Page 14 of 23 FirstFirst ... 4567891011121314151617181920212223 LastLast
Results 131 to 140 of 226
Thread: RRFuelPrices 2.x - Lowest local fuel prices - Updated 05/11/15
  1. #131
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Like I said in my reply email, if it works OK on win7 but not on 8 it's likely to do with the permissions.
    Possibly when you install the plugin or are running RideRunner.
    Both times you need to runas admin, even if you are logged in as an admin.
  2. #132
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Quote Originally Posted by Enforcer View Post
    Easy killer,.... I never received your reply in my mail, never got it for some reason, who knows?
    I even re-replied to see if you did get all my files, still nothing again,.... who knows.
    Well,.... I deleted both RRFP /RRTC and CClean, rebooted, shut off my AV/Firewall and RE-installed again, and as always with admin right click install and full permissions with UAC off.
    Re-registered through settings in the CarWings skin, and now everything is working great!!!
    Sorry about the mix-up man, this should of been a breeze to install, like past installs.
    As always bud, your plugs ROCK!!!
    Cheers.
  3. #133
    Jan 2006
    Dublin, Ireland
    Hi Enforcer
    I have an issue with the time it takes for my Fuelprices plugin to run. Maybe it's something to do with the fact that we do not have postcodes in Ireland but my understanding is that it should then work off GPS positions (and moreso, my Current Position). I think my problem is that my Fuelprices plugin is not getting the current GPS co-ordinates - from wherever it is meant to get them from. It took just under 3 minutes to update and at that, it didn't re-change the prices for my new location. The display was still of prices from my original location. I use iGO8 for my GPS and the GPS co-ordinates are correctly populated to variables GPSLON and GPSLAT. In my Fuelprices.ini file, I added Longitude and Latitude parameters since I thought it was possible that you may have used the same format of variables that you used in Trafficcam. These did appear to help getting the data to be downloaded when at home but at my work location now, it would now be different from the co-ordinates in the ini file. When running the Fuelprices plugin, or when the CarPC is being used away at work, these co-ordinates are not being changed
    Code:
    [Internal]
    lat=53.2785999970805
    lon=-6.25552023754881
    GPScode=True
    [General]
    Country=IE
    zipcode=
    Fueltype=S95
    range=5
    language=english
    username=
    password=
    navigation=iGo8
    AppDataPath=C:\Users\championc\Documents\RideRunner\Plugins\RRFuelPrices\
    DLLPath=C:\Users\championc\AppData\Roaming\Elevena Productions\FuelPrices\
    precache=False
    Debug=True
    InternetOveride=False
    Update=2
    [igo8]
    kmlpath=C:\Program Files\iGo831_PC\content\userdata\poi\
    Slow update
    Code:
    14:03:13.074: Executing: MENU;FUELPRICES_LOADING.skin
    14:03:13.914: Enter Exec: True, fuelprices_loading.skin, , False
    14:03:13.980: Que Exec: True, fuelprices_loading.skin, "ONSCREENCHANGE", False
    14:03:13.992: Que Exec: True, fuelprices_loading.skin, "rrfp_prerefresh", False
    14:03:14.004: Leave Exec: False, fuelprices_loading.skin, rrfp_prerefresh, False
    14:05:55.535: Enter Exec: False, fuelprices_loading.skin, "RRFUELPRICESDONE", False
    14:05:55.539: Que Exec: True, fuelprices_loading.skin, "RRFUELPRICESDONE", False
    Update Debug
    Code:
    06/01/2015|14:03:13|RRFuelPrices 2.2.35|Process Command ONBTNPRESS
    06/01/2015|14:03:13|RRFuelPrices 2.2.35|Process Command PLAYSOUND;C:\Users\BMW\Documents\RideRunner\Skins\Reborn\SOUNDS\BUTTON1.wav
    06/01/2015|14:03:13|RRFuelPrices 2.2.35|Process Command RRFP_REFRESH
    06/01/2015|14:03:13|RRFuelPrices 2.2.35|2 part command
    06/01/2015|14:03:13|RRFuelPrices 2.2.35|Process Command MENU;FUELPRICES_LOADING.skin
    06/01/2015|14:03:13|RRFuelPrices 2.2.35|ReturnSlider = 0
    06/01/2015|14:03:13|RRFuelPrices 2.2.35|Process Command ONSCREENCHANGE
    06/01/2015|14:03:13|RRFuelPrices 2.2.35|Process Command rrfp_prerefresh
    06/01/2015|14:03:14|RRFuelPrices 2.2.35|prerefresh
    06/01/2015|14:03:14|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:14|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:15|RRFuelPrices 2.2.35|ReturnSlider = 21912
    06/01/2015|14:03:15|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:15|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:16|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:16|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:16|RRFuelPrices 2.2.35|ReturnSlider = 22001
    06/01/2015|14:03:17|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:17|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:17|RRFuelPrices 2.2.35|ReturnSlider = 22112
    06/01/2015|14:03:18|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:18|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:18|RRFuelPrices 2.2.35|ReturnSlider = 22223
    06/01/2015|14:03:19|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:19|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:19|RRFuelPrices 2.2.35|ReturnSlider = 22346
    06/01/2015|14:03:20|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:20|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:20|RRFuelPrices 2.2.35|ReturnSlider = 22446
    06/01/2015|14:03:21|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:21|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:21|RRFuelPrices 2.2.35|ReturnSlider = 22579
    06/01/2015|14:03:22|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:22|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:23|RRFuelPrices 2.2.35|ReturnSlider = 22701
    06/01/2015|14:03:23|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:23|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:24|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:03:24|RRFuelPrices 2.2.35|false
    06/01/2015|14:03:24|RRFuelPrices 2.2.35|ReturnSlider = 22824
    06/01/2015|14:04:00|RRFuelPrices 2.2.35|ReturnSlider = 22924
    06/01/2015|14:04:00|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:00|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:01|RRFuelPrices 2.2.35|ReturnSlider = 23024
