Page 5 of 13 FirstFirst 12345678910111213 LastLast
Results 41 to 50 of 122
Like Tree1Likes
Thread: .NET Wifi Manager [v1.0] [2/13/2011]
  1. #41
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    if the skin is the problem, is just a matter of fixing the skin, is a simple command issue, this PI is compatible with all RR skin's. using the latest RR you wont have any issues.
    not sure if theres another PI like this.
  2. #42
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Having a few issues with this version.
    XP PRO SP3
    RRWifiMan 1.6 works fine
    however RRWifiMan_net seems to run, but has issues getting a complete list of wifi networks and fails to send any onwificonnected command.
    Also where are the settings kept and how do you pull up a settings screen.
    First image RRWifiman 1.6
    Second Image RRWifiman_net
    Third image Windows list of wifi networks.
  3. #43
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    theres a setting to allow you to see all connections
    wifiman_locked ,
    0 = Unlocked networks only
    1 = inc locked networks
    also
    wifiman_nets ,, this allows you to set whay type of connection to search for ..
    0 = infrastructure only
    1 = ad hoc networks
    2 = ad hoc & hidden networks
    as far as i'm aware there is no settings scr,, don't rememeber doing 1 lol...
    but all explained in skin cmds,,, all settings are changealbe on runtime
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  4. #44
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Before mitch added the plugin settings to the plugin manager I used to be able to pull up a settings screen I had done for my skins. (actually I'll try making a button to bring up me settings screen again.)
    I think there needs to be settings screen coded into the plugin.
    But where are the settings stored?
  5. #45
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The newer Settings screen for a PI is just a screen called "<pluginname>_Settings.skin" and the btn cmd in the Pluginmgr.skin to open that is "pluginmgr;settings;$DLPLUGINNAME$", opens up what ever plugin's setting screen selected in the list. The load/set/save of settings as always are up to you...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #46
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by Enforcer View Post
    rr.ini or kin.ini up to you
  7. #47
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i have found this not to be the case for all pi's in the list ,, i added XXXX_settings.skin for 4 pi's in list only 2 worked,,, the other 2 i had to code within the pi code to work
  8. #48
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Did the name of the skin exactly match the name of the PI's? Which ones did you find not to be that case...I think just a improper named skin file is the issue.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #49
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by carputer1 View Post
    That does not make sense, how they be just anywhere?
    Plugins now have a section for settings and that gets called from the plugin managers settings button, which is fine as my new plugins have this.
    However if there is no settings section in the DLL then the command "load;<pluginname>_settings.skin" is sent.
    However id the plugin has the Settings Subroutine but is left blank the "load;<pluginname>_settings.skin" command is not sent.
    Now seeing as the examples now have the settings subroutine in by default (which is left blank) if the plugin coder has left it blank the back/default "load;<pluginname>_settings.skin" does not get sent.
    Which is now what is happening here.
    It should now be mandatory for developers to have settings screens for their plugins rather than editing ini/xml files.
  10. #50
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    main 2 were RRwifiman_net and my own Genesis ,,, as for the settings of RRwifi ,,, i did'nt code it ,,, thats how it is ,, i use skin.ini to save settings ,, RRwifi has not been touched since its release which was well before the PI manager change ,, ,,, i have only just started to use this function in my Gen dll,,, was not going to use it at 1st ,, thought it would confuse the user , how to get to settings scr,,, but slowly changeing all pi's i support to use this function ,,, like my Updater uses Genesis_About.skin now and settings are Genesis_settings.skin ,, but thses cmds are hard coded ,, which as far as i'm aware should not be the case ,,, should just read pi name and load skin file if present ...
  1. New Wifi Manager [Beta Ver. 1.2.0]
    By EL CAMINO in forum RR Plugins No Longer Supported
    Last Post: 02-03-2011, 01:10 AM
  2. Ford Product Design Manager Chris Demeniuk - CES 2011
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 01-13-2011, 09:12 PM
  3. Updates to WIFI Manager
    By EL CAMINO in forum Auto App Mart
    Last Post: 10-14-2010, 03:05 PM
  4. WiFi Manager
    By ssteger in forum VaultWiki
    Last Post: 10-21-2009, 03:49 PM
  5. CF wifi manager
    By moto_noob in forum Centrafuse
    Last Post: 04-05-2008, 01:41 AM
