Page 29 of 48 FirstFirst ... 192021222324252627282930313233343536373839 ... LastLast
Results 281 to 290 of 475
Thread: DFXVoice A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #281
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Still busy, but I updated the installer for another 30days and for those that already have installed the latest and have the time out issue, just replace the dll file also found in Post#1
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #282
    Sep 2007
    Florida
    Wake Up Commands
    Blue, great job....so far im diggin it and finally got DXFVoice running but i have a few questions for you. Just a note, my HDD drive in my mustang frinally crashed after several years. I was running an old version of RR with RRVoice so i finally decided to go windows7 and the latest RR with your plugin for voice. Now to my question.....the wakeup command, with RRVoice you had a greet or several greets for RR to choose from upon startup....is there a way we could incorporate that into DFXVoice? It would definitely gives it a more personable touch. Now i changed my "wakeup" command to "computer"....so when i say "computer" it starts listening and i hear the .wav sound...whereas before when i said "computer" (which was the keyword), there were several dfferent replies it could choose from then i could say the command. Ive gone through DFXVoice and have tried a few things with no luck. Ill play aorund with it somemore, but if you have any info, it would be greatly appreciated, im just excited its up and running...so far so great. Thanks., Trey
  3. #283
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    If I understand you correctly, what your asking is a way to be able to use a list of different randomly picked replies that it could respond with so that one doesn't hear the same reply every time you wake it up.
    Like..
    [You] [Comp]
    Computer.... Yes
    Computer.... Can I help you?
    Computer.... You Rang
    Computer.... Yes Master... LOL
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #284
    Sep 2007
    Florida
    greetings, etc
    exactly,,,,,,,,below is a bit of the RRVoice file i had......yea, i had my car call me Master Trey, but it worked so well...i also had it so if i got pulled over by a cop, i would say, "Say hello to the officer",when they got to my window ahd she (loquendo susan)would go off on a rant.....this actually worked and got me out of a ticket. The cops were cracking up when they heard it. It gave my mustang a bit of a personality with an attitude, lol! Thanks for the quick response!
    [Replies]
    Greet="Welcome back Master Trey, its about time!"
    Reply2Check="you have new mail from "
    Reply2Read="shall I read it?"
    Reply2NoMail="you have no new e mail."
    NoAppts="you have no up comming appointments."
    NoApptsToday="you have no appointments for today."
    [KeywordReplies]
    Reply1=Yes Master Trey, what can I do for you?
    Reply2=Your wish is my command, master Trey!
    Reply3=What can i do for you Master Trey?
    Reply4=Yes master Trey!
  5. #285
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Blue you were helping me trying to figure out why RRVoice would not work in the DFX thread.
    New problem.
    I am trying to get your plugin DFXVoice working on Windows 7.
    I just did a fresh dual boot install of XP & Windows 7.
    I use the DFX Skin so this is what I did:
    Installed Windows 7 & updates then went into control panel, ease of access, Speech recognition, advanced speech options, RunSpeech recognition at startup is unchecked, made sure microphone was setup & ran a training session. Then I installed Flash,Winamp, RR, DFX skin & updates, DFXVoice plugin, copied over the newer .dll file.
    Now if I enable wake/sleep comands in the DFXVoiceEditor it hangs as soon as soon as DFX Skin finishes loading. I can't do anything. I just get a spinning mouse cursor. I have to end RR in the task manager. If I have it disabled I can use RR normaly until I press the microphone then it hangs again.
    Testing in carwings works good as long as I disable wake/sleep comands in the DFXVoiceEditor. If I enable it, same thing happens can't do nothing, just a spinning mouse cursor.
    HELP!!!
    Attached Files Attached Files
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  6. #286
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by michaelrj9 View Post
    New problem.
    HELP!!!
    Just a little update.
    On XP I don't have any problems right now (little time testing right now) but so far it changes screens basic stuff.
    Another note:
    I do have the mobilephone.net plugin and don't have any problems right now either. I know it was brought up before that it was crashing RR with the DFXVoice plugin. But for me it is working.
    My problem still remains with Windows 7.
    Is it something that I did or didn't do why it is not working in Windows 7? probably! but what?
    Thanks for all your hard work Blue!!
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  7. #287
    Sep 2007
    ID10t error
    Hi guys,
    I'm doing something wrong...somebody please point out the obvious to me? I think things are installed to some degree...mic activates, recognizes "music" and launches the player, and I can see the settings screen (in DFX5) via the PluginMgr. The sliders in the settings work, but it never scans my music and the "scan music collection" button doesn't seem to do anything. I try to play a song via voice, but it doesn't recognize it - the XML is empty. Should I be able to start the scan without modifying any skins or loading anything?
    (I used to run RRVoice, can't wait to get this working! Fantastic work...)
    Thanks much!
  8. #288
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Another note:
    I believe that IS the problem, combination of W7, DFXVoice, and Mobliephone.net, I know that for sure on a W7 install, but there may not be any issues with both of the plugins when running under XP.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #289
    Feb 2005
    Huntsville, AL
    Ok did not know if the mobilephone.net plugin problem was on XP or Windows 7,
    My Windows 7 machine is bare bones no other plugins or stuff installed. Just New Windows install,Windows updates,Flash, Latest RR, DFX Skin & updates, & DFXVoice.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  10. #290
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by flat6 View Post
    Hi guys,
    Thanks much!
    Well, I was gonna say that make sure that you have all the skin updates, but I did notice that even being current, that the scan button in the settings screen has no button defined for it. That is why you cant get it to scan.. I'll get that fixed but in the mean time you could either open up the skintool or make a btn on that screen if you know how and use the cmd "DFXVOICE;STARTSCAN"
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 05:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 10:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 11:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 12:26 PM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 10:20 AM