    06/01/2015|14:04:01|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:01|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:02|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:02|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:02|RRFuelPrices 2.2.35|ReturnSlider = 23168
    06/01/2015|14:04:03|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:03|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:03|RRFuelPrices 2.2.35|ReturnSlider = 23279
    06/01/2015|14:04:04|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:04|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:04|RRFuelPrices 2.2.35|ReturnSlider = 23435
    06/01/2015|14:04:05|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:05|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:05|RRFuelPrices 2.2.35|ReturnSlider = 23557
    06/01/2015|14:04:06|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:06|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:06|RRFuelPrices 2.2.35|ReturnSlider = 23702
    06/01/2015|14:04:07|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:07|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:08|RRFuelPrices 2.2.35|ReturnSlider = 23858
    06/01/2015|14:04:08|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:08|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:09|RRFuelPrices 2.2.35|ReturnSlider = 24002
    06/01/2015|14:04:09|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:09|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:10|RRFuelPrices 2.2.35|ReturnSlider = 24135
    06/01/2015|14:04:10|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:10|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:11|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:11|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:11|RRFuelPrices 2.2.35|ReturnSlider = 24291
    06/01/2015|14:04:12|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:12|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:12|RRFuelPrices 2.2.35|ReturnSlider = 24458
    06/01/2015|14:04:13|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:13|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:13|RRFuelPrices 2.2.35|ReturnSlider = 24614
    06/01/2015|14:04:14|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:14|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:14|RRFuelPrices 2.2.35|ReturnSlider = 24791
    06/01/2015|14:04:15|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:15|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:16|RRFuelPrices 2.2.35|ReturnSlider = 24936
    06/01/2015|14:04:16|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:16|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:17|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:17|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:17|RRFuelPrices 2.2.35|ReturnSlider = 25114
    06/01/2015|14:04:18|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:18|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:18|RRFuelPrices 2.2.35|ReturnSlider = 25292
    06/01/2015|14:04:19|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:19|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:19|RRFuelPrices 2.2.35|ReturnSlider = 25481
    06/01/2015|14:04:20|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:20|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:20|RRFuelPrices 2.2.35|ReturnSlider = 25636
    06/01/2015|14:04:21|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:21|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:21|RRFuelPrices 2.2.35|ReturnSlider = 25825
    06/01/2015|14:04:22|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:22|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:23|RRFuelPrices 2.2.35|ReturnSlider = 26025
    06/01/2015|14:04:23|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:23|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:24|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:24|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:24|RRFuelPrices 2.2.35|ReturnSlider = 26214
    06/01/2015|14:04:25|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:25|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:25|RRFuelPrices 2.2.35|ReturnSlider = 26403
    06/01/2015|14:04:26|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:26|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:26|RRFuelPrices 2.2.35|ReturnSlider = 26570
    06/01/2015|14:04:27|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:27|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:27|RRFuelPrices 2.2.35|ReturnSlider = 26792
    06/01/2015|14:04:28|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:28|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:28|RRFuelPrices 2.2.35|ReturnSlider = 27015
    06/01/2015|14:04:29|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:29|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:30|RRFuelPrices 2.2.35|ReturnSlider = 27237
    06/01/2015|14:04:30|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:30|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:31|RRFuelPrices 2.2.35|ReturnSlider = 27426
    06/01/2015|14:04:31|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:31|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:32|RRFuelPrices 2.2.35|ReturnSlider = 27660
    06/01/2015|14:04:32|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:32|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:33|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:33|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:33|RRFuelPrices 2.2.35|ReturnSlider = 27904
    06/01/2015|14:04:34|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:34|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:34|RRFuelPrices 2.2.35|ReturnSlider = 28138
    06/01/2015|14:04:35|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:35|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:35|RRFuelPrices 2.2.35|ReturnSlider = 28371
    06/01/2015|14:04:36|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:36|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:37|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:37|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:37|RRFuelPrices 2.2.35|ReturnSlider = 28660
