Page 10 of 13 FirstFirst 12345678910111213 LastLast
Results 91 to 100 of 122
Like Tree1Likes
Thread: .NET Wifi Manager [v1.0] [2/13/2011]
  1. #91
    MySQL Error
    Oct 2004
    not really paying attention
    if the .dll is unsigned, /codebase cannot be used
    so... if the installer uses /codebase, its expecting a strong-named dll
    and a released .dll should be strong-named! to prevent tamper or hook by virius
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #92
    Feb 2011
    what really i have not undestand is why if installed as 1st the plugin works (same os, same net 3.5 + 4 and same vc 2005, 2008 and 2010) else if not installed as 1st the plugin is not recognized
    i mean in my situation is possible to choose only one plugin (USBmon or Wifi)
    just wondering if someone is using both the plugins
  3. #93
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Red face Xp sp3 & 3.5 SP1 .NET
    I try to use this plugin on my xp sp3 .
    I have reinstalled the 3.5 sp1 .net Framework but i have an error when i try to register the plugin and the plugin isn't loaded !
    This is my debug file !
    Code:
    11/30:
    17:33:40,063: Start -- Version: 01/11/2012
    17:33:40,063: OS Type: Windows XP
    17:33:40,063: FileManager: FileMode = Legacy
    17:33:40,063: FileManager: mypath = D:\Program Files\Ride Runner\
    17:33:40,063: FileManager: ProfilePath = D:\Documents and Settings\pierrot\Mes documents\RideRunner\
    17:33:40,109: Start Sequence: Starting Player...
    17:33:40,109: PLAYER: Initialization creating object
    17:33:41,359: PLAYER: Started
    17:33:41,359: PLAYER: Winamp Version:
    17:33:41,359: PLAYER: Initialization complete
    17:33:41,359: Start Sequence: Starting Radio Device...
    17:33:41,359: Start Sequence: Starting Serial Devices...
    17:33:41,359: Start Sequence: Starting Mixer...
    17:33:41,359: Master Vol: Volume principal/4
    17:33:41,359: Master Vol reports number of channels =2
    17:33:41,359: GetLineControl Failed: 401
    17:33:41,359: No Treble Support
    17:33:41,359: No Bass Support
    17:33:41,359: No Master ON/OFF
    17:33:41,359: Source: Mixer line #1: Sons wave=&H1008
    17:33:41,359: Source: Mixer line #2: Synthé. SW=&H1004
    17:33:41,359: Source: Mixer line #3: Front=&H100A
    17:33:41,359: No Mute for Source
    17:33:41,359: Source: Mixer line #4: Rear=&H100A
    17:33:41,359: Source: Mixer line #5: Subwoofer=&H100A
    17:33:41,359: Source: Mixer line #6: Center=&H100A
    17:33:41,359: Source: Mixer line #7: Side=&H100A
    17:33:41,359: Source: Mixer line #8: SPDIF=&H1001
    17:33:41,359: Can't Open Source
    17:33:41,359: Source: Mixer line #9: Front Green In=&H100A
    17:33:41,359: Source: Mixer line #10: Rear Blue In=&H100A
    17:33:41,375: Source: Mixer line #11: Front Pink In=&H100A
    17:33:41,375: Source: Mixer line #12: Rear Pink In=&H100A
    17:33:41,375: Source: Mixer line #13: Rear Grey In=&H100A
    17:33:41,375: Source: Mixer line #14: Rear Orange In=&H100A
    17:33:41,375: Source: Mixer line #15: Rear Black In=&H100A
    17:33:41,375: Source: Mixer line #16: Rear Green In=&H100A
    17:33:41,375: Start Sequence: Starting Speech...
    17:33:41,438: DirectDraw Count: 1 - []
    17:33:41,453: Plugin Manager: loading Global Plugins...
    17:33:41,703: Plugin Manager: Plugin Found: RRWifiMan_NET(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
    17:33:41,719: Plugin Manager: Plugin Found: SkinTool
    17:33:41,719: Plugin Manager: Plugin loaded (Global): SkinTool
    17:33:41,719: Plugin Manager: loading Global Plugins Completed.
    17:33:41,719: LoadSkin: D:\Program Files\Ride Runner\Skins\Carwings_Dynamic_RRMenuItem\
    17:33:41,797: Plugin Manager: loading SkinDir Plugins...
    17:33:41,797: Plugin Manager: loading SkinDir Plugins Completed.
