Page 26 of 48 FirstFirst ... 161718192021222324252627282930313233343536 ... LastLast
Results 251 to 260 of 475
Thread: DFXVoice A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #251
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    I found reason why DFXVoice hangs RR when scanning music, I had one mp3 without id tag and that cause hang... I think scanner should skip files which not include tags?
  2. #252
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Cool, glad you found out what caused one of your hang ups. I will dbl check that here and and add the checks to prevent it for the next release..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #253
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    is the configuration executible supposed to be able to scan music too, or is it just the DFXVOICE;STARTSCAN command that does it?
    Live mp3Car Facebook Chat
  4. #254
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Just the plugin
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #255
    Feb 2008
    Blue,
    Should the Music Commands screen look like this?
    I'm also experiencing the hang in the audio player and audio browser skins. This is on a Win 7 machine and Carwings Dynamic Lite. I can post debug logs if you like.
    On a positive note, the Music Scanner worked great!
  6. #256
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Didn't get that far yet
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #257
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    All going well during testing apart from the error I get with the xml editor util using win7. It says the error message but still accepts the command action.
    I also notice that in normal use it does listen on first required use so I have to dfxvoice on, dfxvoice off and dfxvoice back on.
    Vauxhall Astra SXi Car PC installed.
  8. #258
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Something doesn't sound right then, no one else has yet to mention that, nor did I find that to occur during W7 testing and Johns xp testing. Bit vegue on the err msg, give example and I'll see if i can see & fix it here.
    Just this past week, I did change my carpc over to the .net version and aside from trying to use the carwings settings file with DFX, all has been mostly issue free.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #259
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Unhappy
    I do my test on xp sp3 and i have a rr error when i register dfxvoice !
    I upload my debug file !
    Attached Files Attached Files
  10. #260
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Use the newest installer, the previous one was missing a file and caused an err, probably the one your seeing.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 05:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 10:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 11:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 12:26 PM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 10:20 AM
