View Poll Results: Do you think to use this plugin ?
Voters
9. You may not vote on this poll
  • yes
    9 100.00%
  • no
    0 0%
Page 4 of 9 FirstFirst 123456789 LastLast
Results 31 to 40 of 81
Thread: RRSygicDrive (Sygic Fully Embedded into RideRunner)
  1. #31
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Put your plugin into the folder 'C:\Program Files\RideRunner\Plugins\RRSygicDrive\' .
    Run the command RunMe1st.cmd for register the plugin
    Put the files founds into the folder C:\Program Files\RideRunner\Plugins\RRSygicDrive\skins\' into your skin folder (D:\Program Files\Ride Runner\Skins\Carwings_Dynamic_Lite\).
  2. #32
    Aug 2006
    Columbus, OH
    Quote Originally Posted by pierrotm777 View Post
    This is my second version of this plugin (first post is updated)
    In this new version i have added:
    1-events
    2-turn by turn next instruction with panels indicators
    3-speedlimit panels
    Hi Pierrotm777, Thank you for a very nice plugin. It seems that's coming alone.
    One suggestion that I have, have you thought on the commands section to add a mute or lower the default volume? The reason I ask is because I currently have a setup with with MS Speech where I send the sound out to a second stream audio and reinject that into an input on my main stream audio card. All that to be able to lower or mute the volume of the voice directions while I'm on the phone using handsfree Mobilephone plugin from Lambo. This setup I made works very well, but it will be pretty nice if I could avoid all this process.
    Thanks again for your excellent work!!!
  3. #33
    May 2008
    Bordeaux, France
    Quote Originally Posted by jarepa View Post
    In the actuel API, the mute or set volume option doesn't exist or i had not found it , but you see into the Tools folder , i have added a zip file.
    These dll patch the official drive.exe file (please, create a backup before to use this option) and add two RR events NAVPAUSE and NAVRESUME each time that the GPS say a sentence !
    So, in your Exectbl.ini file, just add these two lines:
    "NAVPAUSE","SETVOL;Winamp;50"
    "NAVRESUME","SETVOL;WINAMP;255"
  4. #34
    Aug 2006
    Columbus, OH
    Excellent, NAVPAUSE / NAVRESUME is what I was looking for. That will work for me. Thank you very much!!!
  5. #35
    May 2008
    Bordeaux, France
    If you like this plugin , it was my pleasure to help you !
    If you have a need , say me what !
  6. #36
    Apr 2010
    hi, is there a UK map available.
    thanks daveo
  7. #37
    Feb 2011
    i can only start the plugin, when i remove the folder from the plugin section.
    when the folder "RRSygicDrive" is in the plugin section and i try to start, the cursor is moving down to the left - nothing else happens.
    what could it be?
  8. #38
    Aug 2006
    Columbus, OH
    Quote Originally Posted by daveo1000 View Post
    thanks daveo
    Sure there's one for Europe, you can get it here:
    http://www.sygic.com/en/business:buy-now
    However be prepared to pay 169 Euros, since here at mp3.com car forums we do not support piracy or illegal software downloads behaviors.
    Just be aware about our rules around here. Thank you.
  9. #39
    May 2008
    Bordeaux, France
    thanks daveo
    Yes, with the europe version
  10. #40
    May 2008
    Bordeaux, France
    Quote Originally Posted by technorocka View Post
    what could it be?
    I am not certain that is an plugin issue .
    1-What skin do you use ?
    2-The plugin must to be in the C:\Program Files\RideRunner\Plugins\RRSygicDrive\ folder . I haven't tested the profile mode option
    3-Did you have changed something to your .ini file ?
    May be do these steps!
    1-stay the plugin where it was installed by you firstly !
    2-unregister it with the 'UnRegister.cmd' command.
    3-put your plugin into the folder 'C:\Program Files\RideRunner\Plugins\RRSygicDrive\'
    4-register it with the 'RunMe1st.cmd' command
    5-copy the screens files into your skin folder
    6-edit the .ini file manually for these two lines
    sygicpath=C:\Program Files\Sygic FLEET Truck\Drive\WindowsXP\
    sygicarguments=-no-safety -r546x415 -p1x76
    Where the first line is the path for your drive.exe software,
    and the second line is the sygic options in an other format that the fence defined for it into the RRSygicDrive.skin file, AX,1,76,546,415,"OPT_NOFOCUS"
    This is the first line that is very important !!!
    That's all
  1. Sygic Drive PC
    By _dopehead_ in forum Sygic Drive
    Last Post: 07-24-2011, 04:27 PM
  2. Sygic PNG
    By nelissen in forum GPS
    Last Post: 12-01-2010, 01:17 PM
  3. Any one use Sygic?
    By shawns in forum Sygic Drive
    Last Post: 01-10-2009, 09:13 PM
  4. help sygic
    By tezuya in forum GPS
    Last Post: 11-11-2008, 07:41 AM
  5. Sygic Drive and/or iGo
    By kfuglsang in forum Centrafuse
    Last Post: 03-25-2008, 12:23 PM
