Ok, I understand now. I saw that same file in C:\Users\Puter1\Documents\RideRunner\Plugins\DFXVo ice\ and assumed it must of went there but couldn't understand why the installer wouldn't of put the right one there :)
Not sure if you had a chance to look at anything yet but I did more playing around with it. This has nothing to do with the XML file location (it acts the same either way) but I did more playing around with DFXVoice and this is what happens on my computers.
Let me see if I can explain this without it getting confused. I am just talking about trying to execute voice commands. As you already know the XML editor has the problem saving-editing-creating Global/screen commands & the "Scan Music Collection does not work" with "Use RRMedia DB" disabled.
On Windows 7 32bit
(1) With NO Microsoft Expression installed with "Use RRMedia ENABLED" = Don't work (Won't listen for voice commands)
(2) With NO Microsoft Expression installed with "Use RRMedia DISABLED" = it will listen for voice commands but will not respond to "play artist xxx" it does respond to "what time is it" Now I know the RRMedia shouldn't work but if I say anyways "Play rock music" it loads rap music. If I say play rap music it works right. Sometimes it just thinks I said music etc. It has a mind of its own :)
(3) WITH Microsoft Expression installed with "Use RRMedia ENABLED" it works good as far as I can tell.
(4) WITH Microsoft Expression installed with "Use RRMedia DISABLED" it will listen for voice commands but will not respond to "play artist xxx" it does respond to "what time is it" and it also has a mind of its own if you try RRMedia commands which shouldn't work anyways :)
Windows 7 64bit
I couldn't get it to listen for voice commands before no matter what I tried (With or without Microsoft Expression)
but then I put in the XML file into the DFX\Plugin\DFXVoice\ and now it will listen but not respond to "play artist xxx" "play xxx music"
Hope this helps with you trying to troubleshoot the problem
Thanks for a GREAT plugin!!
P.S
Is there a way to use the search feature "all" or at least by or title or filename in RRMedia via voice? like if I wanted to search for the word "New York" it would list everything with new york.
