If it was working and it's not now, it could be the site.
run the 11adebugcollector and email the files, plus the webdown.txt file as well.
Anyone having problems with "Fuel Prices"?
I'm all up to date on everything RR/RRFP etc.
And yes, err,..... I did test with "Carwings"![]()
The site I use for converting your zipcode to GPS coords is throwing an error.
I'm checking why now, buit in the meantime if you set the range to 0 it should show the stations
That did it!, I wonder why my zip throws this error?That's weird. Thanks E.
No, it's not just your zip. When I said your zipcode I meant US as opposed to the other countries.
I have found the change the site has made and recoded the worker DLL.
Should update automatically over the next few times you run FuelPrices (nb fuelprices needs to be run and RR left running for at least 10 mins after that.) and then on next restart it should have updated, although it may not happen until tomorrow.
Actually, you may get a non silent upgrade.
I have just done a main package upgrade which will also include the new worker dll, plus some under the hood tweaks.
Now which countries are about to make it into RRFuelprices