    17:33:41,797: INFO: LoadKVPFromFile() - Reading KVP data from D:\Program Files\Ride Runner\Skins\Carwings_Dynamic_RRMenuItem\Menu.ini
    17:33:42,438: Global Hotkey: Successfully registered keycode:2112
    17:33:42,438: PLAYER: Restored rrpl.m3u8
    17:33:42,438: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    17:33:42,469: Enter Exec: Faux, menu.skin, , Faux
    17:33:42,469: Que Exec: Vrai, menu.skin, "ONSTART", Faux
    17:33:42,469: Que Exec: Vrai, menu.skin, "ONLINE", Faux
    17:33:42,469: Que Exec: Vrai, menu.skin, "ONSKINSTART", Faux
    17:33:42,469: Que Exec: Vrai, menu.skin, "ONPLAYERREADY", Faux
    17:33:42,469: Que Exec: Vrai, menu.skin, "ONSOURCECHANGE", Faux
    17:33:42,469: Leave Exec: Faux, menu.skin, ONSOURCECHANGE, Faux
    17:33:52,016: Enter Exec: Faux, menu.skin, "ONBTNPRESS||RRMenuNext", Faux
    17:33:52,016: Que Exec: Vrai, menu.skin, "ONBTNPRESS||RRMenuNext", Faux
    17:33:52,016: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    17:33:52,016: Executing: PlaySound;D:\Program Files\Ride Runner\Skins\Carwings_Dynamic_RRMenuItem\Sounds\button1.wav
    17:33:52,016: Que Exec: Vrai, menu.skin, "RRMenuNext", Faux
    17:33:52,016: Executing: RRMenuNext
    17:33:52,016: Que Exec: Vrai, menu.skin, "load;menu2.skin", Faux
    17:33:52,016: Executing: load;menu2.skin
    17:33:52,141: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    17:33:52,141: INFO: LoadResume() - Reading resume data from D:\Program Files\Ride Runner\resume.ini
    17:33:52,359: Que Exec: Vrai, menu2.skin, "ONSCREENCHANGE", Faux
    17:33:52,359: Leave Exec: Faux, menu2.skin, ONSCREENCHANGE, Faux
    17:33:53,047: Enter Exec: Faux, menu2.skin, "ONBTNPRESS||RRMenuItem;1", Faux
    17:33:53,047: Que Exec: Vrai, menu2.skin, "ONBTNPRESS||RRMenuItem;1", Faux
    17:33:53,047: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    17:33:53,047: Executing: PlaySound;D:\Program Files\Ride Runner\Skins\Carwings_Dynamic_RRMenuItem\Sounds\button1.wav
    17:33:53,047: Que Exec: Vrai, menu2.skin, "RRMenuItem;1", Faux
    17:33:53,047: Executing: RRMenuItem;1
    17:33:53,047: Que Exec: Vrai, menu2.skin, "RRPLUGINMGR", Faux
    17:33:53,047: Executing: RRPLUGINMGR
    17:33:53,359: Que Exec: Vrai, pluginmgr.skin, "ONSCREENCHANGE", Faux
    17:33:53,359: Leave Exec: Faux, pluginmgr.skin, ONSCREENCHANGE, Faux
    17:33:54,563: Enter Exec: Faux, pluginmgr.skin, "ONBTNPRESS||ESC", Faux
    17:33:54,563: Que Exec: Vrai, pluginmgr.skin, "ONBTNPRESS||ESC", Faux
    17:33:54,563: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    17:33:54,563: Executing: PlaySound;D:\Program Files\Ride Runner\Skins\Carwings_Dynamic_RRMenuItem\Sounds\button1.wav
    17:33:54,563: Que Exec: Vrai, pluginmgr.skin, "ESC", Faux
    17:33:54,563: Executing: ESC
    17:33:54,563: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    17:33:54,563: INFO: LoadResume() - Reading resume data from D:\Program Files\Ride Runner\resume.ini
    17:33:55,016: Enter Exec: Vrai, menu2.skin, "ONBTNPRESS||ESC", Faux
    17:33:55,016: Queued: "ONBTNPRESS||ESC"
    17:33:55,031: Que Exec: Vrai, menu2.skin, "ONSCREENCHANGE", Faux
    17:33:55,031: Que Exec: Vrai, menu2.skin, "ONBTNPRESS||ESC", Faux
    17:33:55,031: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    17:33:55,031: Executing: PlaySound;D:\Program Files\Ride Runner\Skins\Carwings_Dynamic_RRMenuItem\Sounds\button1.wav
    17:33:55,031: Que Exec: Vrai, menu2.skin, "ESC", Faux
    17:33:55,031: Executing: ESC
    17:33:55,031: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    17:33:55,031: INFO: LoadResume() - Reading resume data from D:\Program Files\Ride Runner\resume.ini
    17:33:55,203: Que Exec: Vrai, menu.skin, "ONSCREENCHANGE", Faux
    17:33:55,203: Leave Exec: Faux, menu.skin, ONSCREENCHANGE, Faux
    17:33:55,719: Enter Exec: Faux, menu.skin, "ONBTNPRESS||EXIT", Faux
