Results 1 to 3 of 3
Thread: FFDShow EQ Plugin - Windows Media Player
    MySQL Error
    Oct 2004
    this has been updated 2/19/2011
    if using windows 7, Windows 7's wmp is not going to use DirectShow to playback audio/video, it uses Media Foundations, or DMOs
    you can disable(hack) some of these with "Win7DSFilterTweaker_4_0"
    I cant recomend this, but it is possible
    FFDShow Audio Equalizer for Ride Runner
    Description:
    This plugin is meant to provide the means to control FFDShow's audio equalizer from within Ride Runner.
    (Provides a 10-Band Equalizer without pre-amp)
    Purpose:
    When using the Windows Media Player or another DirectShow based Player with Ride Runner, you can have
    FFDShow control the playback of audio in which case you will be allowd to use it's equalizer from within
    Ride Runner. When using other players, you can still use this plugin to add a video equalizer when
    playing videos using the Built-in player, MPC or any other Video/DVD player that works with FFDShow.
    Requirements:
    -FFDShow the latest works use x86!
    -Ride Runner
    Install considerations:
    If you use WMPRR (Windows Media Player), this plugin will automatically override the standard sliders in
    Ride Runner so you can use the FFDShow equalizer without modifying the skin. If you use Winamp, FMOD or any
    player which already includes an equalizer, then this plugin will override the standard sliders ONLY WHEN
    playing VIDEOS. Regardless of this override, there are direct codes which always control FFDShowEQ.
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2008
    San Jose, CA USA
    I am using Window media player with W7. I tried installing this EQ plug in and it just made windows media player not work. Is ride runner using the windows media player from windows 7 or is it's own plug in?
    Also will I be able to have control over the EQ with this plug in...cause right now I only have control when I use itunes or winamp(which I hate)
    MySQL Error
    Oct 2004
    its complicated, you can set rr to use WMP, but its not the FULL WMP... that is not allowed to be used by other programs..(licensing) and hense we cant use its EQ
    and have to do FFDSHOW
    which is messy on win7... with its really improved audio/video playback using Media Foundations
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. FFDShow Equalizer Plugin
    By guino in forum RR Plugins No Longer Supported
    Last Post: 02-19-2011, 02:42 PM
  2. Windows Media Player 10
    By portreathbeach in forum Software & Software Development
    Last Post: 10-30-2006, 09:10 AM
  3. Car2PC plugin for Windows Media Player released !
    By jbors in forum Software & Software Development
    Last Post: 04-16-2006, 01:51 AM
  4. Using windows media player in RR
    By dseoane in forum Road Runner
    Last Post: 08-25-2005, 10:28 AM
  5. VLC vs Windows Media Player
    By Kato in forum General Hardware Discussion
    Last Post: 04-28-2005, 12:50 PM
