Page 1 of 48 1234567891011 ... LastLast
Results 1 to 10 of 472
Thread: DFXVoice – A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Thumbs up DFXVoice – A Voice Control Plugin [v1.1.0.1 Released 09/23/2012]
    Feel free to use the button below to show your appreciation for the many hours I have already spent and will probably continue to spend till this plugin is 100% done
    First and foremost, thanks goes to Jebus and RRVoice, for the inspiration to get one of our several attempts to create a working voice recognition command plugin.
    Note: This is a General usage plugin, not tied to any skin name, just called DFXVoice b/c I didn't want to have to go thur the code and change all of the commands after I decieded to make it not tied to just one skin.
    Now, for the details of this plugin:
    Windows 7 Compatible
    Written in .Net
    All files are in XML
    Editor for the XML files
    Built in screen Overlay(with option to be animated)
    Built in Music Tag Scanner (background)
    Fast n Efficient / Multi-threaded
    Multiple command mode
    Utilize RRMedia’s Db Option
    All settings changeable thur the plugins setting screen
    Extremely Fast startup, plugin startup done in background!
    *=Currently Working on
    **=Future feature
    Operates in the same manner as RRVoice with the following additions:
    Direct Play Command Set
    “Direct Play ”, this statement when spoken, after a very short pause and sound notification, allows you to play a song by either saying Song “” or a song version from a particular album by saying “Album ” and then “Song ”
    Some examples are:
    Direct Play ACDC (wait for ok to continue sound) Song Thunderstruck
    Direct Play ACDC (wait for ok to continue sound) Album The Razors Edge (wait for ok to continue sound) Song Thuderstruck
    Direct Play ACDC (wait for ok to continue sound) Play Album The Razors Edge
    Multiple Song Title match Selection This comes in handy when you just play a whole artist and then latter want to jump to a song that may appear on several different albums like one might be the studio version and another one, a live version, ect. It will display a list screen, and then you can just select the one you want to hear.
    Additional Music commands features
    Play Song xx and Direct play song command allow for both the real and AKA song titles The Tag's Title need to have a (xx) format .
    . Example: ACDC's song "For Those About To Rock"
    . Song Tag Tile: "For Those About To Rock (We Solute You)"
    . You can say either: "For Those About To Rock" or "For Those About To Rock We Salute You"
    Multi Command mode
    When in this mode, you can issue several commands. The only limitation is that you wait till it finishes processing the previous spoken command.
    Wake Command Option
    This allows you to wake up DFXVoice and listen for commands. This was something that was added but at the current time, not really happy with its workings.
    ************** Requirements **************
    .Net 2.0
    Win XP - see below
    win 7 - None
    Good Mic
    Done at least one speech training
    ************* Install Notes *************
    Windows 7 speech setup
    Start Menu > Control Panel > Ease Of Access > Speech Recognition > Advanced Speech Options(far left) Uncheck the "Run Speech Recognition at startup" checkbox
    If not already done so, select your mic to use with speech(Advanced... btn)
    If the speech is already running, close it
    Windows XP speech setup
    Install either:
    a) SAPI SDK 5.1
    b) Install the Speech Recognition found in Office 2003
    * The (b) option above is the better option if you have it available to use, as it has a slightly newer speech recognizer engine than the 5.1 SDK has
    start Menu > Control Panel > Speech Recognition Tab Profile Settings button: Move the 'Accuracy vs. Recognition Response Time' bar to the far right. Uncheck the Background Adaptation checkbox (don't need it to constantly add the road noise to the profile! )
    Plugin usage
    You'll need to either:
    a) create button(s) to execute the cmd "DFXVoice"
    b) Add the "DFXVoice_Status" indicator to some screens, and by simply clicking it, will activate it
    c) Start up the XML Editor(plugin folder\Util) Wakeup commands tab, Enabled-Yes, set a listen for phrase apply & save
    To cancel listening you can either:
    a) re-execute the "DFXVoice" cmd
    b) Click the overlay
    c) say "Cancel Voice" (if using the wakeup cmd option, this will just put it back to sleep)
    Default Plugin indicator status's:
    Red Mic - Plugin loaded and not listening
    Orange Mic - Wakeup cmd option is enabled and its listening for the wakeup cmd to be spoken
    Green Mic - Listening and ready for your command(s)
    There is a Multi command mode, which in the default install, you can start by saying "Multi", you'll get the command recognized sound, overlay will disappear. Now just give it your voice commands, waiting for the previous one to be recognized before giving the next one
    DL's:
    Beta 0.5.0-19
    Beta 0.5.1-56
    Beta 0.5.2-2
    Beta 0.5.3-86
    Beta 0.6.1-191
    v1.0.0.0-185
    v1.1.0.0-39
    v1.1.0.1-20+
    Attached Files Attached Files
    Last edited by Blue ZX3; 10-04-2012 at 09:18 PM. Reason: Post update, version update
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Carwings Main Menu Screen Shot (Animated overlay was turned off for this shot)
    Name:  Main Screen Shot.png
    Carwings Plugin Setting Screen Shot
    Name:  Carwings Setting Screen Shot.png
    Included XML Editor/ DFXVoice Config
    Name:  DFXVoice XML Editor Screen Shot.png
    The Live Debugger
    Name:  Live Debugger.png
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Seeing that I am converting this from the original made plugin in VB6 to VB.Net, I am now almost back at the same operational point that the VB6 one was at. Coding is going good, and hopefully, I should be able to start posting some testing versions.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    If i understand the plugin can work only with the DFX skin ?
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i think this will be the all skins version, just named dfxvoice,,, this will allow all skinners , users to use this plugin,,,
    i think the version that comes with dfx ,, will be more intergrated to dfx skin and its functions
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Constant Bitrate 4ofakind's Avatar
    Jul 2009
    Eagerly awaiting download link.
    Mal
    Vehicle: [100%] 1995 C 1500 ECLB
    Gear: [90%]
    Build: [80%] PC & Chassis, Worklog
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by pierrotm777 View Post
    Quote Originally Posted by carputer1 View Post
    I have added a note to the first post to clearify this confusion. Im not thinking of doing two plugins, just the fact that I now have another PI to manage is bad enough, without adding a modified version of this on top of that big pile now..
    Quote Originally Posted by Enforcer View Post
    speachless
    Wow...I know it takes a lot to get that kinda feedback from you, and you haven't even played with the plugin yet. Thanks!
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Jun 2002
    Virginia
    speachless
    Wow, Blue, that's something coming from Enforcer.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by kbreeden View Post
    Don't get too excited, it was just a play on words to get a mucky paw print in the thread so I get notifications.
  1. Plugin Manager control of plugin Config
    By lambosprit in forum RR Plugins
    Last Post: 10-17-2010, 04:46 PM
  2. Better Voice Control Plugin?
    By HiJackZX1 in forum CF Plugins
    Last Post: 11-21-2008, 09:39 AM
  3. Voice Tunes voice control software
    By kelmk in forum Software & Software Development
    Last Post: 03-18-2008, 10:29 PM
  4. Replies: 1
    Last Post: 03-15-2008, 11:26 AM
  5. New voice itunes voice control software!
    By The Don in forum MacCar
    Last Post: 03-25-2005, 09:20 AM
