Page 3 of 23 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 226
Thread: RRFuelPrices 2.x - Lowest local fuel prices - Updated 05/11/15
  1. #21
  2. #22
    Oct 2010
    Ivry-Sur-Seine (France)
    I have a problem with your plugin, it don't display the adress of the station but a html code.
    screen copy:
  3. #23
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Yeah, I noticed that while working on the CF version last night
    Looks like there has been a small change on the website.
    Will look into it.
    Cheers E.
  4. #24
    Oct 2010
    Ok it work great now.
    could you add a command mnavigationset (rrfp_navigationset) to load as a menu instead of a fullscreen.
    Also is it possible to implement debug, precache and internetoveride as Indicators which will return true or false and their corresponding buttons that change the ini file directly, not by pressing the Apply button.
    Thanx
  5. #25
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by shaken94 View Post
    Already there, you just need to do a smaller skin for it.
    Thanx
    TBH the only one that might be useful to do on the fly is debug.
    Precache only makes a difference on restarting
    internetoveride would only be used in extreme circumstances as it could cause RR to hang up badly, so I think some thought is needed before changing that setting.
    May I ask why to want them as immediate toggles?
    *Edit
    BTW can I suggest you got to Control Panal -->Display-->Appearance-->Effects
    And check 'use the following method to smooth edges of screen fonts'. (Obviously you will need to find the French equivalent)
    It will smooth out those fonts nicely (except for those used in iLists)
  6. #26
    Oct 2010
    I use a live display of indicators. Ie when I click on the button displaying the indicator changes immediately. It's just for effect
  7. #27
    Oct 2010
    Ok now i use correctly the menu (before i use "mcountry" as command button, now "rrfp_mcountry"; It's strange but it work very well !!! lol)
    Otherwise when i use this code in rrfuelprices_settings.skin the indicator image don't change (i change the value of debug directly in fuelprices.ini not with the button command)
    B06,622,141,136,35,"rrfp_debug",
    L06,622,141,136,35,255,255,255,14,"Digiface","=Deb ug :","RIGHT",
    I06,761,141,28,35,"rrfp_debug"
    if i use the byvar command in the I06 i have the same result. (I06,761,141,28,35,"BYVAR;rrfp_debug;Indicators\pa ram_off.png<<Indicators\param_on.png")
    Here a screenshot of my rrfuelprices_settings.skin (the indicator is the red led)
  8. #28
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Let me see if I understand you.
    Do you want the Indicators to just change their display state when they are clicked without pressing apply or do you want them also to change the plugin setting immediately without pressing apply.
    Because if it's the former that should already happen you just need the correct images in the skin and the following lines of code for each indicator
    IMG01,761,141,28,350,"false.png",empty
    IMG04,761,141,28,35,"true.png",On
  9. #29
    Oct 2010
    I prefer they change the plugin setting immediatly without pressing apply but I could be content with your plugin as it is currently.
    Yes I saw these lines of code in the skin preview (CARWINGS and DFX5) and got the same result. When I change the parameter value in the INI file the image does not change. Of course I change the value in having RideRunner stop.
  10. #30
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Some teaser shots of forth coming countries, is yours one of them?
    or can you name them?
  1. Le prix des carburants (Fuel Prices for France) - Released 13/11/09
    By Enforcer in forum Software & Software Development
    Last Post: 12-02-2009, 08:58 AM
  2. Replies: 1
    Last Post: 11-18-2009, 08:45 PM
  3. Fuel prices for the UK - AKA Petrol Status Released 09-12-08
    Last Post: 05-17-2009, 07:54 PM
  4. Fuel prices for the US - AKA Gas : Coming soon
    Last Post: 12-09-2008, 11:26 PM
  5. UK Fuel Prices - Standalone version
    By Enforcer in forum Other Cool Stuff
    Last Post: 11-11-2008, 03:05 PM
