the prices have been collected and in the exectbl.ini there should be the following
    Code:
    /****************RRFuelPrices**********************************
    "RRFUELPRICESSEARCHING","menu;fuelprices_loading.skin",fuelprices.skin
    "RRFUELPRICESDONE","ESC",fuelprices_loading.skin
    "RRFPDEBUGCOLLECTING","menu;fuelprices_debugcollect.skin",rrfuelprices_settings.skin
    "RRFPCOLLECTINGDONE","ESC",fuelprices_debugcollect.skin
    The bold one is the important one in this case.
  5. #125
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Can you add PcNavigator 12 support please ?
    It use TCP/IP command as interface (i can give you my plugin code if you want)
    see the remote possibilities !!!
    Attached Files Attached Files
  6. #126
    Jan 2006
    Dublin, Ireland
    Thanks Enforcer
    Things looking much better now. It's updated to ver 2.2.35. It's also EXITing properly now too from the "Transferring ....." screen
  7. #127
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Thanks Enforcer
    That's strange, I didn't change anything.
    Maybe I had made some changes as I was going along and didn't release..
    Oh well. glad it's now working
  8. #128
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by pierrotm777 View Post
    Would it be easier if I sent the commands to your plugin and then you send them onto Navigator, that way only one TCP connection to it is needed.
    or shall I send commands directly to it?
  9. #129
    May 2008
    Bordeaux, France
    Quote Originally Posted by Enforcer View Post
    In fact , with my plugin , you must to use the command:
    PCNAVI_GPSTONAVIGATOR;YOURLAT;YOURLON
    PS:
    If RR GPS use PcNavigator in rr.ini, GPS or PCNAVI, commands load the Pc_Navigator !
  10. #130
    May 2007
    Unhappy
    Enforcer,
    Just wondering if you had the time to take a look at my debug/error files that I sent through your debug email address.
    I think this might have to do with the update DLL file?
    I tried to update RRFP (DLL) through the plugins settings screen running RR with Carwings of course.
    Same error popup.
    I have no problems with W7 32bit, it's just W8.1 64bit for some reason.
    Thanks..........
  1. Le prix des carburants (Fuel Prices for France) - Released 13/11/09
    By Enforcer in forum Software & Software Development
    Last Post: 12-02-2009, 08:58 AM
  2. Replies: 1
    Last Post: 11-18-2009, 08:45 PM
  3. Fuel prices for the UK - AKA Petrol Status Released 09-12-08
    Last Post: 05-17-2009, 07:54 PM
  4. Fuel prices for the US - AKA Gas : Coming soon
    Last Post: 12-09-2008, 11:26 PM
  5. UK Fuel Prices - Standalone version
    By Enforcer in forum Other Cool Stuff
    Last Post: 11-11-2008, 03:05 PM