    06/01/2015|14:04:38|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:38|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:38|RRFuelPrices 2.2.35|ReturnSlider = 28938
    06/01/2015|14:04:39|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:39|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:39|RRFuelPrices 2.2.35|ReturnSlider = 29216
    06/01/2015|14:04:40|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:40|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:40|RRFuelPrices 2.2.35|ReturnSlider = 29472
    06/01/2015|14:04:41|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:41|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:41|RRFuelPrices 2.2.35|ReturnSlider = 29772
    06/01/2015|14:04:42|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:42|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:42|RRFuelPrices 2.2.35|ReturnSlider = 30094
    06/01/2015|14:04:43|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:43|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:44|RRFuelPrices 2.2.35|ReturnSlider = 30428
    06/01/2015|14:04:44|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:44|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:45|RRFuelPrices 2.2.35|ReturnSlider = 30750
    06/01/2015|14:04:45|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:45|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:46|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:46|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:46|RRFuelPrices 2.2.35|ReturnSlider = 31073
    06/01/2015|14:04:47|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:47|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:47|RRFuelPrices 2.2.35|ReturnSlider = 31462
    06/01/2015|14:04:48|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:48|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:48|RRFuelPrices 2.2.35|ReturnSlider = 31862
    06/01/2015|14:04:49|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:49|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:49|RRFuelPrices 2.2.35|ReturnSlider = 32307
    06/01/2015|14:04:50|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:50|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:51|RRFuelPrices 2.2.35|ReturnSlider = 32674
    06/01/2015|14:04:51|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:51|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:52|RRFuelPrices 2.2.35|ReturnSlider = 33174
    06/01/2015|14:04:52|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:52|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:53|RRFuelPrices 2.2.35|ReturnSlider = 33707
    06/01/2015|14:04:53|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:53|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:53|RRFuelPrices 2.2.35|Instructing update dll to check for update
    06/01/2015|14:04:56|RRFuelPrices 2.2.35|ReturnSlider = 34041
    06/01/2015|14:04:56|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:56|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:56|RRFuelPrices 2.2.35|back from update check
    06/01/2015|14:04:57|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:57|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:58|RRFuelPrices 2.2.35|ReturnSlider = 34152
    06/01/2015|14:04:58|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:58|RRFuelPrices 2.2.35|false
    06/01/2015|14:04:59|RRFuelPrices 2.2.35|ReturnSlider = 34786
    06/01/2015|14:04:59|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:04:59|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:00|RRFuelPrices 2.2.35|ReturnSlider = 35419
    06/01/2015|14:05:00|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:00|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:01|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:01|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:01|RRFuelPrices 2.2.35|ReturnSlider = 36187
    06/01/2015|14:05:02|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:02|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:02|RRFuelPrices 2.2.35|ReturnSlider = 37176
    06/01/2015|14:05:03|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:03|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:03|RRFuelPrices 2.2.35|ReturnSlider = 38354
    06/01/2015|14:05:04|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:04|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:04|RRFuelPrices 2.2.35|ReturnSlider = 40033
    06/01/2015|14:05:05|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:05|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:06|RRFuelPrices 2.2.35|ReturnSlider = 43235
    06/01/2015|14:05:07|RRFuelPrices 2.2.35|ReturnSlider = 43691
    06/01/2015|14:05:07|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:07|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:08|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:08|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:08|RRFuelPrices 2.2.35|ReturnSlider = 43724
    06/01/2015|14:05:09|RRFuelPrices 2.2.35|ReturnSlider = 43746
    06/01/2015|14:05:09|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:09|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:10|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:10|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:10|RRFuelPrices 2.2.35|ReturnSlider = 43780
    06/01/2015|14:05:11|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:11|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:12|RRFuelPrices 2.2.35|ReturnSlider = 43813
    06/01/2015|14:05:12|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:12|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:13|RRFuelPrices 2.2.35|ReturnSlider = 43846
    06/01/2015|14:05:13|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:13|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:14|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:14|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:14|RRFuelPrices 2.2.35|ReturnSlider = 43880
    06/01/2015|14:05:15|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:15|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:16|RRFuelPrices 2.2.35|ReturnSlider = 43913
    06/01/2015|14:05:16|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:16|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:17|RRFuelPrices 2.2.35|ReturnSlider = 43946
