View Poll Results: Do you think to use this plugin ?
Voters
6. You may not vote on this poll
  • yes
    6 100.00%
  • no
    0 0%
Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
Thread: RRSygicDrive (Sygic Fully Embedded into RideRunner)
  1. #41
    Apr 2010
    hi, thanks for the info, is there a trial version available that you can use in order to set it up and see what its like and wgere will i find the pluging for RR
    thanks daveo
  2. #42
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by daveo1000 View Post
    thanks daveo
    1-No trial version exist for Sygic Drive .
    2-You can to download my plugin on the first post http://www.mp3car.com/vbulletin/rr-p...ml#post1466779
  3. #43
    Feb 2011
    Quote Originally Posted by pierrotm777 View Post
    I am not certain that is an plugin issue .
    1-What skin do you use ?
    2-The plugin must to be in the C:\Program Files\RideRunner\Plugins\RRSygicDrive\ folder . I haven't tested the profile mode option
    3-Did you have changed something to your .ini file ?
    1 - The default skin for testing purposes, like this case..
    2 - installed in not profile mode and it's located in C:\Program Files\RideRunner\Plugins\RRSygicDrive\
    3 - only path was changed in plugin ini
    no success at all...
    could there be any regional restricions? i'm using w7 x86 german
  4. #44
    May 2008
    Bordeaux, France
    Quote Originally Posted by technorocka View Post
    I have just tested on xp sp3 and vista x86.
    I don't understand.
    1-What Sygic version do you have !
    2-Do you have followed my instruction ? (2 dll into the windows folder and 1 into you plugin folder:
    Installation:
    1-Copy the ApplicationAPI.dll and sdkdriver.dll files into your C:\WINDOWS folder
    2-Copy the ApplicationAPI.NET.dll into your plugin folder.
    3-Copy the skins files into your skin folder.
    4-register the plugin with the batch file 'RunMe1st.cmd'.
    5-Add this line into your ExecTbl.ini file:
    "RUNSYGIC","Load;RRSygicDrive.skin;Sygic Drive;C:\Program Files\Sygic FLEET Truck\Drive\WindowsXP\drive.exe|-no-safety -r546x415 -p1x76;Sygic FLEET"
    6-Create a command like:
    "MyApp23","BYVAR;RRSYGIC;RUNSYGIC<<RRSYGICDRIVE_RU NSYGIC"
    The SDK files aren't given with this plugin !!!
    This plugin use the 14s API version !!!
  5. #45
    Feb 2011
    hmm..
    i have done it the way your tutorial says.
    sygic version is 8.30.. latest with tts suport.
    copied the sdk files in the two folders.
    but now i see, that i've got the q version of sdk... is that the fault?
  6. #46
    Mar 2009
    how to enable local search Google for sygic fleet
    thanks
  7. #47
    May 2008
    Bordeaux, France
    Quote Originally Posted by achillealb View Post
    thanks
    This feature isn't active actually !
  8. #48
    Mar 2009
    on http://www.solocarputer.com/phpbb2/v...acc2adfaa8b985
    Busqueda en Google (funciona con conexión a internet)
  9. #49
    May 2008
    Bordeaux, France
    Don't run for my v10 fleet version
  1. Sygic Drive PC
    By _dopehead_ in forum Sygic Drive
    Last Post: 07-24-2011, 03:27 PM
  2. Sygic PNG
    By nelissen in forum GPS
    Last Post: 12-01-2010, 12:17 PM
  3. Any one use Sygic?
    By shawns in forum Sygic Drive
    Last Post: 01-10-2009, 08:13 PM
  4. help sygic
    By tezuya in forum GPS
    Last Post: 11-11-2008, 06:41 AM
  5. Sygic Drive and/or iGo
    By kfuglsang in forum Centrafuse
    Last Post: 03-25-2008, 11:23 AM
