Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: RR WebRadio - Proof of concept plugin (SOURCE TYPE)
  1. #11
    Nov 2004
    St Louis
    I know I'm being a killjoy, but what does this plugin add that can't already be accomplished using the RR Winamp audio player?
    I guess if you're not using Winamp for the audio player, it would be useful, but I play webradio in WMP as well... haven't tried any of the other available RR audio configurations.
    Mitch, can you post the docs/txt files for this plugin? My dev machine is down and I don't want to run the setup on my operational machine just to read the documentation.
  2. #12
    Sep 2011
    interesting post gizmo. i never thought of playing webstreams with normal audio player because i changed from centrafuse and there is no way to play streams with stock audio player... but my personal advantage of this plugin is, that i have an own webradio button on homescreen. another one is, that the trackname doesn't show up correctly when starting some *.pls or *.m3u stream in audio player (like from di.fm). somehow it works with webradio plugin!
    edit: had managed it to show trackname of streams global. now i'm 100% satisfied!
  3. #13
    MySQL Error
    Oct 2004
    Quote Originally Posted by GizmoQ View Post
    this a a proof of concept custom source plugin
    and the skin and the plugin is taylored for webradio
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #14
    Aug 2008
    Quote Originally Posted by Dartman_71 View Post
    Images goes to genre folders, for example RideRunner\Plugins\RRWebRadio\Streams\Dance
    If your station is playlist like... Radio Plaa Plaa.m3u then you name image Radio Plaa Plaa.jpg.
    If you use URL for example http://83.145.201.209:8000/ then you name your image WebRadio_83.145.201.209.8000
    Thanks for your help
  5. #15
    Aug 2008
    Thanks again for thease plugin i have only one problem i cant start a stream by double clicking on the list item. I lost that future failure when converting it to another skin. Any Idea?
    Thanks for all your hard work mitchjs
  6. #16
    Sep 2011
    i had the same issue mali_arkan. open the original skin file and have a look at the SC01 list in editor. you will see that the skin editor has stripped some commands away in your modified skin file. when i run my notebook, i can paste the exact part here if you can't find the differences.
  7. #17
    MySQL Error
    Oct 2004
    skin editor is very old, and not directly maintained, could use someone to take that over
    i almost never use it... cause its too far behind what rr can do
    prob an easy update for SC customlist def
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #18
    Aug 2008
    Quote Originally Posted by fruchtfliege View Post
    Thanks work perfect i was adding thease code ,00,"","","WEBRADIO_SETURL;$LISTTEXT$;$LISTDESC$"
    Thanks guys
    Only one more question is there possible to record streams on windows 7 and what is command to add selected list item on the SC01 list to the "favorites.txt" file?
  9. #19
    Sep 2011
    i requested this few days ago, but the only way is to use bassRR as player. using winamp, there is no way to record streams until now. at least you can embed an app that will do this...
  10. #20
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    I requested this a year ago.
    No, not true.
    Really?
    Stream ripper has been out for years, and I been using it for years, I just recorded a show last night.
    Sure, if someone could just add a record/ripping button to every skin out there, to use with stream ripper,..... this would just be dandy!
    The record button is way to small on the stream ripper player to use. Not a option when driving.
    Stream ripper automatically starts up in the background, which you don't see anyway, endless you minimize RR.
    Dude, I been using winamp and recording streams for years with no problems at all. Did you see this? ----> including a button for record
    Hope this helps?
  1. Hyundai Haptic Proof of Concept Uses PC - CES 2011
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 01-07-2011, 01:18 PM
  2. Proof of Concept: Interfacing with GMPC
    By ws6vert in forum Garmin Mobile PC
    Last Post: 12-22-2010, 02:49 AM
  3. Proof of Concept Help ion 330ht-bd
    By sliblue in forum Newbie
    Last Post: 12-06-2009, 03:02 PM
  4. Request: Webradio plugin
    By Flappy in forum CF Plugins
    Last Post: 02-17-2008, 01:52 PM
