View Poll Results: Do you think to use this plugin ?
Voters
9. You may not vote on this poll
  • yes
    9 100.00%
  • no
    0 0%
Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 81
Thread: RRSygicDrive (Sygic Fully Embedded into RideRunner)
  1. #51
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by achillealb View Post
    6-Create a command like:
    "MyApp23","BYVAR;RRSYGIC;RUNSYGIC<<RRSYGICDRIVE_RU NSYGIC"
    for the new RideRunner Dynamic Menus how modified menu.list
    rrmenu3item1 ?????????
    thanks
    If you use the Carwings Dynamics Lite skin, when you hold a buuton , that load the screen "MenuItemSet.skin"
    So, you just need to select the line PI-RRSygicDrive !
    If you want to create your button , see the "menu.lst" file as example :
    ex:
    Your button:
    Sygic = "BYVAR;RRSYGIC;RUNSYGIC<<RRSYGICDRIVE_RUNSYGIC",SY GIC,Icons\Sygic.png
  2. #52
    Mar 2009
    Quote Originally Posted by pierrotm777 View Post
    ex:
    Your button:
    on "MenuItemSet.skin" not appears the line PI-RRSygicDrive !
    i run RR appear this message:
    the file 'rrsygicdriver.txt' for the language 'english' is not found!!!!
  3. #53
    May 2008
    Bordeaux, France
    You don't use the last installer !!!!!
    How do you install your RR , with or without the profile mode ?
    This plugin accept only the normal mode (not profile mode)
    You must to see your plugin here:
    C:\Program Files\RideRunner\Plugins\RRSygicDrive\Languages\en glish\rrsygicdrive.txt
  4. #54
    Mar 2009
    i reinstall RR on normal mode, try
    thanks
  5. #55
  6. #56
    May 2008
    Bordeaux, France
    Quote Originally Posted by Enforcer View Post
    Tut Tut.
    I know, i need to work on that :-(
  7. #57
    Mar 2009
    1-Copy the ApplicationAPI.dll and sdkdriver.dll files from:
    F:\fleet_FLEET10_Europe_Unlimited\Development tools\Windows\SDK\Drivers\DLLs\XP_Vista_W7 -----is right?
    into your C:\WINDOWS folder
    2-Copy the ApplicationAPI.NET.dll from:
    F:\fleet_FLEET10_Europe_Unlimited\Development tools\Windows\Libs\.NET ----is right?
    into C:\Program Files\RideRunner\Plugins\RRSygicDrive
    4-register the plugin with the batch file 'RunMe1st.cmd'
    5-Add this line into your ExecTbl.ini file:
    "RUNSYGIC","Load;RRSygicDrive.skin;Sygic Drive;F:\fleet_FLEET10_Europe_Unlimited\Software\D rive\WindowsXP\Drive.exe|-no-safety -r546x415 -p1x76;Sygic FLEET"
    my ExecTBL.ini
    /, This (OPTIONAL) file contains translation commands.
    /, RR will accept the commands defined on the LEFT
    /, and execute them as expressed on the RIGHT
    /, you can use this to create or redefine any command
    /, (or to add functionality to any syandard command).
    /, The Format of this file is (by choice):
    /, "<COMMAND>","<EXEC COMMAND>"
    /, "<COMMAND>","<EXEC COMMAND>",filename.skin
    /, Examples:
    /, "AUDIO","LOAD;audio_player.skin;Audio Player"
    /, "RESTARTSONG","SEEKTO;00:00",audio_player.skin
    /, Extas:
    /, XM, FM and MM can be used instead of a skin file
    /, to be translated when XM, FM or MM is turned ON.
    /, PLAY, PAUSE and STOP can be used instead of skin
    /, file name so it executes commands based on MP3 or
    /, Video playback status.
