Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Festy's Tripmeter plugin [RELEASED]
  1. #11
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Ok, I just downloaded it from the appmart. I am having all sorts of problems
    First, when I copy the skin files to CarWings for testing, and click on add fuel, it errors out as it is looking for MilEage.skin, not Milage.skin, which is the name of the skin file. Simply renaming the 2 mileage skin files took care of that.
    How do you see what you are entering with the NUMOSK in the text box? If I put the "MILAGE_FUELUNITS" as the label code, it does show, but when going to milage2 it just appends the price after the miles.
    For instance, if I put 12 gallons at $3.56 a gallon, the label reads "123.56"
    Is there a way to enter the car's odometer in the plugin so there is a reference point for accuracy? There is a +/- 1 & 10 to adjust it, but adjust it against what?
    Thanks for the work on this, as it is a really nice little tool for those that do not have fuel economy on the dash, as I do not. I tried numerous times to get this to work back in the day when Festy released it, and was never able to then either
    My Fiero Build Thread
  2. #12
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by festy View Post
    I just stumbled across this thread on google, glad to see someone's looking after my old plugin, even if they're ribbing me about my spelling in the process
    I don't get email notifications from this forum for some reason, so only saw your PM when I logged in just then.
    Sorry about the ribbing But its a good plugin and didn't want to see it die.
  3. #13
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by JohnWPB View Post
    fixed but I changed the skin file not its name.
    are you using the milage_P0-9 or milage0-9 in the milage2 skin? For putting in the price you should use the milage_p
    the milage_plus /minus buttons remove units from the total trip. I didn't see the point of this so I added the accuracy adjustment % (see ini file). I found that my mileage was allways out by 3% so I just multiply the gps mileage by this % and its now perfect.
    well hopefully this time we'll crack it
  4. #14
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Yep, that was the problem! Haaha Sorry! I did not have the _P on the milage2.skin.
    I am using an NumOSK to enter the fuel data, and not a full screen skin. All is working well, except after pressing OK on the Milage2.skin, the plugin is going back a screen / sending an ESC command. This should be handled in the skin really, and not the plugin, just for flexibility. Is there some way I can override or work around this? As of now, when I press OK, it takes me back to the skins Menu.skin.
    Also, the MILEAGE_VOLUNITS label does not appear to be working. It contains nothing. Isn't this the label that should contain either Gallons or Liters?
    I can package the skin I have here up, if you want to have a look at everything, and see if I am doing something stupid on my part
    EDIT: I just checked the SkinTool and after MILAGE_OK is fired, it is executing an "EXIT" command.
  5. #15
    lambosprit's Avatar
    Sep 2006
    UK
    Glad that was an easy fix
    I agree but its what was originally in festy's plugin and if I change it all the current skins will fail when I really wanted backward compatablity. The only way out would be to depricate the command and add a new one.EDIT: I've added a new command called milage_logfuel, does the same as milage_ok but no screen exit.
    not at the moment
    It is. Whats your internationalisation set to in RR. Edit: You are using milage_volunits and not mileage_volunits
    Can you send me that plus you milage.ini file.
  6. #16
    Aug 2012
    Can I print a list of work trips?
  7. #17
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Feiko View Post
    If you check the first post it tells you what types of logs are written out. Depending on what info you want take your pick.
  8. #18
    Aug 2012
    I'm sorry my English is not that good so I interpret it wrong, but thanx.
  9. #19
    Jul 2009
    B.C., Canada
    Is this dead again? The original version crashes RR and this version I can't find in the AppMart.
    PROGRESS:
    Hardware: 100%
    Software: 99% - Always upgrading and improving.
    Installation: 100%
    WORKLOG:
    2005 F-150
  10. #20
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
    By Blue ZX3 in forum RR Released Plugins
    Last Post: 05-15-2013, 11:45 AM
  3. My Destinator plugin has been released
    By Deadeye in forum DigitalMods (Scripts / API)
    Last Post: 10-12-2007, 12:14 PM
  4. ANNOUNCEMENT: Zehnder LCD Plugin v 6.0a released
    By CrazyLittle in forum Software & Software Development
    Last Post: 03-04-2003, 08:51 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
