I have these framework installed :
But i can't register on XP sp3
Printable View
like bo and carputer said, after you run the installer go to .\RideRunner\Plugins\RRWifiMan_NET\
and you should see "RunMeFirst.bat", "Regasm.exe", "RRWifiMan_NET.dll", etc., execute "RunMeFirst" and you should see how a "RRWifiMan_NET.tlb" file is created, and you should be able to use the PI after that.
It's exactly that i have done on my xp sp3 but without succes.
On vista , that run very well:happy:
uninstall the rrwifiman.net you have and re-download , the installer has been updated
same issue for me on my xp sp3 .
With this new installer , i haven't a regasm.exe and readme1st.cmd files
This is my debug file for xp sp3
looking at your debug you have alot not working ,, i even see 3 bass pi's there ,, for a start i would say clear all PI's from rr root clean you regisrty of any rr dll found , and start by adding your pi's back 1 by 1 ,, you have so much going on , onskin start i think you have a conflict somewhere ,
I am running Win 7 and when I press the Connect/Disconnect button it is disconnecting/connecting my wireless network adaptor. Any ideas as to what might be going on. I am using the Mar release of RideRunner. Thanks
we need to know one more thing, skin?, and please, atach a debug log. OR, use skin tool and see what command is executed when you hit that connect/disconnect button.
