Page 39 of 48 FirstFirst ... 2930313233343536373839404142434445464748 LastLast
Results 381 to 390 of 472
Thread: DFXVoice – A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #381
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    I am having trouble getting the new version to run correctly probably my own doing but don't know what
    I was running version 1.0 with the latest RR & DFX skin versions on XP SP3. At first I installed the new version of DFXVoice on top of 1.0.0. I copied over the new skin files added the lines to the skin exectbl file etc.
    It installs,loads and works but the RRMedia part did not work for me. I tried "Play Rock Music" "Play Rap Music" etc. If I understood correctly It should be whatever Genre's that RRmedia displays them as.
    So I went into the plugin settings and turned on "Use RRMedia DB" in there. I know before that had to be disabled but could not get it to work with it off so I turned it on. If I have that on, DFXVoice does not do anything if I press the microphone. In the debug it says "DFXVoiceservice.exe is NOT running" after I press the microphone.
    On another note "Scan Music collection" does not want to work either with or without changing the setting of the "Use RRmedia DB" button. In the debug it says "Warning: Blank Music XML file could be found.
    I tried doing fresh installs of DFXVoice by unregistering then runing the uninstaller deleting the folder in the My documents\*\*\ etc/
    Now I went ahead and installed an older version of DFXVoice (0.61) over on to top of the new version and the "Scan Music collection" was working again.
    What am I doing wrong getting the new version to work properly?
    Shuttle Sk41g,Xp Pro,2.4ghz Amd,250gb Wd 7200 Rpm Hd,2gb DDR Ram,Ati Radeon 9250,Sound blaster external,CarPC Pro v.2.5d SD Controller,7" Xenarc 700TSV
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  2. #382
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by michaelrj9
    Correct, it gets the genre listing from the database and creates the cmds from there.
    When you switch that setting, a restart of RR is necessary unfortunately if done in the skin...
    Not sure, but you could attach a log from the plugin.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #383
    Feb 2005
    Huntsville, AL
    Not sure why it's not working then.
    When you switch that setting, a restart of RR is necessary unfortunately if done in the skin....
    Done that multiple times
    This one?
    The first one is with RRMedia enabled
    The 2nd one is with it disabled
    Attached Files Attached Files
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  4. #384
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    What size is your System.Data.SQLite.dll file in the main plugin folder? Should be ~853kb, if its over a 1mb then the installer needs fixing as it installed the x64 one instead of the x32 version. And that would probably be the reason that the PI [EXE] is crashing in the background.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #385
    Feb 2005
    Huntsville, AL
    just checked and it is 853kb
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  6. #386
    Feb 2005
    Huntsville, AL
    Just a little update, it still don't work on my carputer with xp but I tried it on one of my home Windows 7 machines and it installed but then it crashed once RR finished loading up but it said I did not have the .net 4.0 installed then I installed it and it and DFXVoice works good on the Windows 7 machine 32 bit.
    When I first tried to install the new version of DFXVoice on my carputer XP it knew .net 4.0 wasn't installed and it told me to install it before it even would install it on the xp machine. Just was wondering if I could be missing something with the .net and thats why it crashes but remember it only crashes when Use RRMedia is enabled.
    Another update after I saw it was working on my home Windows 7 machine I got brave and installed the mobilephone.net plugin to see if it would work. I thought before (somewhere in this thread) someone was saying it would crash with DFXVoice and Windows 7.
    I did not do a lot of testing, I made a couple calls, used DFXVoice a little restarted RR Maybe 5-7 times and it seems like it was working. DFXVoice did crash once like the second time I restarted RR but not sure if that was just a fluke or has something to do with mobilephone or something else.
    Can anyone else confirm if mobilephone.net plays nice or not with DFXVoice now?
    I was using latest bluesoleil 8.X On Windows 7 32 bit.
    I would still like to figure out why it won't work on my XP puter as the computer don't have enough power to run Windows 7 smoothly.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  7. #387
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I'll have to db check on an XP install and see if see any crashing. Not likely, but see if there are any updates for .net4 that causing it?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #388
    Feb 2005
    Huntsville, AL
    No Wndows updates available on my XP machine. I also did a new Windows XP install with a bare install of Flash, Winamp, RR, DFX 5.1.2 & DFXVoice & Windows updates and still the same problems.
    I also wanted to clarify from my previous post on my Windows 7 machine it does work BUT the "Scan Music Collection" still doesnt work on the install either.
    Michael
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  9. #389
    Feb 2005
    Huntsville, AL
    Blue, I have a couple questions before I go crazy trying to figure out what is going on.
    Should the "Scan Music Collection" still work? Does it make a difference if the Use RRMedia DB is enabled or disabled to get the Scan Music Collection to work? I have tried it either way on XP & Windows 7 with no luck.
    Now im talking on a fresh install of DFXVoice (old verision was uninstalled and folders in My Docs & Program Files were removed)
    After I install the new version of DFXVoice I immediately go go the sample skin folder and copy over the new skin files into the DFX skin folder, copy the DFXVoice_Settings.xml file to My Documents\RideRunner\Plugins\DFXVoice\ and overwrite the other one whick is about half the size of the new one which is about 50kb or so. So the one that was overwritten was like 25kb or so. I have tried NOT copying over the file and still don't work.
    Now I am not sure where I need to put the lines in the SKIN EXECTBL.ini FILE. Where in the DFX Skin Exectbl.ini should I put them? top, bottom under any specific heading in the file? I tried a few different areas with no luck.
    Like I said in a previous post I tried on a home puter running Windows 7 Ultimate 32 bit and seems to be working. That computer I already had RR on it 9-1-12 version with DFX skin 5.1.2 with no updates done to the skin (it shows last update was (3-31-12) Now I don't know if I had a previous version of DFXVoice installed. I should of checked but didn't. I installed the latest version of DFXVoice and did nothing else. I did not copy the new skin files, DFXVoice_Settings.xml or add the lines to the DFX Skin Exectbl.ini file. This computer seems like it is working with the commands like "Music" "What Time is It" "Play Artist XXX" and "Play XXX Music"
    On my car PC XP I tried this was of installing and like the ones listed above with no luck.
    Do you think this can be a hardware isue causing my problems?
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  10. #390
    Jun 2002
    Virginia
    Finally got around to installing this great plugin. Everything seems to be working well except I am unable to get the XML editor to work. If I edit or add any commands and hit apply I get an unhandled exception error "Object reference not set to an instance of an object" with the notes shown on the attached. In addition, the save and update road runner buttons remain grayed out. It happens on both machines on which I have loaded the plugin. XP SP3 - Up to date DFX - 09/01 RR.
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 04:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 09:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 10:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 11:26 AM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 09:20 AM
