1 Attachment(s)
FFDShow EQ Plugin - Windows Media Player
this has been updated 2/19/2011
if using windows 7, Windows 7's wmp is not going to use DirectShow to playback audio/video, it uses Media Foundations, or DMOs
you can disable(hack) some of these with "Win7DSFilterTweaker_4_0"
I cant recomend this, but it is possible
FFDShow Audio Equalizer for Ride Runner
Description:
This plugin is meant to provide the means to control FFDShow's audio equalizer from within Ride Runner.
(Provides a 10-Band Equalizer without pre-amp)
Purpose:
When using the Windows Media Player or another DirectShow based Player with Ride Runner, you can have
FFDShow control the playback of audio in which case you will be allowd to use it's equalizer from within
Ride Runner. When using other players, you can still use this plugin to add a video equalizer when
playing videos using the Built-in player, MPC or any other Video/DVD player that works with FFDShow.
Requirements:
-FFDShow the latest works use x86!
-Ride Runner
Install considerations:
If you use WMPRR (Windows Media Player), this plugin will automatically override the standard sliders in
Ride Runner so you can use the FFDShow equalizer without modifying the skin. If you use Winamp, FMOD or any
player which already includes an equalizer, then this plugin will override the standard sliders ONLY WHEN
playing VIDEOS. Regardless of this override, there are direct codes which always control FFDShowEQ.
