View Poll Results: Do you think to use this plugin ?
Voters
9. You may not vote on this poll
  • yes
    8 88.89%
  • no
    1 11.11%
Page 10 of 19 FirstFirst 12345678910111213141516171819 LastLast
Results 91 to 100 of 189
Thread: RRGoogleMapsTools for RideRunner
  1. #91
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Yes , for have no conflict between real com port and virtual com port build by xport !!!
  2. #92
    Mar 2011
    Quote Originally Posted by pierrotm777 View Post
    however, right to bring to the knowledge,
    Garmin also in simulation snaps dramatically, something that Sygic and igo do not.
    however septum the right door, then try with igo8.
    curiosity. Also on igo I have seen is that the dll IGO MUTE. but how come it does not work well as with Sygic and Garmin?
    other curiosity, do you know if it works with igomysize IGO831?
    thanks again for all the support that you're giving me. you're on your award
  3. #93
    May 2008
    Bordeaux, France
    Quote Originally Posted by Carlo201983 View Post
    dll mute run also well with sygic or Garmin . You just need to patch the software like that:
    setdll.exe -d:NavMute.dll iGo_pc.exe
    About igomysize , yes also !
  4. #94
    Mar 2011
    I have this:
    SETDLL.EXE-d: NavMute.dll iGo_pc.exe
    but then again it does not work as well for Sygic and Garmin, almost as soon as the voice of the navigator finishes speaking the music volume does not return instantly, but after about 3.4 seconds thing with Sygic and Garmin does not happen, everything is instant and responsive .
    attached you can find the mute igo I have.
    Igo 8 Mute.rar
  5. #95
    May 2008
    Bordeaux, France
    I have this:
    Igo 8 Mute.rar
    for Sygic, use:
    setdll.exe -d:NavMute.dll drive.exe
    for Garmin, use:
    setdll.exe -d:NavMute.dll Que.exe
    That create a backup for each exe !
  6. #96
    May 2008
    Bordeaux, France
    Into your exectbl.ini file, you must to add these lines:
    "NAVPAUSE","SETVOL;Winamp;50"
    "NAVRESUME","SETVOL;WINAMP;255"
    /Used only with RRextended
    /"NAVPAUSE","RRVolRamper_Dn;75;30;Wave"
    /"NAVRESUME","RRVolRamper_Up;100;30
  7. #97
    Mar 2011
    on Sygic and Garmin use as you quote the appropriate dll everything works properly, the volume of the voice of the navigator returns immediately with igo thing that does not happen employing 3.4 seconds.
    I have this in the ini file:
    "NAVPAUSE","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/Volume/Set to -12 dB"
    "NAVRESUME","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/Volume/Set to -0 dB"
  8. #98
    May 2008
    Bordeaux, France
    That was an old foobar setup. If you use foobar try :
  9. #99
    Mar 2011
    thus putting an does not work.
    apart from this igomysize seems not to work
    inserting this .. igo do not start.
    [Navigation]
    GPSMode=2
    GPSPath=C:\Program Files\Igo 8\iGO831PC\iGO-MySize.exe|-width=800 -height=357
    GPSName=iGO8
  10. #100
    May 2008
    Bordeaux, France
    Setup your RR with Winamp player and test again !
  1. RideRunner for Android?
    By upspace in forum Road Runner
    Last Post: 09-24-2014, 02:20 PM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. Riderunner and iGo8
    By dorrisdormouse in forum Road Runner
    Last Post: 02-16-2010, 08:21 AM
  4. Not able to exit RideRunner...??
    By arb004 in forum Road Runner
    Last Post: 01-04-2010, 11:44 AM
  5. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
