Page 27 of 48 FirstFirst ... 171819202122232425262728293031323334353637 ... LastLast
Results 261 to 270 of 472
Thread: DFXVoice – A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #261
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Use the newest installer, the previous one was missing a file and caused an err, probably the one your seeing.
    It's ok now with the new installer :-)
  2. #262
    Maximum Bitrate Davefocus's Avatar
    Mar 2005
    Norfolk UK
    Blue,
    First I should apologise for forgetting my manners the other day - Happy New Year .
    I've done some more testing and find that the first use of RRVoice_On requires very accurate pronounciation, whereas subsequent uses appear to allow much less accurate pronounciation which may be as much to do with the mic and training profile as anything else - so my bad with that.
    The .NET Framework error message I'm getting with the DFXVoice utility reads:
    'Undefined Exception has occured in your application. If you click Continue the application will ignore the error and attempt to continue. If you click Quit the application will close immeadiately.
    Object reference not set to an instance of an object'
    I suspect this is related to my set up as its not being experienced elsewhere. However any advice would be welcome.
    This app is working very well in general, a fitting tribute to the hard work and dedication from yourself and associated developers.
    Regards,
    Dave
    Vauxhall Astra SXi Car PC installed.
  3. #263
    Jun 2002
    Virginia
    Quote Originally Posted by Davefocus View Post
    I have received that message as well with the latest install.
  4. #264
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Thanks!
    Most important thing that you both missed, I need to know what exactly you did leading up to that error so I can find it and fix it..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #265
    Mar 2005
    Norfolk UK
    I opened the app in the RR-plugins-dfxvoice-util folder by double left click. Have I made a elementry error...
  6. #266
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    By chance, are u trying to use an older settings file? If u look at the history file, I did change somethings. If so you can compare the two and adj the older one to match the changes in the scanner section.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #267
    Mar 2005
    Norfolk UK
    Thanks Blue. I just downloaded and initiated the unpack. Didn't read the info, just applied. I'll check tomorrow.
    Cheers,
    Dave
  8. #268
    Mar 2005
    Norfolk UK
    Got my Andrea Array mic to install and time to sort out the util issue today. Unfortunately the Beta has timed out . Can I ask when there is likely to be another realease to be able to test with?
    Thanks,
    Dave
  9. #269
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Because of late I have become a bit more busy, I have now pushed the beta time frame to 31 days from build. (Is that soon enough? )
    Installer updated again.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #270
    Mar 2005
    Norfolk UK
    Thanks blue
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 04:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 09:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 10:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 11:26 AM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 09:20 AM
