Page 19 of 48 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 475
Thread: DFXVoice A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #181
    Jun 2007
    win7 now 0.5.3 screen change Does not respond.
  2. #182
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    It is called "Beta" ...
    I am working on several features at once, I will check and post my findings.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #183
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    I'll try to bring more light to audio_player screen RR hang issue. After more testing i noticed that DFXVoice hang RR also in WebRadio screen. It can't be related to Mitch's WebRadio plugin because after I uninstall all other plugins except DFXVoice, audio_player screen issue is still presence. Also it's not related to WinAmp, same issue happens with WMP.
  4. #184
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    And doing a great job . Thanks Blue.
    I'm just downloading the latest Beta and I'll report back to whether the 'RR Hang' issue is resloved here.
    Thanks again. Your hard work and quick response is very much appreciated.
    Vauxhall Astra SXi Car PC installed.
  5. #185
    Mar 2005
    Norfolk UK
    "RR hang" bug sorted. Thanks Blue.
    Steering control next for Mic on/off
  6. #186
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by Davefocus View Post
    Nice.
    For those looking for an easy, inexpensive way to trigger listening, consider the RRMousetrap plugin and a wireless mouse. That's what I'm using. I set the middle mouse button to trigger listening. I keep the mouse on the floor of the car and simply tap the mouse with my foot in order to trigger. It's just like those older cars where you pushed a button with your foot to turn the bright lights on and off. Works great.
  7. #187
    Dec 2008
    well my first shot was a total miss last night
    im missing a couple things
    first, i just let it auto install. rr and dfx are up to date, and i did one training profile. however once in dfx i try to click on the little voice indicator on top (which should put it into listening mode) but nothing happens.
    second, i thought there used to be a program that scanned your mp3 collection and made a voice command file from that. i didnt notice any such work being done... is it just automatic and in the background now?
  8. #188
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    not to mention fixing all these bugs... Dam, where did i put that can of bug remover at??? LOL Heck, I may need more than one can
  9. #189
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by trader007 View Post
    first, i just let it auto install. RR and DFX are up to date, and i did one training profile. however once in DFX i try to click on the little voice indicator on top (which should put it into listening mode) but nothing happens.
    second, i thought there used to be a program that scanned your mp3 collection and made a voice command file from that. i didn't notice any such work being done... is it just automatic and in the background now?
    We're pretty much done with the DFX skin stuff. The ind in your DFX skin is linked to RRVoice. Edit your topindicators.txt file and use the "DFXVoice_Status" name instead.
    Again, this is beta and I'm working on sever things at once, the music scanner part of this plugin wasn't going to be worked on till everything else was in order, but if your read the first post you would have seen whats done and not done yet .
    I have now started the dual threaded music scanner, did a huge chuck of it last nite and looking very promising! I'd say that probably in the next two weeks I'll be releasing a version with access to it.
    @ RAWPWR
    Nice!...Hahah
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #190
    Jun 2007
    I hard test for your plugin..
    Hopefully you will not bother.
    And Now..I found issue when I click to change screen on skin, DFXVOICE Does not respond ( not add current screen )
    cheer to 0.5.4
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 05:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 10:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 11:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 12:26 PM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 10:20 AM
