Page 37 of 48 FirstFirst ... 272829303132333435363738394041424344454647 ... LastLast
Results 361 to 370 of 472
Thread: DFXVoice – A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #361
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya, I set to send cmds to rr depending on the action done, for the clicks. I have it directly controlling the volume via it's built-in functions to get my user adjustable speed atten volume. RR's speedattn vol controls the master vol between 50% and 100%, then I have my mouse wheel control either the wave or line in depending on what source I'm listening to.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #362
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Just about done, RRMedia usage is now fully working! I have also gone and added next/previous album commands (90% done). I will be PMing back those that were looking to test out this next version in the next day or so!
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  3. #363
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    I can't wait!!
    Shuttle Sk41g,Xp Pro,2.4ghz Amd,250gb Wd 7200 Rpm Hd,2gb DDR Ram,Ati Radeon 9250,Sound blaster external,CarPC Pro v.2.5d SD Controller,7" Xenarc 700TSV
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  4. #364
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Been testing. Working great. Got girder trigger setup to my steering wheel etc.. Only issue Im having is commands such as "Play Artist Tom Petty" are not working.
  5. #365
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Dougw133 View Post
    Goto settings, uncheck Music Taste Filter.
  6. #366
    Nov 2007
    PA
    Quote Originally Posted by Enforcer View Post
    LOL!!
    I acutally don't even have any Petty! It was an example, but touche!
  7. #367
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Well I do have some Petty! Now what cha gotta say... <open mouth, and sticks foot in>. LOL
    I will put up v1.1.0.0 tonight, under my testing/ coding / debugging on W7 32 bit, virtually no lock ups occurred. Now, when I went to test the installer and the 64bit RRmedia integration on my W7 64bit LT, twice it died in the same function same spot without any errors at...hmmmmm. I didn't really do too much more testing on the laptop as by then needed a nice break from all the digging thru code for a bit. Nutt'n like re-burning myself out that quickly.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #368
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Looking forward to the 32 bit version, and have a partition for 64 bit OS set up when that is good to go too.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  9. #369
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    See first post...
    v1.1.0 (9/2/2012)
    Major operational change, now two parts DLL & Exe
    Change the .Net codebase to 4.0 *** NOW REQUIRED ***
    Changed the debugxxx modes to now be levels instead of just off/on
    Changed Moved the xml Music scanner errors to a seperate log called 'DFXVoice_Scanner_Errors.txt' (debug mode must be on to be used)
    Added full RRMedia intergration, all music cmds come directly from the database
    Added labels for the above
    Added a Medialist type listing to the Multiple Songs found screen now shows the artwork,album name,track#, track name from that album
    Added Next & Previous Album for the voive loaded artist (DFXVoice;NextAlbum/PreviousAlbum) currently set to "Next Album/Previous Album)
    Added auto clearing of the DFXVoice Live log at plugin startup ( I got tired of doing it manually LOL)
    Added check for the "ON_DFXVOICE_MULTIPLESONGS" event, if not translated in Exectbl, then plugin will attempt to load the 'DFXVoice_MultipleSongs.skin'
    Added "Play xxx music" music genre cmds when using RRMedia opt, where xxx is the genre listed in your RRMedia's db.
    Updated the plugin commands text
    Updated the carwings screens
    Updated the DFX5 screens
    Updated the plugin xml setting file
    Updated the XML editor for the changed debug options
    I think that all
    NOTE: users of previous version, if doing an upgrade over previous install, you'll need to change the three debug settings in all you setting xml's. Old style was just T/F but now uses 0,1,2 for levels 0=OFF,1=Minimum, 2=Full
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #370
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I'll also add to work around cmds that take a while to process in rr, ie weather on the first load or gps, to use rr's delayexec;1;xxxx cmd to allow the plugin to resume your music, by then a second has gone by and rr will process the cmd you wanted to like normal. I have actually changed the gps cmds in the new setting XML to reflect this. And if what you want rr to execute is more than one cmd then make a cmd for it in the exectbl file and just use the single cmd in the delayexec one.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 04:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 09:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 10:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 11:26 AM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 09:20 AM
