Page 40 of 48 FirstFirst ... 30313233343536373839404142434445464748 LastLast
Results 391 to 400 of 475
Thread: DFXVoice A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #391
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    I'll have to db check on an XP install and see if see any crashing. Not likely, but see if there are any updates for .net4 that causing it?
    There are no updates through Microsoft updates
    But I got a little closer to getting it to work but don't know what I am missing.
    I made a little video showing what happens and hopefully you can tell me what I am missing.
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  2. #392
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by michaelrj9 View Post
    I also wanted to clarify from my previous post on my Windows 7 machine it does work BUT the "Scan Music Collection" still doesnt work on the install either.
    Scan music does not work for me on XP.
    So I went into the plugin settings and turned on "Use RRMedia DB" in there. I know before that had to be disabled but could not get it to work with it off so I turned it on. If I have that on, DFXVoice does not do anything if I press the microphone.
    Same here. I am unable to trigger DFXVoice to listen with Use RR Media DB turned on. I have tested multiple times, closing RR after each change of the setting.
    By the way, Blue, a belated thank you for fixing the button editor. I love that thing!
  3. #393
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by kbreeden View Post
    If you get a chance try downloading microsoft expressions encoder sp1 from Microsoft and see if DFXVoice works. It did for me but don't know why See the video I posted above to see the results.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  4. #394
    Raw Wave
    Jun 2002
    Virginia
    Will do. I did see the vid. Very helpful. Will download expressions and see what happens. Will not be able to do until tomorrow unfortunately.
  5. #395
    Raw Wave
    Jun 2002
    Virginia
    I can confirm that installing Microsoft Expression solves the problem of not being able to trigger DFXVoice to listen if "Use RRMedia database" is selected. It does not solve the issue of Scan Music Collection not working.
    Blue, am I correct that muting of music, etc., should occur when I trigger DFXVoice to listen? It is not muting for me.
  6. #396
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Hmmm... That's kinda odd, I'm not using any part of that but I do have it installed here because RRPandora required it to use it, and maybe just having it installed when I compile the plugin, it uses the newer files from that which aren't in the STD .net install and causes crashes... I wonder if/how I could add that check to the installer.
    The scan music collection is null of course if you have the Use RRMedia db option on, but I should add a check for that when someone has it on and tries to use that button. And if its off, it not working b/c it can't find the blank template music xml's it uses on scans, which is an installer issue. The files are not being put in the right places.
    Correct, muting of current audio source is done by the plugin when triggered. PI debug Log?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #397
    Raw Wave
    Jun 2002
    Virginia
    Muting is working fine now.
    Any idea why I might be having trouble with the XML editor per post #390?
  8. #398
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I'll take a look at that and see what I can fnd.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #399
    Raw Wave
    Jun 2002
    Virginia
    Thanks, Blue. So you know I just installed everything onto a third computer (XPSP3, 09/01 RR, up to date DFX) and have the same issue (XML Editor throwing exception when I hit apply). I've messed around with it some more and found that it only happens on the Global and Screen Commands screen. I can go to any of the other screens, e.g., the music scanner screen, and all works fine.
  10. #400
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    After I install the new version of DFXVoice I immediately go go the sample skin folder and copy over the new skin files into the DFX skin folder, copy the DFXVoice_Settings.xml file to My Documents\RideRunner\Plugins\DFXVoice\ and overwrite the other one which is about half the size of the new one which is about 50kb or so. So the one that was overwritten was like 25kb or so. I have tried NOT copying over the file and still don't work.
    FYI, the default settings XML should be the plugin defaults, the one found in the sample skin DFX5Plugins\DFXVoice is the skin specific settings that override the defaults if found and would be located in the same location as was in the sample skin folder. What you did is OK only if say the only skin your running is DFX.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 05:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 10:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 11:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 12:26 PM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 10:20 AM
