Blue you were helping me trying to figure out why RRVoice would not work in the DFX thread.
New problem.
I am trying to get your plugin DFXVoice working on
Windows 7.
I just did a fresh dual boot install of XP & Windows 7.
I use the DFX Skin so this is what I did:
Installed Windows 7 & updates then went into control panel, ease of access, Speech recognition, advanced speech options, RunSpeech recognition at startup is unchecked, made sure microphone was setup & ran a training session. Then I installed Flash,Winamp, RR, DFX skin & updates, DFXVoice plugin, copied over the newer .dll file.
Now if I enable wake/sleep comands in the DFXVoiceEditor it hangs as soon as soon as DFX Skin finishes loading. I can't do anything. I just get a spinning mouse cursor. I have to end RR in the task manager. If I have it disabled I can use RR normaly until I press the microphone then it hangs again.
Testing in carwings works good as long as I disable wake/sleep comands in the DFXVoiceEditor. If I enable it, same thing happens can't do nothing, just a spinning mouse cursor.
HELP!!!