    06/01/2015|14:05:17|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:17|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:18|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:18|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:19|RRFuelPrices 2.2.35|ReturnSlider = 43991
    06/01/2015|14:05:19|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:19|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:20|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:20|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:20|RRFuelPrices 2.2.35|ReturnSlider = 44035
    06/01/2015|14:05:21|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:21|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:22|RRFuelPrices 2.2.35|ReturnSlider = 44069
    06/01/2015|14:05:22|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:22|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:23|RRFuelPrices 2.2.35|ReturnSlider = 44102
    06/01/2015|14:05:24|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:24|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:25|RRFuelPrices 2.2.35|ReturnSlider = 44124
    06/01/2015|14:05:25|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:25|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:27|RRFuelPrices 2.2.35|ReturnSlider = 44158
    06/01/2015|14:05:27|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:27|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:28|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:28|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:28|RRFuelPrices 2.2.35|ReturnSlider = 44202
    06/01/2015|14:05:29|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:29|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:30|RRFuelPrices 2.2.35|ReturnSlider = 44235
    06/01/2015|14:05:30|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:30|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:31|RRFuelPrices 2.2.35|ReturnSlider = 44280
    06/01/2015|14:05:31|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:31|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:32|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:32|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:32|RRFuelPrices 2.2.35|ReturnSlider = 44313
    06/01/2015|14:05:33|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:33|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:33|RRFuelPrices 2.2.35|ReturnSlider = 44347
    06/01/2015|14:05:34|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:34|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:35|RRFuelPrices 2.2.35|ReturnSlider = 44391
    06/01/2015|14:05:35|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:35|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:36|RRFuelPrices 2.2.35|ReturnSlider = 44424
    06/01/2015|14:05:36|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:36|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:37|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:37|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:37|RRFuelPrices 2.2.35|ReturnSlider = 44458
    06/01/2015|14:05:38|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:38|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:39|RRFuelPrices 2.2.35|ReturnSlider = 44480
    06/01/2015|14:05:39|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:39|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:40|RRFuelPrices 2.2.35|ReturnSlider = 44513
    06/01/2015|14:05:40|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:40|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:41|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:41|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:41|RRFuelPrices 2.2.35|ReturnSlider = 44558
    06/01/2015|14:05:42|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:42|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:43|RRFuelPrices 2.2.35|ReturnSlider = 44602
    06/01/2015|14:05:43|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:43|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:44|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:44|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:44|RRFuelPrices 2.2.35|ReturnSlider = 44625
    06/01/2015|14:05:45|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:45|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:46|RRFuelPrices 2.2.35|ReturnSlider = 44625
    06/01/2015|14:05:46|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:46|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:47|RRFuelPrices 2.2.35|ReturnSlider = 44625
    06/01/2015|14:05:47|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:47|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:48|RRFuelPrices 2.2.35|ReturnSlider = 44625
    06/01/2015|14:05:48|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:48|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:49|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:49|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:49|RRFuelPrices 2.2.35|ReturnSlider = 44625
    06/01/2015|14:05:50|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:50|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:50|RRFuelPrices 2.2.35|ReturnSlider = 44625
    06/01/2015|14:05:51|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:51|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:51|RRFuelPrices 2.2.35|ReturnSlider = 44625
    06/01/2015|14:05:52|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:52|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:52|RRFuelPrices 2.2.35|ReturnSlider = 44625
    06/01/2015|14:05:53|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:53|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:54|RRFuelPrices 2.2.35|ReturnSlider = 44625
    06/01/2015|14:05:54|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:54|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:55|RRFuelPrices 2.2.35|updatingFinishedTimer
    06/01/2015|14:05:55|RRFuelPrices 2.2.35|false
    06/01/2015|14:05:55|RRFuelPrices 2.2.35|ReturnSlider = 44625
    06/01/2015|14:05:55|RRFuelPrices 2.2.35|true
    06/01/2015|14:05:55|RRFuelPrices 2.2.35|update is finished
  4. #134
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by championc View Post
    Hi Enforcer
    [code]
    [Internal]
    GPScode=True
    Yes, because of the lack of postcodes in Ireland the only way the plugin can work is by GPS coords.
