Page 41 of 48 FirstFirst ... 313233343536373839404142434445464748 LastLast
Results 401 to 410 of 475
Thread: DFXVoice A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #401
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    FYI, the default settings XML should be the plugin defaults, the one found in the sample skin DFX5Plugins\DFXVoice is the skin specific settings that override the defaults if found and would be located in the same location as was in the sample skin folder. What you did is OK only if say the only skin your running is DFX.
    Ok, I understand now. I saw that same file in C:\Users\Puter1\Documents\RideRunner\Plugins\DFXVo ice\ and assumed it must of went there but couldn't understand why the installer wouldn't of put the right one there
    Not sure if you had a chance to look at anything yet but I did more playing around with it. This has nothing to do with the XML file location (it acts the same either way) but I did more playing around with DFXVoice and this is what happens on my computers.
    Let me see if I can explain this without it getting confused. I am just talking about trying to execute voice commands. As you already know the XML editor has the problem saving-editing-creating Global/screen commands & the "Scan Music Collection does not work" with "Use RRMedia DB" disabled.
    On Windows 7 32bit
    (1) With NO Microsoft Expression installed with "Use RRMedia ENABLED" = Don't work (Won't listen for voice commands)
    (2) With NO Microsoft Expression installed with "Use RRMedia DISABLED" = it will listen for voice commands but will not respond to "play artist xxx" it does respond to "what time is it" Now I know the RRMedia shouldn't work but if I say anyways "Play rock music" it loads rap music. If I say play rap music it works right. Sometimes it just thinks I said music etc. It has a mind of its own
    (3) WITH Microsoft Expression installed with "Use RRMedia ENABLED" it works good as far as I can tell.
    (4) WITH Microsoft Expression installed with "Use RRMedia DISABLED" it will listen for voice commands but will not respond to "play artist xxx" it does respond to "what time is it" and it also has a mind of its own if you try RRMedia commands which shouldn't work anyways
    Windows 7 64bit
    I couldn't get it to listen for voice commands before no matter what I tried (With or without Microsoft Expression)
    but then I put in the XML file into the DFX\Plugin\DFXVoice\ and now it will listen but not respond to "play artist xxx" "play xxx music"
    Hope this helps with you trying to troubleshoot the problem
    Thanks for a GREAT plugin!!
    P.S
    Is there a way to use the search feature "all" or at least by or title or filename in RRMedia via voice? like if I wanted to search for the word "New York" it would list everything with new york.
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  2. #402
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I actually have a update that I'll be posting soon that has a couple of fixes. The reason that none of the play artist xxx would work w/o the use rrmeda option is that the blank xml templates it looking for when doing a scan to build them,where missing from the installer (oops!).
    Currently there is only a hacked up way of doing a voice search that I came up with a while back but now that RRMedia is incorporated, it could be done much cleaner right in the plugin. I will work on adding this feature as it would be nice to have as well.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #403
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by michaelrj9 View Post
    As you already know the XML editor has the problem saving-editing-creating Global/screen commands.
    Michael, I'm not sure what you mean by this. Are you also getting an exception error when trying to use the xml editor like I describe in post 390?
    Blue, any thoughts on my post 390 issue?
  4. #404
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by kbreeden View Post
    Yep that's what I meant.
    Hopefully that will be one the the fixes Blue was talking about.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  5. #405
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Exclamation New Version
    v1.1.0.1 (9/23/2012)
    Fixed the XML editor when hitting apply on the Global & Screens Commands Tab
    Fixed the installer, was missing the blank Music & Songs XML templates (oops!)
    Fixed 64bit issue
    Added installer check for C++ 2010 SP1 Redist files
    Added Error check for the scan music if Use RRMedia option is on
    Added Error screen notification that when changing the Use RRMedia Db option requires a restart of RR
    Don't be surprised if the installer asks you to install another requirement as i found the reason why installing the M$ Expression seemed to fix the underlying issue. Just couldn't understand why that would have to be installed when I don't use anything from it, and didn't like to have users install something to fix an issue when I'm not even using it.
    See first post...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #406
    Feb 2005
    Huntsville, AL
    Fixed 64bit issue
    See first post...
    I'm drooling... But don't see it yet.
    But i'll be on top of it as soon as I see it
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  7. #407
    Raw Wave
    Jun 2002
    Virginia
    Woo hoo, Blue. The XML editor is working great in the new version. Thanks!
  8. #408
    Feb 2005
    Huntsville, AL
    Quick update but will play around with it more later today.
    I uninstalled Microsoft Expression. I was installing new version of DFXVoice and it told me I needed C++ 2010 SP1 (whch I did)then I went to install the new DFXVoice and it gave me an error saying it couldn't delete a dll file. I aborted it and restarted my computer then it worked.
    Everything seems better but the scan music collection still don't work right, it starts the scan now but in 1 sec the thread 1 says it is done and thread 2 never starts.
    Will play around with it more on XP & WIN 7 64 later today but it seems like the voice commands and the XML editor is working good.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  9. #409
    Raw Wave
    Jun 2002
    Virginia
    I did not uninstall Expressions prior to installing the plugin and did download and install C++ 2010 SP1 when prompted. The plugin install proceeded flawlessly.
    ... but the scan music collection still don't work right, it starts the scan now but in 1 sec the thread 1 says it is done and thread 2 never starts.
    I'm experiencing the same thing - though I intend to use the plugin with RRMedia so there's no reason for me to do a scan.
  10. #410
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Set all the debug levels to full and run a course, attach the logs.
    @ALL
    I'd like to know if your have the MoblePhone.net plugin setup on a W7 machine and the v1.+ version of this plugin, does it still crash? Did I by accident fix that issue too??
    I'd also like get feed back on any noticeable if any lag for users that were used to the old xml database and are now trying the RRMediaDb option. I don't think I really can tell which its using...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 05:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 10:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 11:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 12:26 PM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 10:20 AM
