Page 14 of 48 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 475
Thread: DFXVoice A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #131
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Can u please also attach your DFXVoice_Settings.xml file... something just a bit odd with your log.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #132
    Jun 2007
    ok...
    I think 0.5.1 have bug with audio_browser.skin
    I can see command with this skin on plugin default,When I transfer to my skin I can't see voice command in it.
    Attached Files Attached Files
  3. #133
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    I'm must be doing something wrong. Can someone advise me please .
    I've downloaded the latest version, run the setup and added the required code to the skin exectbl. What else should I do as I'm getting no signs of voice recognition working (the indicator is showing for DFXVoice)? Should the automatically starting Win7 voice recognition app (that stays on top) be left running too?
    I've tried searching before posting with no success, and probably missed something really basic!
    Thanks in advance,
    Dave
    Vauxhall Astra SXi Car PC installed.
  4. #134
    Jun 2007
    1.setup your mic for voice recognition
    2.create command for dfxvoice
    3.no need auto load voice recognition when startup windows
  5. #135
    Mar 2005
    Norfolk UK
    Thanks anuchit.
    1.Mic set up
    2.Is this not done in ExecTBL?
    3.Windows VR autoloads. I'll attempt to prevent it auto-starting
    Cheers,
    Dave
  6. #136
    Mar 2005
    Norfolk UK
    Thanks again anuchit,
    I've just been out to the car and added a button to the main menu (I thought the Exectbl code set this to on) and prevented Win7 VR app from auto-starting. I'm at work so it was a very quick test but happy with it at this stage . More testing tomorrow.
    BTW - If anyone has a copy of the latest RRK8055 plugin (2.2.0.0, I think - for global setting) I would be most grateful so I can set my steering wheel controls to DFXVoice on/off button in whatever menu .
    Thanks,
    Dave
  7. #137
    Sep 2011
    afaik you have to bind the command "DFXVOICE" to a hotkey or something. i attached it to my powermate and it works. waking up by saying "dfxvoice" doesn't work for me. should it?
  8. #138
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by fruchtfliege View Post
    The "DFXVoice" cmd is when u want to use a btn either in the skin or an external one. To use the wakeup part u need to have it enabled and specify what it is supposed to listen for. If using carwings, in the plugin setting scrn, press n hold the wakeup on/off btn and u should get the osk so that u can set/change the listen cmd.
    I will update the installer to better explain some of these misunderstood issues.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #139
    Sep 2011
    thanks for explanation. that means that i can't enable it by the xml editor? i'm using elite 2 alpha skin, and i guess the setting screen won't work there. is there any other way to enable and/or change auto-voice (command)?
  10. #140
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, actually you can... I wasn't infront of the comp, and couldn't exactly remember if I had finished/done that part of the editor yet..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 05:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 10:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 11:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 12:26 PM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 10:20 AM