    It should get the Coords from RideRunner, so make sure that the RRConfig Navigation ComPort is set to a valid GPS device. you will need to run a com port splitter if you are also connecting a Navigation program to the same GPS device.
    I'll need to check the code but I'm sure the plugin polls RR for the current Lat and Lon before trying to update the prices.
    Also because the Ireland search is based on a database the plugin has to first check for stations in the database within the radius set, then go to each one of those stations urls to get the prices. Therefore the bigger the range, the more stations to search (especially in a major town or city) and the more web page requests.
    And then the more stations the longer the sort will take afterwards.
  5. #135
    Jan 2006
    Dublin, Ireland
    Thanks Enforcer
    I correctly have a COM port splitter running, so I have the GPS status and co-ordinates working perfectly in RR while I'm also successfully using iGO8.
    I have been experimenting between using a radius of between 2 and 5 miles. Every time, it takes about 3 minutes to complete the action, so it appears to be looking at every single petrol station in the whole of Ireland.
    However, I just looked at the files more closely. I see the FuelPrices.IEX file is 306kb whereas the Stations.IE is only 5kb. It therefore seems possible that rather than using a radius of 5 miles, maybe it's doing 50 miles ???
    I've attached a ZIP containing my Stations.IE file. Maybe you can understand it and see what exactly it is using and downloading.
    Attached Files Attached Files
  6. #136
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    3 minutes doesn't sound unusual for those distances. The first time to connect to a website can take a bit of time. Once a connection has been made subsequent requests tend to be quicker. If it was doing the whole of Ireland it would probably take anything from 10 minutes to 30 mins.
    FuelPrices.IEX is the DB of all the stations, Stations.IE is just the details of the cheapest 20 stations with the given parameters.
    Only the cheapest 20 are saved to file.
    The file(s) that will help me work out what is happening at the ones which can be collected by the debugcollector.exe in the Plugins folder. Follow the instructions in the PDF manual on how to collect and send me the necessary files. DO NOT post the debugs in the thread.
    Cheers
    E.
    *Edit
    BTW you need to press GPS and not Refresh to get the updated GPS cords.
  7. #137
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Enforcer,
    I am not able to get FP or RRTC to pull my GPS data to find the closest locations. Since I have moved to Win7 (was working fine on XP), I am using GPS2City and I see the information there but it will not update in the plugins. Also, do I need to store the zip.dat file in a different location? I have it in root of RR.
    What could I be missing?
    RR 8/1
    Win7 32bit
    DFX 5.12
    Gee
  8. #138
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    If i don't say a jock, with the nes GPS2City version the Zips.dat file is into the GPS2City plugin folder not into the RideRunner .
  9. #139
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by navputer View Post
    Enforcer,
    RR 8/1
    Win7 32bit
    DFX 5.12
    My plugins don't use GPS2City not the zip.dat file.
    As usual, debug files would be good. ;-)
  10. #140
    Jan 2007
    DFW Area
    FP Debug File
    Ok...here is my FP debug files.
    Thanks for the help.
    Gee
  1. Le prix des carburants (Fuel Prices for France) - Released 13/11/09
    By Enforcer in forum Software & Software Development
    Last Post: 12-02-2009, 08:58 AM
  2. Replies: 1
    Last Post: 11-18-2009, 08:45 PM
  3. Fuel prices for the UK - AKA Petrol Status Released 09-12-08
    Last Post: 05-17-2009, 07:54 PM
  4. Fuel prices for the US - AKA Gas : Coming soon
    Last Post: 12-09-2008, 11:26 PM
  5. UK Fuel Prices - Standalone version
    By Enforcer in forum Other Cool Stuff
    Last Post: 11-11-2008, 03:05 PM
