View Poll Results: Do you think to use this plugin ?
Voters
9. You may not vote on this poll
  • yes
    8 88.89%
  • no
    1 11.11%
Page 11 of 19 FirstFirst ... 2345678910111213141516171819 LastLast
Results 101 to 110 of 189
Thread: RRGoogleMapsTools for RideRunner
  1. #101
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Sorry , try only:
    GPSPath=C:\Program Files\Igo 8\iGO831PC\iGO-MySize.exe
  2. #102
    Mar 2011
    Quote Originally Posted by pierrotm777 View Post
    Setup your RR with Winamp player and test again !
    but it is obvious that it works with Winamp.
    but I use foobar sounds better.
  3. #103
    Mar 2011
    Sorry , try only:
    starts but no resize
  4. #104
    May 2008
    Bordeaux, France
  5. #105
    Mar 2011
    I try this? where you say you work?
    Pause music on Sygic Drive directions
    I repeat, however, that the old method is that with Garmi with Sygic works perfectly. only with igo makes jokes, or delays in removing the "attenuation"
    and the problem of resize IGO, how do I?
  6. #106
    May 2008
    Bordeaux, France
    Quote Originally Posted by carlo201983 View Post
    i try this? Where you say you work?
    i repeat, however, that the old method is that with garmi with sygic works perfectly. Only with igo makes jokes, or delays in removing the "attenuation"
    and the problem of resize igo, how do i?
    yes
  7. #107
    Mar 2011
    DOES NOT WORK .. the volume is lowered or rather sometimes it does sometimes it does not: (
    it is absurd to every software has its own problem, (one freez but otherwise functioning properly. GARMIN), (the other Sygic everything works correctly, but the maps are OBSOLETE,) (and who does not resize igo 8 is more the fault on the audio .. I do not know what to do ..)
  8. #108
    May 2008
    Bordeaux, France
    Quote Originally Posted by Carlo201983 View Post
    The volume stay low for all GPS ?
    Try before with winamp.When all will be ok, pass to foobar ? No ?
    I have no issue with igo8 and resize !!!!
  9. #109
    Mar 2011
    No. As mentioned several times the volume of the problem is only with igo. With other navigation software working properly. then the problem lies in the "dll" mute igo who does not carry his work well. If you are able to resize igo with igomysize would you be so kind in telling me how you did it?
    Inviato dal mio Fantastico Samsung NOTE 3....altro che I-PHOGNE.... ahaha
  10. #110
    May 2008
    Bordeaux, France
    Try that:
    Attached Files Attached Files
  1. RideRunner for Android?
    By upspace in forum Road Runner
    Last Post: 09-24-2014, 02:20 PM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. Riderunner and iGo8
    By dorrisdormouse in forum Road Runner
    Last Post: 02-16-2010, 08:21 AM
  4. Not able to exit RideRunner...??
    By arb004 in forum Road Runner
    Last Post: 01-04-2010, 11:44 AM
  5. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
