Results 1 to 10 of 20
Thread: Festy's Tripmeter plugin [RELEASED]
    lambosprit's Avatar
    Sep 2006
    UK
    A long time ago Festy developed a tripmeter plugin to record various mileages.
    He released the source code and hasn't been seen on the forums for a while so I have taken it upon myself to convert the plugin to .net and make a few additions such as hibernate awareness and profile mode.
    I will be releasing the plugin on Appmart but thought I'd check first if anyone knows if Festy has any objections to this. I sent him a PM ages ago but no reply. Dont want to let a good plugin die so if no objections I will release it BUT if Festy ever tells me to remove it then I will.
    Edit. No objections so far so I'll release. Get it from the AppMart.
    Milage (yes I know its spelt wrong but thats history) is a plugin for Riderunner. Its been tested against May and June versions but should be ok for older versions too.
    Functionality
    It adds multiple trip meters, fuel consumption calculation and logging, and a few other bits and pieces.
    The plugin can record trip specifics - such as distance, end time/date and end coordinates.
    These details and Fuel consumption information are saved to a sqlite database.
    There are 3 trip meters available simultaneously:
    Total meter - this is a cumulative meter that is saved between RR restarts. This is the trip meter
    that the fuel consumption is calculated from. Resetting this meter also resets the average and
    max speed, as well as the leg meter.
    Trip or Leg meter - this is a sub-meter of the Total meter, useful for following trip notes that
    state "left in 3.4km" kind of thing, can be reset without effecting the total meter. Its also automatically reset
    when comming out of hibernate.
    Work meter - can be started and stopped at will, useful for recording trips for work etc. Completely
    independant of the other meters.
    Fuel consumption is calculated by inputting the quantity of fuel used. The idea being that when you
    fill up, you enter the litres/gallons it took, and this is used with the Total meter to record a
    consumption figure, in L/100km or mpg. Entering a fuel quantity will zero the Total meter, ready to
    start logging the next tank of fuel.
    Both metric and imperial units are supported, based on the isunits line in RR.ini.
    For countrys that use a mix (i.e UK) then a special mixedUnits variable allows miles and litres.
    Files:
    tripmeter.ini - records Total and work meter values between invocations of RR
    tripmeter.log - CSV of recorded trips, fields are end date, end time, total meter, leg meter,
    work meter, end lat, end lon
    fuel.log - CSV of fuel consumption, fields are date, time, fuel quantity, distance,
    mpg or l/100km, lat, lon
    fuel.kml - google earth points file.
    Mileage.db3 - sqlite database file.
    lambosprit's Avatar
    Sep 2006
    UK
    FAQ
    Q1) Why does the tripmeter go up when I'm stopped?
    A. This is because of GPS accuracy. To counter it the is a min mileage for update in the ini file. Set this to a slightly higher number (default is 0.001).
    Q2) Why does the tipmeter suddenly go up alot of miles?
    A. again due to GPS accuracy. There is a max mileage setting in the ini to counter this. set it lower.
    lambosprit's Avatar
    Sep 2006
    UK
    Screenshots
    Screenshots from Carwings lite
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Certainly a new cool plugin !
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by pierrotm777 View Post
    Not a new one just a resurrected one. All credit must go to Festy as he wrote it first. I just converted it.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Does this use exactly the same skin codes as the original?
    If so there should be no need for me to change any support in the iDrive skins.
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Enforcer View Post
    I used exactly the same skin codes for that very reason even though he spelled Mileage wrong.
    Low Bitrate festy's Avatar
    Jun 2006
    Sydney, OZ
    I just stumbled across this thread on google, glad to see someone's looking after my old plugin, even if they're ribbing me about my spelling in the process
    I don't get email notifications from this forum for some reason, so only saw your PM when I logged in just then.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    festy lives!
    Glad to see this converted over and working! I always thought this was a nice simple plugin, and am glad to see it resurrected!
    My Fiero Build Thread
  1. RRMedia Plugin by Blue ZX3 [v1.3.0 Released]
    By Blue ZX3 in forum RR Released Plugins
    Last Post: 10-24-2015, 01:12 PM
  2. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  3. My Destinator plugin has been released
    By Deadeye in forum DigitalMods (Scripts / API)
    Last Post: 10-12-2007, 12:14 PM
  4. ANNOUNCEMENT: Zehnder LCD Plugin v 6.0a released
    By CrazyLittle in forum Software & Software Development
    Last Post: 03-04-2003, 08:51 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
