Page 20 of 48 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 475
Thread: DFXVoice A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #191
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Ok, for those of you beta testing the DFXVoice plugin, and using the DFX skin, you can run the auto updater in the skin, to get the new settings screen. For now you will have to create a button in the skin manually, to load the DFXVoice_settings.skin, or use the skin tool and put this in one of the command lines: load;DFXVoice_settings.skin
    Here is a screen capture of the settings skin:
    Notice Thread 1, and Thread 2 labels... Blue created the plugin as multi-threaded, thus it can scan your ID3 tags almost 2 times faster, significantly lowering the scan time. It scans all tags, and creates the database for 40,000 MP3's in around 18 minutes! With a previously released voice plugin I was using, it took almost an hour to scan 30,000 MP3's!
    My Fiero Build Thread
  2. #192
    Dec 2008
    We're pretty much done with the DFX skin stuff. The ind in your DFX skin is linked to RRVoice. Edit your topindicators.txt file and use the "DFXVoice_Status" name instead.
    Again, this is beta and I'm working on sever things at once, the music scanner part of this plugin wasn't going to be worked on till everything else was in order, but if your read the first post you would have seen whats done and not done yet .
    I have now started the dual threaded music scanner, did a huge chuck of it last nite and looking very promising! I'd say that probably in the next two weeks I'll be releasing a version with access to it.
    @ RAWPWR
    Nice!...Hahah
    i read i promise! i just missed it
  3. #193
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Instead of having to add a button for the settings screen, just use plugin manager. create a method in your project as so..
    Code:
    public sub Settings()
        'whatever command loads the settings screen goes here
    End Sub
    With this, the settings button on the plugin manager screen will dynamically work with your settings skin.
    Live mp3Car Facebook Chat
  4. #194
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Sonic, DUH! I forgot about that. He has that sub in the plugin, so yes, you can add "Plugin MGR" to the main menu buttons, go into it, select DFX voice in the list, and click the "Settings" button to get to it.
    Brain cramp last night when I posted it I guess
  5. #195
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    I'm sorry that I didn't praise this plugin before, but more I play with it, more I like it! After teaching Windows to understand my mumble, this really works very well.
    Please Blue, try to fix audio_player screen issue.
  6. #196
    Sep 2011
    i'm really impressed, because i changed all commands to german and dfxvoice recognizes them much better than my bad english now i'm waiting for a release where i can change the music commands.
    am i right when i say that the voice commands didn't work in the actual release, due the lack of a background scanner?
  7. #197
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Yes, adding the music commands is something that Blue is currently working on, and making very good progress as well The initial beta just has commands for switching screens, firing commands and such, but no music commands just yet... but hopefully soon...
    Again, like with any music scanner, it will only work as good as how well your files are tagged. Get something like "Tag & Rename" (Has a 30 day free trial) and get your tags in order. I know, it's a pain, and people will wine that they have 10,000 songs to tag blah blah blah.... well I have close to 50,000 songs here, and every single tag, in each and every .mp3 is complete. A daunting task, but a good tagging program can make it fairly automatic.
  8. #198
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    John, dual thread scan will def make my scanning of my mp3 collection less of a chore, being that I have 50,000+ mp3s also.
    I also been using "Tag & Rename" for a while now, and I must say that this is the best/easiest program to use in my opinion.
    Excellent job so far!
  9. #199
    Sep 2011
    well, this is at least much more than centrafuse is able to do has blue build in a "expire date" to the plugin? i wondered yesterday, that RR shows a screen which says something like "beta blablabla". or have i messed something up with adding / removing commands?
  10. #200
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, all beta builds have a one week expire date, once a final full release is made, that will be removed... its just to keep everyone using the more recent version.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 05:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 10:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 11:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 12:26 PM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 10:20 AM