    /, You can add commands to execute before suspend
    /, and after resume, using the codes bellow:
    /, For MediaCar Compatibility only:
    "AUDIONEXT","RRNEXT"
    "AUDIOPREV","RRPREV"
    / CORE
    "ONIDLE","CANCEL"
    / SOUNDS
    "ONBTNPRESS","PlaySound;$SKINPATH$Sounds\button1.w av"
    "ONBTNHOLD","PlaySound;$SKINPATH$Sounds\button2.wa v"
    / BACKGROUND CHANGING
    "SELECT","CHANGEBG",bg_browser.skin
    "CHANGEBG","SETVARBYCODE;BKGNDPOS;LISTPOS||SAVETOS KIN;BKGND;$BKGNDPOS$||SETVARBYCODE;BKGND;LISTTEXT| |SETVAR;BACKGROUND;$BKGND$||SAVETOSKIN;BACKGROUND; $BKGND$||RELOADALLSCREENS||SETLIST;$BKGNDPOS$"
    "ONFILECLICK","SETVARBYCODE;imagefilename;LISTTEXT ",bg_browser.skin
    "UPDATE_IMAGE","SETVARBYCODE;imagefilename;LISTTEX T"
    / Change iList settings in the skin
    "TurnOffiLists","ESC||SAVETOSKIN;usedx;false||SAVE TOSKIN;iListStatus;Off||RELOADSKIN||Load;skin_brow ser.skin"
    "TurnOniLists","ESC||SAVETOSKIN;usedx;true||SAVETO SKIN;iListStatus;On||RELOADSKIN||Load;skin_browser .skin"
    / SKIN SETUP
    "ONSKINSTART",""
    / MISC
    "CAMERA","LOAD;RRCam.skin||run;$skinpath$RRCam\RRC am.exe;RRCam.exe"
    / GMPC
    "GMPC","LOAD;GMPC.skin"
    "GMPCRUN","RUN;$garminpath$;!CDP",GMPC.skin
    "GMPCOSK","RUN;$SKINPATH$Scripts\Nav\Garmin\ElcosM enu.exe|GMPCOSK.skin"
    "GMPCOVERLAY","RUN;$SKINPATH$Scripts\Nav\Garmin\El cosMenu.exe|GMPCOL.skin"
    "GMPCXOVERLAY","SENDMSG;ElcosMenu;Exit"
    "GMPCCLOSE","RUN;$skinpath$Scripts\Nav\Garmin\GMPC Close.exe"
    / IGO8
    "IGO8","LOAD;igo.skin;iGO;$igo8path$;iGO Zoom"
    / IGUIDANCE
    "IGUIDANCE","GPS"
    menu.ini
    rrmenuitem3 = "BYVAR;RRSYGIC;RUNSYGIC<<RRSYGICDRIVE_RUNSYGIC",SY GIC,Icons\Sygic.png
    rrmenu2item5 = "menu;dimmer.skin",DIMMER
    rrmenu2item6 = "RRPLUGINMGR",PLUGIN MGR
    RRSygicDrive.ini
    [RRSygicDrive]
    windowname=Sygic FLEET
    sygicpath=F:\fleet_FLEET10_Europe_Unlimited\Softwa re\Drive\WindowsXP\
    sygicarguments=-no-safety -r546x415 -p1x76
    initonstart=No
    minimizeonstart=No
    eventsactive=Yes
    eventsflashmessage=Yes
    language=english
    countrypanel=eu
    [OnlineServices]
    online=Yes
    username=pierrotm777
    password=marley
    [Coordinates]
    latitude=48.858589
    longitude=2.292409
    [XYEnter]
    keysequencelatlon={1}{LAT}{CLICK}{2}{LON}
    xmouse=0
    ymouse=0
    Menu.lst
    [ Available Menu Items]
    # LISTITEM = "COMMAND",LABEL[,ICON_PATH],[,DESCRIPTION]
    -CLEAR- = "",,,,Clears the button's functionality
    # Other Navigation
    GMPC = "GMPC||GMPCOVERLAY||GMPCRUN",GMPC,Icons\GPS.pn g
    # PLUGINS
    what should I do
  8. #58
    May 2008
    Bordeaux, France
    All is ok, but ,
    Delete the spaces into the two lines:
    rrmenuitem3 = "BYVAR;RRSYGIC;RUNSYGIC<<RRSYGICDRIVE_RUNSYGIC ",SY GIC,Icons\Sygic.png
    and
    Sygic = "BYVAR;RRSYGIC;RUNSYGIC<<RRSYGICDRIVE_RUNSYGIC ",SY GIC,Icons\Sygic.png
  9. #59
    Mar 2009
    All is ok, but ,
    and
    O.S Windows Tiny 7
    i delete the spaces into the two lines
    nothing happens
  10. #60
    May 2008
    Bordeaux, France
    Send me the files that you have into your plugin folder
  1. Sygic Drive PC
    By _dopehead_ in forum Sygic Drive
    Last Post: 07-24-2011, 04:27 PM
  2. Sygic PNG
    By nelissen in forum GPS
    Last Post: 12-01-2010, 01:17 PM
  3. Any one use Sygic?
    By shawns in forum Sygic Drive
    Last Post: 01-10-2009, 09:13 PM
  4. help sygic
    By tezuya in forum GPS
    Last Post: 11-11-2008, 07:41 AM
  5. Sygic Drive and/or iGo
    By kfuglsang in forum Centrafuse
    Last Post: 03-25-2008, 12:23 PM
