Page 7 of 9 FirstFirst 123456789 LastLast
Results 61 to 70 of 84
Thread: New Weather Plugin Beta
  1. #61
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    So the "Program files\ride runner\plugins" & "user\usersdocuments\ride runner\plugins" have the same size & have the same amount of files & folders.
    This is TOTALLY NOT correct!
    Very simple, in a correctly written plugin:
    Program files\ride runner\plugins\xxx = is for DLL's,EXE's, and Docs of the plugin, no setting files or files created by the plugin should reside here
    user\usersdocuments\ride runner\plugins\xxx = is where plugins "should" write/create any needed files and should NOT include DLL's, EXE's
    For the record.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #62
    Jan 2012
    UK
    I AGREE 100% it's NOT the correct way, but this method got rid of a lot of my errors. Some of the plugins I use look like they have not been touched in a couple of years, so with that I try anything possible to get them working.
  3. #63
    May 2008
    Bend, OR
    Thanks that fixed the issue with switching cities, the zip serach in dfx is still not happy. However at least this works yay!
  4. #64
    MySQL Error
    Oct 2004
    Quote Originally Posted by GizmoQ View Post
    Chill Blue, you're starting to sound like me.
    I quit complaining cause my issues never get fixed. I only update my build every 3-4 months cause it takes me that long to rewrite all my RRCode given the "improvements" (deletions) of each new RR release. I realized the .xml files had to be deleted from non-profile mode installs so I just wrote an autoit script and added it to the weather call. If I had moaned about it we'd have had ten days and 50 posts about "did you test it in Carwings" and "It ain't broke".
    I'm just fed up with the profile mode mafia and fixing things by eliminating backward compatibility!
    you're all wrong...
    this xml problem, has NOTHING to do where the XML file is, in a profile or in the same folder as rr... the XML was being written wrong... go back a version
    do a search for a city... like just put in "ORLANDO", then look at the xml... then put in your city, directly, such as Lansdale, PA
    then look at the XML... you will see a bad file..
    also... Q "YOUR" issuess as you call them , not that anyone knows of any, dont get fixed, if you dont ask them to get fixed
    there are 2 more bugs i found in weather, i fixed them too.. i didnt post any update file... this plugin just has a bunch of bugs, i never really looked at it before, till
    a few people complained, to me specificlly, and i went to work on it...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #65
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Only b/c you didn't write it means that it should be rewritten BY YOU...just like all the other "xxx needs to be rewritten, bla bla" If we had the time that you seem to have for working on RR then maybe someone else would have rewritten it, but then it still wouldn't be right b/c ........
    Very strong words from guy who can't fix DFXVoice issue which I and others report many times day one when first beta released, no offence intended.
    I don't know anything about code but I know Mitch is really good what he does, so if he say something needs rewritten that only mean there is way to do it better.
    It's really sad to see when one who spend LOTS of time to make RR better, get the most **** and whine.
    Many issues in weather plugin is fixed while you guy tell your opinions here.
  6. #66
    MySQL Error
    Oct 2004
    I have updated the file...
    fixed...
    Date issues with regions that use . (dots/periods) in their date
    translation issue with . in the dates (no more translating them)
    also TRANSLATION is obsolete persay, WeatherUndergound, returns the textual data (ie days of week) in your region's lang (provided you have that set in OS)
    my advice is rr.ini setting for language should be
    weatherlanguage=
    NO translation
    but you still can have some things translated... like if you want to change "Monday" to "Mon"
    then make your own custom translation file
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #67
    MySQL Error
    Oct 2004
    Thanks to RTgreen1 we have a Weather RRCONFIG plugin
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #68
    MySQL Error
    Oct 2004
    Download updated "Update ONLY" installer, link in 1st post
    ill fix the language box, to allow none later...
    ok i fixed it now...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #69
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    WONDERFULL job !!!
    Thanks for this new rrconfig option !
  10. #70
    Nov 2006
    Russia
    Quote Originally Posted by mitchjs View Post
    fixed...
    Thanks a lot! It's working now!
  1. 05/27/08 Road Runner Official Beta, Weather Fixed!
    By JohnWPB in forum Road Runner
    Last Post: 09-02-2008, 07:06 AM
  2. Weather Plugin
    By f1anatic in forum Centrafuse
    Last Post: 05-10-2008, 10:35 PM
  3. weather plugin
    By nadforever in forum Centrafuse
    Last Post: 06-11-2007, 11:15 AM
  4. Weather Plugin
    By Thor_PT in forum CF Plugins
    Last Post: 03-13-2006, 06:54 PM
  5. Weather Plugin
    By veetid in forum CF Plugins
    Last Post: 09-22-2005, 02:02 PM
