Page 2 of 9 FirstFirst 123456789 LastLast
Results 11 to 20 of 84
Thread: New Weather Plugin Beta
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You can add the state or country to the town/city.
    For Wembley I had to do wembley+uk otherwise it sent me info on Wembley, WA (That's about as far as you can get from my wembley.)
    So for Miami,AZ I would assume Miami+AZ would get you the correct data.
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Google Weather could be used for a basic weather plugin, the current plugin shows a lot more information (humidity, pressure, chance of precipitation - most for day and night times).
    @PhilG: Never seen this - if you install RR using the installer you should be able to just overwrite the dll with this one and it should work. The path you posted had a "|" in it which doesn't seem right ( C:\ProgramFiles\RideRunner\Plugins|Weather\ Weather.dll )
    Ride Runner RR's Myspace
  3. #13
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    Quote Originally Posted by guino View Post
    So does google for today....
    Blessed are the "cracked" for it is they who let in the light.
  4. #14
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I guess the question, would there be any advantage of using Google weather (as far as data), that has less information, compared to the new dll that is already working, with far more information available? As for the setup for the new one, go to the site, sign up for a key, and put it in your rr.ini. Takes 2 minutes, and has to only be done once.
    My Fiero Build Thread
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well a pluigin for google could always be done.
    No harm in having more than one plugin for weather, then if one falls over you have a backup.
    Or code both sites into the plugin and have a switch that lets the user decide which source to use.
  6. #16
    Feb 2008
    Ireland
    Thanks guino, much appreciated!
  7. #17
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have found this code into a FREEICE's plugin example than run very well for me !
    <code removed> Don't publish non-open source code</code removed>
  8. #18
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It's true, no harm in having more than one plugin... the google weather has about the same info for "today" just lacks some info for the next days (so the current 5 day screen would look somewhat empty - but making a new forecast screen should look ok).
  9. #19
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by bhitman View Post
    Works good so far, but there is a littel "bug" in the current temperature: Today we've 3.3C, but the plugin generates in the myweather.xml a data of 33C (without comma/point)...
    Can you please try the version I just uploaded to the first post? I hope to have fixed this bug now.
  10. #20
    Aug 2006
    Hong Kong
    Hi, does the "weatherdegrees" is not necessary anymore? Because I input this field in value of "C" and set the "weatherunits" in "WORLD", finally the display is XX C C
  1. 05/27/08 Road Runner Official Beta, Weather Fixed!
    By JohnWPB in forum Road Runner
    Last Post: 09-02-2008, 07:06 AM
  2. Weather Plugin
    By f1anatic in forum Centrafuse
    Last Post: 05-10-2008, 10:35 PM
  3. weather plugin
    By nadforever in forum Centrafuse
    Last Post: 06-11-2007, 11:15 AM
  4. Weather Plugin
    By Thor_PT in forum CF Plugins
    Last Post: 03-13-2006, 06:54 PM
  5. Weather Plugin
    By veetid in forum CF Plugins
    Last Post: 09-22-2005, 02:02 PM
