Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: RR WebRadio - Proof of concept plugin (SOURCE TYPE)
    MySQL Error
    Oct 2004
    this adds web radio... it uses Winamp as player (so you have to have winamp properlly installed)
    (you dont have to use winamp for RR has nothing to do with that)
    sample skin for carwings is included
    a bunch of streams included
    thanks to Dartman_71 for his ideas and testing...
    DOWNLOAD HERE:
    https://www.dropbox.com/sh/7kprao1it51ol3t/45d5pH85Ul
    Code:
    RideRunner Extension Plugin for Web Radio
    Written by MJS Gadgets www.mjsgadgets.com
    Inspired by Dantman_71
    ! Requires .net 3.5sp1 framework
    * Sample Skin installed into: <RR Root Folder>\Plugins\RRWebRadio\Sample Skin
    NOTES:
    1. This uses winamp to play web radio streams.
    2. If your audio player in RR is configured as Winamp,
       the EQ Settings, Preamp Volume will sync.
    Parameter Definitions:
    url              = URL or playlist file ".m3u" or ".m3u8".
    pname            = Stream name.
    Default Data folder:
    Profile Mode: My Documents\RideRunner\Plugins\RRWebRadio\
    Legacy Mode: <RRROOT>\Plugins\RRWebRadio\
    Data File format:
    path or file||displayed text
    Examples:
    Pop.txt||[ Pop ]
    mitch.txt||Mitch's Favorites
    610 Wip.m3u||610 WIP Sports Talk
    http://10.10.1.1:8000||My Stream
    ** SKIN COMMANDS
    "WEBRADIO"                                                               - Loads "WebRadio.skin"
    "WEBRADIO_SETURL;url;pname"                                              - Opens a stream and begins playing.
        ex. WEBRADIO_SETURL;http://83.145.201.209:8000;BassoRadio
            WEBRADIO_SETURL;mywebstream.m3u,My Web Stream
    "PLAY"        - Plays current stream.
    "STOP"        - Stops current stream.
    "PAUSE"        - Pause(stop) current stream.
    "RESUME"        - Plays current stream.
    "LOADLIST;listname.txt"                                                  - Loads a stream list.
    "RELOADLIST"                                                             - (Re)loads the 'root' stream list.
    "RELOADLIST;1"                                                           - (Re)loads the current stream list.
    ** EVENTS
    ** SKIN LABELS
    "STATUS"        - Returns "playing, paused, stopped"
    "PLAYLIST"                                                               - Returns the current stream "friendly" name.
    "TRACKNAME"                                                              - Returns stream broadcasted message.
    "KBPS"        - Returns bitrate of stream "xxx Kbps"
    "KHZ"        - Returns sample rate of stream "xxx Khz"
    ** SKIN INDICATORS
    "STATUS"        - Image in skin path, "play.png", "stop.png", "pause.png"
        (.gif is also tried)
    "ALBUMART"                                                               - Image of stream, uses file name of stream
        If URL type, then "webradio_xxx.xxx.xxx.xxx"
        Where in URL, : & \ are replaced with .
        Ex. URL = http://10.10.1.1:8000
        File name is, "webradio_10.10.1.1.8000"
    "WEBRADIO_ART"                                                           - see "ALBUMART"
    ** SKIN SLIDERS
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Oct 2010
    Canada
    Awesome plugin. I have it working well, but few things I've noticed regarding winamp. For some reason when loading road runner it loads 2 instances of winamp - one for the radio and one for my music. Not a huge issue but if I listen to radio and then switch to my music, I can't adjust the eq as it's focussed on the instance playing radio.
    I've tried manually closing one of the instances after loading RR but this creates its own issues. If I listen to music and then try to listen to radio, the radio stations won't load and I get an invalid URL message.
    Any suggestions?
    Sep 2011
    great plugin! is it possible to start a stream by double clicking on the list item in any way?
    further i made a skin for elite lite 1.6.6 - if anyone wants it or mitch want to include it, let me know.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    This is a new great plugin.
    Thanks mitchjs :-)
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by fruchtfliege View Post
    Stream should start when you double click item on list, at least mine start.
    Feb 2009
    Finland
    Quote Originally Posted by pierrotm777 View Post
    Thanks mitchjs :-)
    And took only four months to notice it hehehee...
    Sep 2011
    Quote Originally Posted by Dartman_71 View Post
    thanks, maybe i made a failure when converting it to elite lite skin
    MySQL Error
    Oct 2004
    Quote Originally Posted by doctr_nick View Post
    Any suggestions?
    it uses its own instance of winamp, the eq should match the other instance(music), its complicated...
    dont be closing any instances of winamp
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2008
    Work perfect. Only one questions how to make it work whit "ALBUMART" my webstream: WEBRADIO_SETURL;mms://live.radio1.si/antena ;Radio Antena - image name: webradio_live.radio1.si.antena.jpg is thease correct? where to copy it?
    Feb 2009
    Finland
    Images goes to genre folders, for example RideRunner\Plugins\RRWebRadio\Streams\Dance
    If your station is playlist like... Radio Plaa Plaa.m3u then you name image Radio Plaa Plaa.jpg.
    If you use URL for example http://83.145.201.209:8000/ then you name your image WebRadio_83.145.201.209.8000
  1. Hyundai Haptic Proof of Concept Uses PC - CES 2011
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 01-07-2011, 01:18 PM
  2. Proof of Concept: Interfacing with GMPC
    By ws6vert in forum Garmin Mobile PC
    Last Post: 12-22-2010, 02:49 AM
  3. Proof of Concept Help ion 330ht-bd
    By sliblue in forum Newbie
    Last Post: 12-06-2009, 03:02 PM
  4. Request: Webradio plugin
    By Flappy in forum CF Plugins
    Last Post: 02-17-2008, 01:52 PM