    17:33:55,719: Que Exec: Vrai, menu.skin, "ONBTNPRESS||EXIT", Faux
    17:33:55,719: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    17:33:55,719: Executing: PlaySound;D:\Program Files\Ride Runner\Skins\Carwings_Dynamic_RRMenuItem\Sounds\button1.wav
    17:33:55,719: Que Exec: Vrai, menu.skin, "EXIT", Faux
    17:33:55,719: Executing: EXIT
    17:33:55,719: Enter Exec: Faux, menu.skin, "ONEXIT", Faux
    17:33:55,719: Que Exec: Vrai, menu.skin, "ONEXIT", Faux
    17:33:55,719: Leave Exec: Faux, menu.skin, ONEXIT, Faux
    17:33:55,719: Shutdown: (1)
    17:33:55,891: Un-Mounting ISO Files
    17:33:55,891: Shutdown: (2)
    17:33:55,891: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    17:33:55,906: INFO: LoadResume() - Reading resume data from D:\Program Files\Ride Runner\resume.ini
    17:33:55,906: Shutdown: (3)
    17:33:55,906: Shutdown: (4)
    17:33:55,906: INFO: SaveResume() - Saving resume data to D:\Program Files\Ride Runner\resume.ini
    17:33:55,922: Plugin Manager: Warning Plugin skintool does not support Terminate Method
    17:33:55,922: Plugin Manager: ALL Plugins unloaded.
    17:33:56,078: Shutdown: (5)
    17:33:56,078: Player is running
    17:33:56,844: Shutdown: (6)
    17:33:56,844: Shutdown: (7)
    17:33:56,844: OSUnloadMode: 1
    17:33:56,844: Global Hotkey: All keys unregistered
    An idea please ?
  4. #94
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    using one of those nlite'ed xp version?, havent touch this in ages, but, didnt i sent you the source for this?
  5. #95
    May 2008
    Bordeaux, France
    Quote Originally Posted by EL CAMINO View Post
    Sorry but i don't understand what you say me !
  6. #96
    May 2008
    Bordeaux, France
    I have found an issue into my Wifiman settings, my SSID list show only the SSID nolocked!
    It was because i had these lines into my Exectbl.ini file:
    "LockNets","SetVar;WifiMan_Locked;True||SaveToIni;WifiMan_Locked;True"
    "NolockNets","SetVar;WifiMan_Locked;False||SaveToIni;WifiMan_Locked;False"
    that must to be replaced by:
    "LockNets","SetVar;WifiMan_Locked;1||SaveToIni;WifiMan_Locked;1"
    "NolockNets","SetVar;WifiMan_Locked;0||SaveToIni;WifiMan_Locked;0"
    Now i can to see all my hotspots (but only on vista and more)
  7. #97
    EL CAMINO's Avatar
    Jul 2005
    Quote Originally Posted by pierrotm777 View Post
    im asking if you are using nlite to strip down xp, the pi needs wlanapi comes on xp sp3 and above, on xp the api is limited dont remember if i disable xp support, not sure, the other thing i was asking is, i remember sending you the source for this plugin, have a go, info is on msdn on how to use it.
  8. #98
    May 2008
    Bordeaux, France
    Ho, ok, i have a special xp sp3 in fact :-( and yes i have again your VB6 source !!!
  9. #99
    May 2008
    Bordeaux, France
    Why the command wifiman_pr_export;C:\ don't run for me please ?
    Where the profiles are saved by default please ?
  10. #100
    EL CAMINO's Avatar
    Jul 2005
    taken from skin commands.
    "wifiman_pr_export" ;saves profiles info to an xml file. 1 parameter needed, folder path, to save xml file.
    i.e. "wifiman_pr_export;C:\" saves selected profile from profiles list.
    if selected profile name is MyHomeNet, C:\MyHomeNet.xml is created.
    this was tested on windows 7 32bit
  1. New Wifi Manager [Beta Ver. 1.2.0]
    By EL CAMINO in forum RR Plugins No Longer Supported
    Last Post: 02-03-2011, 01:10 AM
  2. Ford Product Design Manager Chris Demeniuk - CES 2011
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 01-13-2011, 09:12 PM
  3. Updates to WIFI Manager
    By EL CAMINO in forum Auto App Mart
    Last Post: 10-14-2010, 03:05 PM
  4. WiFi Manager
    By ssteger in forum VaultWiki
    Last Post: 10-21-2009, 03:49 PM
  5. CF wifi manager
    By moto_noob in forum Centrafuse
    Last Post: 04-05-2008, 01:41 AM
