Page 25 of 48 FirstFirst ... 151617181920212223242526272829303132333435 ... LastLast
Results 241 to 250 of 475
Thread: DFXVoice A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #241
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    I got RideRunner not responding with v0.6.0 when I run RR... Could it be related the file you forget?
  2. #242
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Dartman_71 View Post
    This version crashes RR on load for me. Same way it did with the mobilephone plugin installed, but this time it does it with no other plugins installed. RR loads splash screen, but as soon as i get to menu.skin RR crashes with a system.io.filenotfound exception. Here are the rest of the details
    Code:
    System.IO.FileNotFoundException was unhandled
      Message=Could not load file or assembly 'Interop.LITEXLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
      Source=DFXVoice
      FileName=Interop.LITEXLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
      FusionLog=WRN: Assembly binding logging is turned OFF.
    To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
    Note: There is some performance penalty associated with assembly bind failure logging.
    To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
      StackTrace:
           at DFXVoice.modMain.Initialize_PI()
           at DFXVoice.modMain.MainThread()
           at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
           at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
           at System.Threading.ThreadHelper.ThreadStart()
      InnerException:
    Live mp3Car Facebook Chat
  3. #243
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, it is b/c of the missing file...sorry
    Will post a fixed installer when I get home!!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #244
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ok, installer fixed...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #245
    Feb 2009
    Finland
    Thank you for quick installer fix.
    But RR still stops responding (hang) if I give "DFXVOICE" command in audio_player.skin or webradio.skin, I belive you haven't done anything to this issue?
    Now begin to feel that I am very stupid or complete noob because RR also stops responding when I give "DFXVoice;startscan" command... so is there real issues or is't just that I do something wrong?
    Also DFXVoice_debug show that plugin scan my playlist folder, should it scan music folder?
    Just to be sure, will DFXVoice plugin and scan etc. features work without RRmedia, RRExtended or any other plugin. I start to feel if I miss something simple what advanced users already knows.
    Attached Files Attached Files
  6. #246
    Woodbridge, VA
    Blog Entries
    55
    newest installer works fine for me. Now i'll try to get it installed in the car again.
  7. #247
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    All the req's are listed, and this doesn't rely on anything else yet. It gets the musicpath from rr so what ever your musicpath setting is set is what it's gonna scan. I'll look at yr logs when I get home and see what else I can suggest or ask
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #248
    Sep 2011
    can't wait to test the music commands in car. thanks for new release! i'm sure my andrea a-350 installation will make sense soon
    just a question: is release 0.60 downloadable in first post? it's a bit confusing because it has the same name like the release before afaik.
  9. #249
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The log was just saying that the playlist files that it came across are not audio files, that's all. I now changed that so that it wont log those non errors any more.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #250
    Feb 2009
    Finland
    Oh yes it was. Can you help with RR hang issue, it doesn't make any sense why RR hang only in audio_player and webradio.skin. I also wonder about hanging after scan???
    I've tried everything what came to my mind, changing Windows region from Finnish to English, without any other plugins, profile and legacy mode, with Carwings and Reborn. Also Windows is updated and if I didn't mention before this is Win 7 32bit.
    This doesn't seem to be related to music player because same issue happend with Winamp and WMP, only those darn screens.
    I can give voice commands in any other screens without any issue, except in those two screens. This is so weird!
    Am I only one with Hang issue?
    Well, great job with plugin although it cause gray hairs here
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 05:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 10:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 11:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 12:26 PM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 10:20 AM
