Quote:
Originally Posted by
JohnWPB
Yep, that was the problem! Haaha Sorry! I did not have the _P on the milage2.skin.
Glad that was an easy fix
Quote:
I am using an NumOSK to enter the fuel data, and not a full screen skin. All is working well, except after pressing OK on the Milage2.skin, the plugin is going back a screen / sending an ESC command. This should be handled in the skin really, and not the plugin, just for flexibility.
I agree but its what was originally in festy's plugin and if I change it all the current skins will fail when I really wanted backward compatablity. The only way out would be to depricate the command and add a new one.EDIT: I've added a new command called milage_logfuel, does the same as milage_ok but no screen exit.
Quote:
Is there some way I can override or work around this? As of now, when I press OK, it takes me back to the skins Menu.skin.
not at the moment
Quote:
Also, the MILEAGE_VOLUNITS label does not appear to be working. It contains nothing. Isn't this the label that should contain either Gallons or Liters?
It is. Whats your internationalisation set to in RR. Edit: You are using milage_volunits and not mileage_volunits
Quote:
I can package the skin I have here up, if you want to have a look at everything, and see if I am doing something stupid on my part :)
Can you send me that plus you milage.ini file.
