Page 47 of 48 FirstFirst ... 373839404142434445464748 LastLast
Results 461 to 470 of 472
Thread: DFXVoice – A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
  1. #461
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    I will try it in the next few days. Right now I'm away laying hardwood floor for parents.
    Shuttle Sk41g,Xp Pro,2.4ghz Amd,250gb Wd 7200 Rpm Hd,2gb DDR Ram,Ati Radeon 9250,Sound blaster external,CarPC Pro v.2.5d SD Controller,7" Xenarc 700TSV
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  2. #462
    Jun 2002
    Virginia
    New XML editor is working for me.
  3. #463
    Jun 2002
    Virginia
    Blue, sorry to keep bothering you, but I'm wondering if you have had any luck getting the "select" function to work. It would be great to be able to say "Go to First Song" and then say "Select" to start playing the song once it gets there.
  4. #464
    Feb 2005
    Huntsville, AL
    XML editor works great.
    Thanks Blue...
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  5. #465
    Feb 2005
    Huntsville, AL
    Blue, I'm not sure if you know but it seems like the 64bit install is still needs a little work but the 32bit seems fine.
    On a fresh Windows 7 64bit I went to install DFXVoice and it said I needed visual C++ 2010 x64 so I downloaded it and then installled DFXVoice and it installed fine but there was a "pop under" when I minimized RR saying DFXVoice needs .net 4.0 so I downloaded that, but DFXVoice is doing the same thing like before and will not listen if you press the microphone.
    So I installed Microsoft expression codec and it is working again.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  6. #466
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Same thing for me on vista 32bits
  7. #467
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by pierrotm777 View Post
    I thought that seemed like it was fixed with the last update (on XP anyways) as I uninstalled Microsoft Expression before instaling the new version at it worked. Maybe even though I uninstalled it maybe it left in some files still to get DFXVoice to work. Or maybe there is a difference between XP & Vista-Windows 7 installs. Hopefully kbreeden can shed some light on this. I thought recently he did a fresh install on XP and see if he had to install Microsoft Expression to get the new install to work.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  8. #468
    Jun 2002
    Virginia
    Quote Originally Posted by michaelrj9 View Post
    I did not have to reinstall MS Expression to get it to work after a fresh install of XP 32bit and update to SP3. My recollection is that even though the Microsoft Visual C++ 2010 program had already been installed on my machine by the time I got around to installing DFXVoice, the DFXVoice installer prompted me to install it and I did. All worked fine.
  9. #469
    Feb 2005
    Huntsville, AL
    Thanks for the info,
    On my Win 7 64bit fresh install it didn't work until I installed Expressions. I did all the avaiable MS updates with no luck. It is a bare RR install and no other plugins except the ones from DFX skin.
    I thought I also did a XP fresh install and it worked with but wasn't positive, that's why I thought i'd ask.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  10. #470
    Mar 2007
    Quick update but will play around with it more later today.
    Everything seems better but the scan music collection still don't work right, it starts the scan now but in 1 sec the thread 1 says it is done and thread 2 never starts.
    I am having the same scan music collection issue. Is there a remedy?
    (Windows 7 32 bit, mobilephone.net is uninstalled)
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 04:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 09:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 10:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 11:26 AM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 09:20 AM
